Dead link - Chevy Colorado & GMC Canyon
post #1 of 3 (permalink) Old 09-08-2016, 07:30 PM Thread Starter
Dead link
1st Gen. Index of issues, Check Here First... The vibration at idle, rough idle thread repeatedly takes me back to the home page. I've read quite a bit as a visitor the past couple weeks and continue with the same issue. Need help please.
kjh9835 is offline
post #2 of 3 (permalink) Old 09-08-2016, 09:05 PM
to C'Fans
What words/terms are you using for "Search"? There are probably many Threads relating to the issue you have.
I read your other Thread. How about starting by telling us what vehicle you have i.e model, model year, engine, trans. etc. Are there any codes set? Is the problem only at idle? Posting what you have done in an attempt to correct the problem would save a lot of time.
post #3 of 3 (permalink) Old 09-08-2016, 10:07 PM Thread Starter
Was in the process, long poat and i had to stop n think about everything I've done. I googled "05 colorado rough idle" and there are several posts/results. I thought the Index of issues check here first" Issue: Vibration at Idle, Rough Idle 600 RPM - PIP3112. would take me to those posts but it sent me back to home page so i could not research on my own before putting the long post up
kjh9835 is offline
