Door Sill Protection pics - Page 8 - Chevy Colorado & GMC Canyon
 82Likes
post #141 of 145 (permalink) Old 05-05-2017, 07:06 PM
Originally Posted by Bret_B View Post
I went with the XPEL textured black tape. I bought two 60" rolls and it was enough to do all four sills and the bottom of the tailgate that Chevy did not coat with the factory bed liner. The front sill pieces are 23 1/2 " and the rear sills are 13 1/2". Cut both front pieces from one roll and it will leave about 13 1/2" for one rear sill. Cut one rear piece out of the other roll and you will have about 47" left for the tailgate. It is a bummer that the factory does not coat the bottom of the tailgate.
After cutting the pieces to length, I rounded the corners. I set them out in the sun to get soft. I peeled all of the backing off to apply. I missed a couple times but it peeled up and stuck again without any problems.
I bought the same tape but have an extended cab so my application area is shaped a little different. Did you remove the weather stripping above and below your tape? Or just pull the stripping out and place the tape behind/under it? I was think of completely removing all of the stripping, applying the tape, and then reattaching the stripping. Sounds like a lot of work but I want to make sure the tape covers the 90 degree corner of the door sill and all of the exposed painted surface.
thegraham77 is offline
post #142 of 145 (permalink) Old 05-05-2017, 08:07 PM
Jeff Jordan's Avatar
Got these off eBay. Front and back. http://www.ebay.com/itm/Door-Sill-Pl...414092?vxp=mtr
Last edited by Jeff Jordan; 05-05-2017 at 08:08 PM. Reason: Added the link I forgot to put in. Sorry.
Jeff Jordan is offline
post #143 of 145 (permalink) Old 05-05-2017, 11:47 PM
KY Red Rock's Avatar
Question
Originally Posted by Jeff Jordan View Post
How was the install?
Jeff Jordan likes this.
Bed Rug
WeatherTech Splash Guards
Finish protected by Chemical Guys & Turtle Wax
KY Red Rock is offline
post #144 of 145 (permalink) Old 05-10-2017, 07:32 PM
Bret_B's Avatar
I left the weather stripping where it was and just stuck the tape under it. It took a couple tries but the tape was easy to remove and reapply.
20015 Colorado LT, Crew Cab, Long Box, Cyber Gray Metallic.
Bret_B is offline
post #145 of 145 (permalink) Old 05-15-2017, 07:25 PM
Install was easy. Just have to hold one end while pushing out the water soap solution.
