Driver side lean - lean to the left - Chevy Lean (combined threads) - Page 2 - Chevy Colorado & GMC Canyon
 33Likes
post #21 of 131 (permalink) Old 06-20-2015, 11:26 AM
Two possible causes: weak leaf springs or the drivers side suspension wasn't at the resting position when the leaf spring shackle bolts were tightened.
post #22 of 131 (permalink) Old 06-20-2015, 02:00 PM
TopTheRockies's Avatar
Some other thread said that a guy ordered one and one of the wheels was a 17" instead of 18" . I'm sure you checked, but just a suggestion to see.
TopTheRockies is offline
post #23 of 131 (permalink) Old 06-22-2015, 09:11 AM
Just put your mother-in-law in the right rear passenger seat. Solves multiple issues on the Twins
-Will even out rear bed height issue. (Warning, possibilty exists for a low passenger side bed measurement once this has been performed. Application of several layers of duct tape will remedy this condition within a couple of weeks due to reduced caloric intake by the bed leveling system Remove and reapply as necessary to maintain proper weight adjustment.
-Reduces/eliminates steering wheel rattle noise. Of course application of the duct tape (see above) can vary the effectiveness of this measure.
-Enhancement of the Bose stereo system. Adds to the piercing treble needed in the rear of the cab as well as supplementing sub-bass response with bowel-port induced bass resonance (Warning-excessive bowel-induced bass response may cause a severe reduction in air-quality within the cabin area. Window position adjustments may be necessary to equalize/improve cleanliness of available oxygen.
Old 96 and jim_87 like this.
AUTimbo is offline
post #24 of 131 (permalink) Old 06-22-2015, 09:35 AM
Payload's Avatar
I once bought a new Jeep Grand Wagoneer that was lopsided from day one. Multiple trips to the dealer and consultations with factory reps couldn't make it right. It turned out to be a horrible lemon. Never ending problems. I eventually ate the loss and gave it away.
It soured me on the brand forever.
2015 Canyon SLT 4X4 V6, CC, SB.
Bronze Alloy Metallic/Cocoa Dune
Ordered 10/8/14 Picked up 12/22/14
Payload is offline
post #25 of 131 (permalink) Old 06-22-2015, 10:22 AM
Chevy Colorado & GMC Canyon - Search Results
more info,
100,000 miles on 01/28/13
110,000 miles on 10/22/13
120.000 miles on 07/08/14
130,000 miles on 03/19/15
140,000 miles on 11/19/15
davn is offline
post #26 of 131 (permalink) Old 06-22-2015, 09:34 PM
LudditeDave's Avatar
Anyone remember the '72-75 Novas? What were they F bodies or Omega bodies or something, but they were slightly askew. Looked like they were always ready to make a right turn going straight. GM admitted the problem, but couldn't or wouldn't fix it.
Ordered 11/10/14: 2015 Colorado LT EC,4wd, Red Rock Metallic, Conv and Luxury package, G80, Bose & Nav, 18" dark argent wheels, black assist steps, bed mat, bed divider, tow package.
Event status 3000 12/15/14. Still at 3000 12/29/14. Status 3000 01/05/15. Status 3000 01/12/15. Status 3400 no VIN or TPW 01/17/15. Got VIN, and waiting transportation 01/27/15. On the train 02/04/15. At dealer 02/13/15, taking delivery 02/18/15; 100 days stock to dock.
LudditeDave is offline
post #27 of 131 (permalink) Old 06-23-2015, 10:50 AM
Maybe someone hit you and drove off, check your vehicle for other signs of damage underneath the truck too.
stdbcs12 is offline
post #28 of 131 (permalink) Old 06-23-2015, 02:24 PM
Various measurements should make the source of the lean clear.
First, make sure you're parked on reasonably level ground. Second, make sure your tire pressure is equal for all tires.
Measure from the bottom of the leaf spring to the ground. I would be surprised if there's any difference here, assuming your'e on level ground and your tire pressure is the same.
Then measure from the top of the spring to the bump stop (i haven't looked on my truck, but it's probably a big rubber block on the bottom of the frame, above the leaf spring). If there's a difference, then one of your springs is more compressed than the other. This could be because of a weight differential, defective leaf spring, or a shackle bolt that was over-tightened and is thus limiting movement.
If there's no difference, then measure from the top of the frame to the body at the same point on both sides. The only difference should be the thickness of the body mounts.
If there's no difference after all of the above, then your body or frame must be tweaked somehow.
pierps is offline
post #29 of 131 (permalink) Old 06-26-2015, 10:28 AM
i have a 2015 f150 screw shortbed with fx4 suspension, with the 36 gallon fuel tank. When the truck is empty the truck will sit about 1" higher on the passenger side. When its full down to 1/4 it appers to be level. After 1/4 you can sorta tell. Thats probly the way they all are now. the issue never appeard on most 90's vehicles because there was no saftey concern for having the gas tank at the rear of the vehicle.
Only way to fix it properly is to get some sort of auto leveling air suspension like dodge has. Might solve the issue. I wanted a colorado but didnt come with a v8 so i jumped ship. I just felt they made the fenders on the colorado to big which threw of the mid size proportions+ no v8.
XtraSpclCrspy is offline
post #30 of 131 (permalink) Old 06-26-2015, 07:24 PM
Just a quick note to say that they sent it to the body shop, and they did make an "adjustment to the bed". So now with a full tank of gas the difference is 3/8" from their measuring point (i do not have the technical info in front of me). When I run the fuel out of the tank it should be level according to the Service Manager. Sorry I could not get more specific I do not have the information in front of me. Will update once I get a empty tank.
bluenorther is offline
post #31 of 131 (permalink) Old 08-08-2015, 06:41 PM
I just got my new truck last week and it is lower on the drivers side. I also remember the same thing on the Colorado I test drove a few months back. I have a full tank of gas too and it still leans. I put a level across the tailgate and the bubble is 1/2 outside of being centered. I'll call the dealer Monday.
JRJalapeno is offline
post #32 of 131 (permalink) Old 08-08-2015, 08:16 PM
Beondwacko's Avatar
Originally Posted by UnlimitedMatt View Post
Are you a large man?
There are too many underlying jokes in that statement!
2015 GMC Canyon Quicksilver Metallic access can,3.6L SLT 2WD
HID's, tint, LED reverse and cargo lights, bed mat,tailgate extender, sill plates, aux led reverse lighting, Trifecta advantage tune, more to come.
Beondwacko is offline
post #33 of 131 (permalink) Old 08-09-2015, 02:26 PM
I found this for a 2014 Silverado. I'll share this with the dealer.
post #34 of 131 (permalink) Old 10-04-2015, 10:55 PM
Does your colorado lean to driver's side?
My 2015 Colorado sits almost an inch lower on the driver's side. Although it probably doesn't cause any real issues it is enough that I feel it when I drive. Is there any adjustment in the suspension that would allow me to eliminate this lean? Does anyone else's truck do this?
2015 Colorado
2wd Z71 Crew Cab
My 1965 Mustang
BurgesS is offline
post #35 of 131 (permalink) Old 10-04-2015, 11:31 PM
ADMIN
Blue15ColoradoLT's Avatar
Yes. My truck is 265 lbs heavier on the driver side
JBT, RatRacer, savagebob and 6 others like this.
2015 Laser Blue Colorado LT
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED license plate lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Canyon swapped tail lights
Red painted calipers
Supermod ported throttle body
Silver metallic rally stripes
Super Skidz skid plate
Volant CAI
***NOTE***
SITE RULES
Blue15ColoradoLT is offline
post #36 of 131 (permalink) Old 10-05-2015, 12:08 AM
savagebob's Avatar
If you are measuring ground to fenders, then it is meaningless. There is a lot of tolerance stack up in a non adjustable suspension height setup anyway. The alignment is still correct when it left the factory. You should have it checked after 10k miles. The suspension will settle and change during that period. The fuel tank is on the left side. I doubt they bother to add a weight to the truck (almost empty tank) when the initial alignment is done.
savagebob is offline
post #37 of 131 (permalink) Old 10-05-2015, 09:34 AM
Google "Chevy Lean"
War Dang Eagle !!!
2016 Lazer Blue Long Bed Crew Cab
2004 Black ZQ8 Crew Cab <---Sold
Cut the Dang Wire Already!!!!!!!!!!!!!!!!!!!!
WDEagle is offline
post #38 of 131 (permalink) Old 10-05-2015, 10:45 AM
MoseMan's Avatar
Gas tank is on the drivers side. 20 gals of gas weighs in around that much.
2015 Cyber Gray SLT CC SB 4x4
MoseMan is offline
post #39 of 131 (permalink) Old 10-05-2015, 11:12 AM
Be careful when measuring side to side, it could be your location. I've notice my truck looks off level in some parking spots, and level in other spots. I've noticed this on most of my trucks... its a truck thing
JBT likes this.
Xcanuk is offline
post #40 of 131 (permalink) Old 10-05-2015, 11:54 AM
LOL about the same here. We need to hit up the salad bar
Rich-C is offline
