Caps - Page 16 - Chevy Colorado & GMC Canyon
 176Likes
post #301 of 312 (permalink) Old 04-17-2017, 01:01 AM
mhr900ss's Avatar
Mark: thanks for this info. A neighbour has the CX installed on his Taco and got the drop down front window. Unfortunately I'm looking at a big RTT and a kayak too so I need the extra weight loading; the drop down front window is not compatible with the aluminum HD frame so I'll have to find another way to clean the area. I'm interested to read that ARE gave you the 750lb stationary number; I contacted their customer service department directly and the response was vague. I'll be very interested to see your pics. I've also seen loads of pics of non HD canopies with RTTs but I'm looking at a 4 man and they weigh in at over 150lb then add the roof rack, then add half a 19' kayak, maybe another 25lb. All adds up!
Did you go with the bottom edge trim? I've seen the real deal up close and it looks fine but I think the lines of the truck look better without.
mhr900ss is offline
post #302 of 312 (permalink) Old 04-18-2017, 03:12 PM
Yeah I actually contacted them through social media and they got back to me right away and said all their caps were designed like that. As for the bottom, I got the trimless bottom edge because I thought it looked nicer. Also, I just found out that if you have the short bed ARE can't do the vented windoors on the sides because apparently there's not enough space so I just got the regular windoors and I'll build my own screens. Delivery should be in around 3 weeks so I'll post pics here when I get it installed.
Mark Hissner is online now
post #303 of 312 (permalink) Old 04-19-2017, 05:50 AM
GraniteBlue05's Avatar
I ordered and had installed an ARE V series (about $1,350) with the sliding swing down front window and had Bullet Liner sprayed in at the same time for $350. I am very pleased with both. Paint match is good on the ARE cap and the bedliner install was clean and professional.
I thought about going with a higher ARE CX model, but this suits my purpose and looks good on my 2017 CCSB Cyber Gray. The CX model had a black headliner that I did not care for since it made it too dark inside. I was surprised that my V series came with a pretty smooth light painted head liner. Years ago, the insides were pretty rough fiberglass but very nice on this V series. It also has an interior LED light built in.
An interesting thing . . . I ordered the ARE cap about two weeks before my ordered out 2017 Colorado Crew Cab came in and they both arrived on the same day! But I had to wait a schedule an install appointment about 5 days later.
GraniteBlue05 is offline
post #304 of 312 (permalink) Old 04-19-2017, 02:03 PM
JBT
JBT's Avatar
Any photos of the inside and outside?
_________________________
Built 8/18/15
A.R.E. Z Series Cap
Red Hot
JBT is offline
post #305 of 312 (permalink) Old 04-20-2017, 02:23 PM
Photos of my 2017 Colorado LT with ARE V Series cap.
The cap has the inside Sliding and Swing Down Front Window, standard side windows with screens, and LED interior light.
The first interior picture is with just the inside LED light on and naturally lighted. The second interior picture is with the camera flash to see a bit more detail.
- - -The last picture shows the interior Finish and Color.
JBT likes this.
post #306 of 312 (permalink) Old 04-20-2017, 02:53 PM
HITTHEBEACH's Avatar
Neat!! Good luck with both the new truck and the new cap!
GraniteBlue05 likes this.
2016 Canyon SLE, Copper Red, 2WD, CC, SB, V6, Tow, Bose, Cocoa-Dune Cloth, Factory spray liner, Locking Rear Diff., DeeZee Rubber Bed Mat, WeatherTech No-Drill Mud Flaps, Iron-Cross SS Running Boards. Built April 27, 2016. Delivered May 16, 2016.
HITTHEBEACH is offline
post #307 of 312 (permalink) Old 04-20-2017, 04:48 PM
mhr900ss's Avatar
Hi folks: I took the plunge yesterday and ordered the ARE CX HD; it will have the solid drivers side swing-up panel, a swing-up passenger side window with middle slider, a front fixed with middle slider (drop down not an option with HD frame) and the HD roof rack that is integral with the frame. It will also have a carpet liner.
The four risers to the roof rack bars connect directly to the HD aluminium frame through the top of the cap so the cap itself bears no load; good for 550lb on the move. It will take 4 to 5 weeks delivery; I'll post detailed pics once it's up top. It was not cheap; about CAN$3400 installed including taxes. I went with the solid drivers door because that's where my tools, compressor and other goodies are going to go; I'll build my own divider/tool storage arrangement.
Despite the multitude of picture of bigger roof top tents on a host of vehicles with a host of caps on the Internet, the feedback from cap suppliers was too vague for me to feel comfortable going without a higher, guaranteed load rating. I also spoke to several overland stores that specialize in RTTs; they too stated that fitting RTTs to SUVs, Landrovers, whatever with full factory roofs is never an issue but putting them on fibreglass canopies can be a compromise. One guy I talked to reminded me that a 200lb on-the-go rating for a cap can be pretty much divided by two when off road due to the extra bumps and that he had seen lots of cracked gel-coat on customers' truck caps.
JBT likes this.
mhr900ss is offline
post #308 of 312 (permalink) Old 04-20-2017, 05:30 PM
JBT
JBT's Avatar
@mhr900ss , You have to post some pics when you get it. We get to see very few of those. Thanks
hjw likes this.
Built 8/18/15
A.R.E. Z Series Cap
Red Hot
JBT is offline
post #309 of 312 (permalink) Old 05-05-2017, 07:00 PM
Finally got my ARE CX cap installed today! I'm really happy with it overall. The build quality is excellent and the carpet liner matches my bedrug perfectly. Let me know if you guys have any questions about it!
JBT and ernster500 like this.
post #310 of 312 (permalink) Old 05-10-2017, 10:57 AM
Originally Posted by Shifty Raven View Post
I originally posted in the Cyber Grey thread but here's my ARE Overland.
How are you liking this? I just ordered the same cap last week. They are doing a cross between the MX with extra headroom and the overland for me. I ordered it with the three way sportsman windows, interior lighting with the auto switch, and roof rails.
Waiting is killing me. I had to order the extra height because of my dog kennels. Not usually a fan of the look of the extra height, but practicality outweighs wants sometimes.
ClaysandBirds is offline
post #311 of 312 (permalink) Old 05-16-2017, 10:18 AM
MacksChevy's Avatar
Softtop
Originally Posted by Easmiles View Post
Hard to give a good review at this point. Have been doing MPG test though. Same stretch of road, cruise set at 65, .8 mpg better with top on and air dam removed. Install was simple. I have been making adjustments to it so the fit is a little better then the pics. Negative is the top sits about 1 inch above the back of the cap. With that said it is level with the middle of the cab. Shows how curved the cab is. I am building a rack to go over the top so I believe it will eliminate that visual bump. I love how easy it is to stow and that it stowes as one piece, where the besttop doesn't. No side windows doesn't really change visibility when driving. To be fair Imarket a fireman so drive with the mirrors primarily. I didn't love my hard top on a previous truck due to how hard it was to remove (no garage to lift to roof) I think I dig the look, now to see how it sleeps.
Where did you purchase your soft top, how much was it....
MacksChevy is offline
post #312 of 312 (permalink) Old 05-16-2017, 12:29 PM
I do not think you will get a reply. The post you refer to is about 2 1/2 years old. . .. . and the member has not logged in here since June of last year.
But. . . . ya never know.
MacksChevy likes this.
