Your Notifications 3 - Chevy Colorado & GMC Canyon
 1Likes
post #1 of 21 (permalink) Old 05-05-2017, 07:24 AM Thread Starter
Send a message via AIM to Z15_34396 Send a message via MSN to Z15_34396
The link does not show me the notifications, can't find what they are. What am I missing?
Mike
2015 Sierra Denali 6.2L/420HP
Protected by AMSOIL Synthetic Lubricants
Z15_34396 is offline
post #2 of 21 (permalink) Old 05-05-2017, 08:58 AM
BumbleZ's Avatar
In another thread the admins basically admitted they've done something to the site that causes this to happen if you are using Firefox browser with any ad blocking extensions.
You can get around it by switching over to the classic view of the site in the pull down menu near the bottom left of the page and then reload the site....
Fold-A-Cover G4 Elite
Factory GMC front Mud Flaps
BigBoi Headlight Switch Mod
In the garage: 2002 Z06
BumbleZ is offline
post #3 of 21 (permalink) Old 05-05-2017, 03:00 PM
Administrator
We actually have a fix for those using adblockers on the site. Just need to know what type of adblocker you are using and I'll talk you through what you need to do
Kevin
admin is offline
post #4 of 21 (permalink) Old 05-05-2017, 06:20 PM Thread Starter
Ghostery with Chrome Version 58.0.3029.96 (64-bit)
Mike
post #5 of 21 (permalink) Old 05-05-2017, 08:52 PM
BumbleZ's Avatar
Firefox with Adguard and uBlock Origin.
BumbleZ is offline
post #6 of 21 (permalink) Old 05-06-2017, 12:23 PM
Rememo's Avatar
Happens at work and at home, but for some reason there are less issues at home. I'm running Windows 10, Firefox 53, uBlock Origin, and Ghostery in both locations. Also happens with Chrome and uBlock Origin. At work the site is pretty much unusable. The menus don't work, posted images aren't visible, and the notifications are false. At home, posted images aren't visible, the menus don't work, but the notifications seem to work. Any assistance is appreciated.
Rememo is offline
post #7 of 21 (permalink) Old 05-06-2017, 03:16 PM
Administrator
Can you unblock [Verticalscope] from your adblock? it should fix the issue and still allow you to use adblock.
Niall
admin is offline
post #8 of 21 (permalink) Old 05-06-2017, 04:55 PM Thread Starter
That works......
Mike
post #9 of 21 (permalink) Old 05-06-2017, 05:40 PM
CuriousD's Avatar
Doesn't work for me. Also, most threads that used to have pictures in them now just say: "Attached Thumbnails" but don't display anything and avatars don't display either. Seems like whatever change(s) were made to the site have broken it more than helped it, and it was pretty damn broken to begin with.
- Justin
CuriousD is offline
post #10 of 21 (permalink) Old 05-06-2017, 07:31 PM
BumbleZ's Avatar
Same result here. Also can't see my notifications as before. I was instructed to clear my cache. Didn't work. Classis view IS working though with both adguard, uBlock Origins, and Disconnect active so that's an acceptable work around...
BumbleZ is offline
post #11 of 21 (permalink) Old 05-08-2017, 09:30 AM
Rememo's Avatar
Niall
I whistlisted 'static.verticalscope.com' and 'verticalscope.com'. I also deleted any cookies from this site and restarted Firefox. No joy. I can't see the image you posted. It simply says "attached thumbnail". The drop-down arrows of the menus don't work either. (Forums, New Posts, Garage, Tools).
Edit: If I disable uBlock and allow Verticalscope in Ghostery the site behaves normally. Will have to find the proper way of allowing Verticalscope in uBlock.
Rememo is offline
post #12 of 21 (permalink) Old 05-08-2017, 10:26 AM
Administrator
Have you tried to use classic skin option? If you got to the bottom of the page you can click the drop down function and switch to classic to see if that helps out your issue? What kind of device are you using?
~ Glenda
admin is offline
post #13 of 21 (permalink) Old 05-08-2017, 10:42 AM
Rememo's Avatar
~ Glenda
Classic skin never seemed to work for me. I finally found a way to allow VerticalScope in both uBlock and Ghostery for this site. Everything is working now. Thanks for the information.
Rememo is offline
post #14 of 21 (permalink) Old 05-08-2017, 09:40 PM
~ Glenda
I am using Chrome and Adblock Plus. How do I switch to "classic"? I select the Classic pulldown, but it always reverts to "Full".
njacobsen is offline
post #15 of 21 (permalink) Old 05-09-2017, 09:32 AM
Administrator
Hey there,
What device are you using?
~ Glenda
admin is offline
post #16 of 21 (permalink) Old 05-09-2017, 09:44 AM
Hey there,
~ Glenda
HP Laptop
post #17 of 21 (permalink) Old 05-09-2017, 02:22 PM
Administrator
Originally Posted by njacobsen View Post
HP Laptop
Hey there,
When you attempt to change your skin, have you tried clearing your cache and cookies?
Also, from your browser, make sure that the cookies are set to be remembered.
Go to the Settings in Chrome->Advanced settings->Privacy->Content Settings-> Allow local data to be set. Make sure you check this setting off.
Let us know if that worked at all for you.
Richard.
admin is offline
post #18 of 21 (permalink) Old 05-09-2017, 04:27 PM
Hey there,
Richard.
That did not change the behavior of the site. The skin reverts to "Full".
When you say "check this setting off", I assume you mean to say "Allow local data to be set" should be selected. Correct? That setting cannot be "turned off" unless a different setting is selected.
post #19 of 21 (permalink) Old 05-10-2017, 09:49 AM
Administrator
Can you try going to your user cp -> Settings & Options -> Edit Options -> Miscellaneous Options -> Forum Skin and change the skin from there.
Niall
njacobsen likes this.
admin is offline
post #20 of 21 (permalink) Old 05-10-2017, 10:27 AM
Niall
That fixed all of the issues. It now remains in the Classic Skin and drop downs work once again.
Thank you
