Trailboss Bed Cover Options/Modifications? - Chevy Colorado & GMC Canyon
post #1 of 15 (permalink) Old 05-19-2017, 02:38 AM Thread Starter
Hey everyone,
So I own a 2016 Colorado Trailboss Duramax.
I'm wondering if anyone else with a Trailboss edition did anything special to cover the bed.. the Roll bar i've noticed it wrapped into the bed rails.. So it seems as if a "standard bed cover" would not be able to work being the Roll bar is in the way.. any options/modifications done to allow you to cover the back?
File Type: jpg 17265823_1497900986887182_4600232719333457920_n.jpg (405.4 KB, 48 views)
310HSSV is offline
post #2 of 15 (permalink) Old 05-19-2017, 02:40 AM
Originally Posted by 310HSSV View Post
Hey everyone,
I've seen one that works. But it's Velcro. So I didn't buy it since obviously you can't lock it.
Thegoose is offline
post #3 of 15 (permalink) Old 05-19-2017, 02:47 AM
spoonman's Avatar
GM makes a cover (well GM doesnt make it but they sell it as an accessory) that fits the sport bar trucks.
There is also a few threads where some members have cut the sport bar rear bracket to fit certain covers or notched the cover mounts.
spoonman is online now
post #4 of 15 (permalink) Old 05-19-2017, 04:18 AM Thread Starter
I don't mind if its velcro.. I'm just worried about when I go away and need to pack the back out with luggage, I just don't want water getting inside and ruining things.
310HSSV is offline
post #5 of 15 (permalink) Old 05-19-2017, 04:19 AM Thread Starter
Really? Great! Thanks, I'll have to give the dealer a call!
310HSSV is offline
post #6 of 15 (permalink) Old 05-19-2017, 06:56 AM
Wolfman01's Avatar
I just notched mine. There is a thread in the forum that details the process. I do have to go back and nibble a bit more off my rails when I can get more than negative free time to do so.
2015 Rally Yellow Chevy Colorado Z71 Trail Boss 4x4 crew cab (14k) "Colly"
MODS: 2016 Trail Boss sport bar and lights, Backing plates on sport bar for "Colorado" badge painted Rally Yellow, Westin brush guard with winch tray, Trailmaster 6000 lb winch, Rough Country light bar, Window tint, soft tonneau cover
Wolfman01 is offline
post #7 of 15 (permalink) Old 05-19-2017, 08:18 AM
I have the GM Accessory cover on my 16 Trailboss. Part of the deal with the truck. Took the dealer 11 days to get it installed with flying a "GM Accessory Specialist" out to assist....it still leaks and is a PITA to use. When I load the bed for trips I just keep anything I need dry in the center of the bed cause water just drips in around the sports bar and stays to the outside of the bed.
2016 Colorado Z71 Trail Boss Duramax Diesel
Summit White Crew Cab
go_n_low is offline
post #8 of 15 (permalink) Old 05-19-2017, 11:43 AM
Wolfman01's Avatar
Holy Crap. Have they ever installed truck accessories before? The one on my truck is the first one I've ever done, needed to be modded to fit around the sport bar, and I still got it done in the matter of a couple of hours. These things aren't that hard to install. You can get some black silicone sealant to seal up around the sport bar if you feel brave enough to mess with the stuff and not make a mess out of it to fix the water intrusion.
post #9 of 15 (permalink) Old 05-19-2017, 12:13 PM
I don't think they could change a taillight bulb. I have since changed to a different servicing dealer with not much better service. I continually have to bring the truck back for the same things over and over again. Not major mechanicals, just stupid annoyances. Eventually I either give up cause I don't have time to sit at the dealer and live with the issue or fix it myself.
go_n_low is offline
post #10 of 15 (permalink) Old 05-19-2017, 12:34 PM
Wolfman01's Avatar
That's unfortunate. My dealer worked extensively with me when I was modding my truck, and did an amazing job with the parts of the job that I needed their help with. It's unfortunate that you live way far away from me, or I'd point you to their service center.
post #11 of 15 (permalink) Old 05-19-2017, 12:39 PM
ferg Z71's Avatar
Just have to notch where the tonneaur rail meets the sport bar. Pic is a Revolver X2
ferg Z71 is offline
post #12 of 15 (permalink) Old 05-19-2017, 04:52 PM
ChaosTheory's Avatar
I'll tell you on Mon how that GM accessory soft cover fits with the bar. It will be installed by the dealership. I'm not too concerned about water intrusion or theft, as I just need it to keep the snow/leaves out. Just wonder if it will ventilate enough to evaporate whatever little leakage DOES occur, so as not to promote rust.
"Ragnar": 2017 Duramax 4x4 Z71
04/20: Ordered at dealer
04/25: Accepted by GM (2000)
04/26: TPW 05/08 given (3000)
04/29: Vehicle ready to build (3300)
05/05: Order sent to production (3400)
05/13: 0946 AM, Ragnar is born
05/17: Delivered to dealership (5000)
05/24: Delivered to me (6000)
ChaosTheory is online now
post #13 of 15 (permalink) Old 05-23-2017, 01:15 PM
I'm a bit late to the part. I just picked up my '16 Trail Boss less than 2 months ago and had the soft folding tonneau cover installed a week later. It works with the light bar (obviously) but not perfectly, it requires a little angling to get the tonneau's support bars past the light bar but it's nothing complicated. Mine doesn't leak, but it looks like when the dealer was fitting it with the weather seal they had to shift the positioning of the light bar during installation (I only noticed because they left a couple of the torx screws loose - I tightened them myself once I noticed). As somebody mentioned before, it is Velcro, but it does in fact lock. It pulls tight, and snaps down into a clip at the tailgate, so locking the tailgate essentially locks the tonneau cover. I can take pics later if you'd like to see it. Unrelated, does anybody know if the OEM bed extender works with this tonneau cover? I'm looking to get it, but the tonneau cover brackets stick out a few inches from the sides of the bed and I'm skeptical that it'll swing by them.
SpaceMan is offline
post #14 of 15 (permalink) Old 05-23-2017, 03:47 PM
If its anything like the bed extender on My Nissan, it probably will require additional hardware.
Access Lorado was the tonneau cover and they have a kit that has special brackets that allow the bed extender to function as required.
I doubt it is available for the 2nd Gen. Colorado yet but there is a chance they are working on it by now due to the popularity of these trucks.
I'd say contact them and see what they say, I sure like my bed extender and want one on my next truck (Colorado) if at all possible.
Access tonneau covers are great, they last and hold up in the wettest climates. (PNW)
Jettcity is offline
post #15 of 15 (permalink) Old 05-23-2017, 04:17 PM
I took some initiative and snapped some pics anyways, also made a few gifs.
To clarify, this is part number 19355365 on the Chevy accessories site.
"Premier Soft Roll-Up (with or without GM Sport Bar), for trucks, Short box by Advantage®"
First, the tonneau installed
The lever to latch/release the cover
Releasing the cover
The tonneau cover is too wide to just roll right past the light bar
You have to angle it to pass the light bar
This creates some slack once both sides are past the light bar
Rolled up the slack
There are 2 loops between the bed and rear window of the cab to secure the hooks to
The tonneau secured
Latching the cover
And lastly, this is one of the brackets for the cover. It sticks out a little over 3" from the side of the bed. Curious if the OEM bed extender would swing by 2 of them, or maybe some other brand.
All of this may be overkill, but hopefully it answers some questions. I remember not being able to find much info on it before I finally just took the leap and ordered it, glad I did.
SpaceMan is offline
