Fan/Whistling Noise / Cabin air filter replacement - Chevy Colorado & GMC Canyon
 25Likes
post #1 of 121 (permalink) Old 12-02-2014, 04:34 PM Thread Starter
Chipster's Avatar
I found this and thought it might be useful if you have this issue on your truck.
Not sure this is the best place for this, move it as needed.
http://sandyblogs.com/techlink/?p=3883
By the way , how can someone delete a thread that they posted?
Edit by 08Canyon 10/31/2015
The cabin air filter discussions from December 2014 through October 2015 have been blended as a mega-thread. I probably have not found all of them but I did find 8-10 discussions.
If anybody reads the posts between #1 and #91 it may now come across as confusing since they are shuffled into the deck by date. You will also encounter many broken links within cfans.com as many of the linked discussions are now contained here. Links to external sites are unaffected by the merges, however.
The title has been altered and the first post is edited to include keywords that may benefit a faster search.
Happy cabin air filter fix/replacement
Tags:
Cabin Air Filter
Cabin Filter
Air Filter
Cabin
Whistle
Whistling
HVAC
HVAC Whistle
HVAC Noise
High Pitch Sound
Whine
Fan Speed
Fan Whine
Fan Whistle
Fan Noise
Blower Noise
Blower Whistle
Last edited by 08Canyon; 10-31-2015 at 01:07 PM. Reason: Added content describing merging
Chipster is offline
post #2 of 121 (permalink) Old 12-02-2014, 04:55 PM
So there is an ac cabin filter on these trucks.
Last edited by CaryBosse; 12-02-2014 at 07:08 PM. Reason: corrected a typo from my phone
post #3 of 121 (permalink) Old 12-02-2014, 07:00 PM
Glad they added one to the new trucks but still makes no sense a to why the 1st gens never got one.
Barfurd is offline
post #4 of 121 (permalink) Old 12-02-2014, 07:54 PM
Xtrema01's Avatar
Thanks the October issue is great. Learned some new stuff about my Canyon.
Canyon Crew Cab SLT V6, 4x4, Long Bed, Quicksilver Metallic, Black Leather, Nav, Safety Package & Spray-on Bedliner.
Built: November 18, 2014 Delivered: January 17, 2015
Xtrema01 is offline
post #5 of 121 (permalink) Old 12-02-2014, 09:04 PM
No kidding. There are some great pieces of information in the October issue on the Canyon/Colorado.
All new owners should read, especially if you are putting a Tonneau Cover on your truck.
post #6 of 121 (permalink) Old 12-03-2014, 12:27 AM
KenLyns's Avatar
^Wait, this tapered bedside thing is new with the 2015 Colorado? As in previous GM trucks weren't designed like this?
KenLyns is offline
post #7 of 121 (permalink) Old 12-05-2014, 09:36 AM
Fan/Whistling Noise Behind Nav Panel Inceases with Fan Speed
New 15 Canyon. 400 miles so far.
Loud fan noise, kind of a whistling noise, behind the instrument/Nav panel when fan is turned on. Makes no difference if A/C is on vs vent. Increases and gets louder with fan speed. It is pretty loud and annoying.
Dealer is a ways away, any ideas?
Love the truck except this.
2015 Canyon, AT, CC, SB.
ktmtrek is offline
post #8 of 121 (permalink) Old 12-05-2014, 09:50 AM
There is an issue with the cabin air filter. Service bulletin already issued on it I believe. Dealer can probably fix pretty quickly I would assume.
post #9 of 121 (permalink) Old 12-05-2014, 10:00 AM
Kooler King's Avatar
could be related to a cabin air filter, but whistling noise in HVAC is usually related to a missing or misaligned seal between case sections or at a mode valve door ... depending on location, this level of work could require a lot of disassembly behind the dash and would be beyond capability of some dealer shops to tackle. Definitately get a second opinion from GM before allowing the dealer shop to take anything apart.
Kooler King is offline
post #10 of 121 (permalink) Old 12-05-2014, 10:02 AM
post #11 of 121 (permalink) Old 12-05-2014, 10:08 AM
The filter door also has a seal; need to look at it to make sure it isn't cut, missing, or not fully flat and continuous around the perimeter
post #12 of 121 (permalink) Old 12-05-2014, 10:31 AM
Thanks guys, I decided to go to the dealer today to get it checked out.
Thanks for the link- it would be nice if it was that easy.
ktmtrek is offline
post #13 of 121 (permalink) Old 12-05-2014, 11:22 AM Thread Starter
Chipster's Avatar
I think would be a good idea to create a new sub-forum called Issues & Resolutions (or something like that) where there would be a specific place for owners to report issues (like this one) and then follow up with the fixes that their dealer used to fix that problem. Doable?
1995 S-10 4X4 Blazer
2007 S-2000 Honda
Chipster is offline
post #14 of 121 (permalink) Old 12-06-2014, 01:10 AM
Yep, this is what was causing the noise. Dealer fixed it, it was from the cabin filter seal.
ktmtrek is offline
post #15 of 121 (permalink) Old 12-06-2014, 09:02 AM
Thanks for reporting back.
post #16 of 121 (permalink) Old 12-15-2014, 06:54 AM
plumcrazy's Avatar
just started hearing a whistle on mine. gonna look at this later. thanks
2015 Canyon, crew cab, all terrain, 4x4, v6, BFG AT TA KO2 265/70/17 tires with a zone 1.25" kit
plumcrazy is offline
post #17 of 121 (permalink) Old 12-16-2014, 05:29 PM
drizzle's Avatar
AC Fan Speed High Pitch Whistle
Just bought a 2015 GMC Canyon and noticed today that if I turn the fan speed all the way up @ 67 degree setting, a loud, high pitched whistle noise resonates from the glove compartment. If I open the glove compartment, the noise becomes louder. Has anyone else experienced this? Thanks.
drizzle is offline
post #18 of 121 (permalink) Old 12-16-2014, 05:36 PM
Beondwacko's Avatar
It's been mentioned a few times on this forum that the cover for the in cabin air filter is causing this whistle. Remove and reinstall fixes it.
Beondwacko is offline
post #19 of 121 (permalink) Old 12-16-2014, 05:39 PM
That is a leaking filter cover door; either it is not fully seated or the sealing foam has a gap in it. Easy dealer fix or a basic DIY if you're so inclined to give it a try before going to dealer.
post #20 of 121 (permalink) Old 12-16-2014, 06:05 PM
CFI
CFI's Avatar
A low quality control item with an easy fix. Maybe after 20,000 warranty claims, GM will train Clyde to install the air door and filter properly.
CFI is offline
