Rear End Knock [2015 GMC Canyon 3.6 CC 2WD] - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 02-26-2017, 10:55 AM Thread Starter
I've noticed my rear end knocks/clunks under certain circumstances. Mainly when I drive over speed bumps at an angle.
I found out there was a TSB out for re-torqueing the leaf springs so I took it to the dealer and had this work down.
It still knocked afterwards so I bugged the dealer about it and they mentioned the knock was caused by lateral movement and that all 2nd Gens do it. The rep also went out to my truck and showed me by pushing on the bed and rocking the entire truck to duplicate the knock. Apparently it has something to do with the axle.
Is anyone else running into these issues with the truck?
Amartinez5978 is offline
post #2 of 10 (permalink) Old 02-26-2017, 12:09 PM
Mine does the same thing! Went to the dealer and showed me exactly the same thing your dealer showed you! As I understand it, it's a tiny bit of end play in the axles!
Loving my 2016 Colorado. Had it since February 2016!
IowaDean is offline
post #3 of 10 (permalink) Old 02-26-2017, 12:47 PM Thread Starter
@IowaDean I honestly don't feel comfortable with this. I'm assuming this will have a long term affect on thr reliability of the axle. Geez
Sent from my SM-G930V using Tapatalk
post #4 of 10 (permalink) Old 02-26-2017, 01:15 PM
Janster's Avatar
I don't know how much experience you have with driving trucks..... but this characteristic is common in trucks especially those with spring/over axle configuration. It can also be referred to as 'Axle Wrap' - google it.
I haven't looked under the Canyon recently to notice if it has any sort of traction bars....etc (probably not). Most leaf sprung-over trucks I've owned never had any sort of traction bars/etc.
http://www.forbbodiesonly.com/moparf...le-jpg.186824/
Surely, you can do all sorts of things to try and correct this with aftermarket parts - but chances are, you'd be chasing your tail - while sacrificing ride comfort.
www.lieblweb.com
2016 GMC Canyon
2015 Infinity QX70s
Janster is offline
post #5 of 10 (permalink) Old 02-26-2017, 06:48 PM
I'm going to question the axle wrap scenario! The excellent video you provided showed it clearly, however it was demonstrated on a high torque application. For myself (and probably Amartine597) we're talking about going slow (5-10 mph). I notice mine when I pull into the driveway at an angle.
IowaDean is offline
post #6 of 10 (permalink) Old 02-26-2017, 07:09 PM
I have this same issue on my 2017 Canyon. It does it every day in my work parking garage. (My coworkers Tacoma doesn't clunk over the same speed bumps.) At first I thought something was loose, like my spare tire. I did a bit of experimenting today and found that my truck clunks if I go over a speed bump with only my right tires. If I go over the speed bump with only my left tires, it doesn't seem to do it.
raider27 is offline
post #7 of 10 (permalink) Old 02-26-2017, 11:11 PM Thread Starter
Perhaps the tolerances aren't as tight as they used to be? I know my older Silverado never did it .
post #8 of 10 (permalink) Old 02-27-2017, 12:33 AM
ZinkehCanyon's Avatar
Yup. Mine does this exact same thing when backing out if the driveway and over speed bumps or an uneven driveway. Always and only on the right side.
ZinkehCanyon is offline
post #9 of 10 (permalink) Old 03-03-2017, 03:46 PM
Took my Canyon in to the dealer today for the whistle noise and the rear axle clunk/bobble. The Canyon loaner they gave me feels quite a bit different to drive. The suspension seems much tighter and quieter. On my normal commute, I still experienced a very little bit of suspension noise, but nothing like what I hear/feel with mine. I doubt there is any difference in shocks between the SLE and SLT, so hopefully they figure out what's wrong with mine.
As a side note, my 2017 powertrain is night and day difference to the 2016 powertrain on this loaner.
raider27 is offline
post #10 of 10 (permalink) Old 04-18-2017, 07:31 PM
Whip8888's Avatar
Hey guys
I've had my truck since November and this Saturday was the first time I noticed this.
I was pulling up my driveway and it was loud enough for me and my wife to both hear it. I don't get any noise when I jump up and down on the bumper, but I get a ton of noise when I grab one of the back wheel and shake the truck back and forth.
I took it to the dealer and they said this is normal but i'm having a hard time believing that my brand new truck is supposed to sound like its 20 years old when I pull in to my driveway.
Has anyone tried shaking their truck from side to side and heard a bunch of noise or should I take it to another dealer for a second opinion.
Thanks
2016 Colorado Crew Cab Long Box
2013 Fusion SE 2.0L Eco Boost
1988 Firebird Formula
Whip8888 is offline
