Console Vault now made for the twins - Page 2 - Chevy Colorado & GMC Canyon
 68Likes
post #21 of 123 (permalink) Old 10-11-2015, 06:35 PM
There is just one bolt in each side securing this? Could you have dropped the vault in place, drilled a 1/4" hole in each side, pulled out the vault, enlarged the holes in the existing console to match the nutsert, inserted the nutserts, replaced the vault and installed 1/4" bolts from the inside?
DougE is offline
post #22 of 123 (permalink) Old 10-11-2015, 07:35 PM
savagebob's Avatar
You can do that with new nutserts and an installation tool. Problem is that the plastic is too weak to hold the nutserts. They would spin and would likely just pull out of the plastic Then you would still have the original serts sticking into the Console Vault.
Yes, there is only one bolt on each side securing the vault. It comes with the nutserts already in place and expanded into the 12 gauge steel sides. Are you wanting to mount it without removing the console center? It really doesn't get any easier than this.
Nutserts are really hollow threaded rivets. There is quite a big gap between the console insert and the outer structure of the console if that is where you were thinking to put the nutsert. The nutserts don't really stick out much into the vault and with a cap over them, you will not notice them.
savagebob is offline
post #23 of 123 (permalink) Old 10-11-2015, 07:41 PM
savagebob's Avatar
Originally Posted by matt2858 View Post
So how hard is it to remove the seats? And can't you just put the seat either way forward or way back and access it?
It's way easier than I thought. Seats don't have to come out. Front half of the console remains untouched except for removing the shifter trim bezel.
matt2858 likes this.
post #24 of 123 (permalink) Old 10-12-2015, 02:27 AM Thread Starter
matt2858's Avatar
Thank you Bob! My TPW is 10/12/15 so I am thinking I will have the truck soon. I just ordered the vault. I cannot wait to do the install. I'll let you know how it goes. Your pictures are much appreciated. Thanks again!
2016 GMC Canyon SLE All Terrain Quicksilver Crew Cab -SB - Nav - Bose - Trailer pckg -
Ordered 9/12/2015,TPW 10/12/2015, Shipped/In Transit 10/17/2015, TOOK DELIVERY 10/31/2015!
matt2858 is offline
post #25 of 123 (permalink) Old 10-12-2015, 09:23 AM
Skyshroud's Avatar
Savagebob,
Thank you so much for the detailed pictures and installation advice!
Skyshroud is offline
post #26 of 123 (permalink) Old 10-12-2015, 11:01 AM
I wasn't able to tell that the nutserts came already mounted in the box nor that there is space between the side of the box and the console so your way makes the best installation. I appreciate your posting this information.
DougE is offline
post #27 of 123 (permalink) Old 10-12-2015, 06:30 PM
savagebob's Avatar
There you go. I remember that day when I picked up mine from the dealer. Enjoy it, personalize it.
post #28 of 123 (permalink) Old 10-12-2015, 06:34 PM
savagebob's Avatar
It really is pretty simple. I made it harder by trying to put some 3/16" foam under it. The Tahoe version has much room between the top door of the vault and the bottom surface of the console armrest. The Colorado does not have any extra space. That is why I had to shim my latch.
post #29 of 123 (permalink) Old 10-23-2015, 06:25 AM Thread Starter
matt2858's Avatar
SavageBob, how is it working out? Any reason you went with a 4 digit combo lock vs 3 digit or key? Photo with stuff in it? Thanks!
matt2858 is offline
post #30 of 123 (permalink) Old 10-24-2015, 05:24 AM
savagebob's Avatar
The owner of the company recommended the max security 4 digit lock. I hate having to use a key. The vault is great. I don't keep anything in it. I use it for temp storage of my firearm when going in to forbidden buildings. Courthouse, post office, etc.
post #31 of 123 (permalink) Old 12-11-2015, 04:48 PM
Any chance of getting a few pics of it? Im curious how the inside looks as well. Has anyone installed in a Canyon? I'm assuming its the same
2016 GMC Canyon All Terrain Crew Cab Short Box 4x4
b.wild is offline
post #32 of 123 (permalink) Old 12-12-2015, 11:37 AM Thread Starter
matt2858's Avatar
Go back a page for pics.
matt2858 is offline
post #33 of 123 (permalink) Old 12-12-2015, 11:39 AM
Carlos31820's Avatar
Pics aren't showing up. Tried multiple browsers with no luck.
2015 GMC Canyon SLT, V6 Crew Cab Short Bed - Quicksilver Metallic, Driver Alert package, Navigation, Bose Audio, Trailering Package.
Carlos31820 is offline
post #34 of 123 (permalink) Old 12-12-2015, 03:08 PM
don't see any in multiple browsers
b.wild is offline
post #35 of 123 (permalink) Old 12-12-2015, 04:41 PM
Anybody actually got a photo of this thing installed in the twins? What are the inside dimensions?
Ernest t is offline
post #36 of 123 (permalink) Old 12-12-2015, 07:38 PM
Will be installing mine tomorrow.
Ac guy is offline
post #37 of 123 (permalink) Old 12-12-2015, 08:32 PM
savagebob's Avatar
Pics had to get deleted so I could post others. Storage must be at a premium here. Interior space is roughly the same as the console interior. It is the only game in town. If you need one, there is no other choice for the console location. It is a quality made product.
TexazReece and matt2858 like this.
post #38 of 123 (permalink) Old 12-13-2015, 03:29 AM
Well, I know what my next mod is. This looks sharp. I used to hide my pistol under the tray of my ZR-2's center console. Most people don't even realize the old ZR-2 has a compartment under the tray in the center console. I think I owned the truck for 5 or 6 years before I discovered it. No such thing in the new Canyon so this vault looks like a great option.
-Curtiss
CrashFix likes this.
phxdsrtrat is offline
post #39 of 123 (permalink) Old 12-13-2015, 11:36 AM
would someone mind measuring the opening of the vault for me? I can't seem to find the dimensions and it looks like it might be a tight squeeze for what I am thinking
b.wild is offline
post #40 of 123 (permalink) Old 12-13-2015, 01:24 PM
Thanks for the photos. I'm going to order one. Wife has been concerned about me keeping a pistol in there with no lock on the console. How fast can you unlock the thing with the 4 digit lock system?
Ernest t is offline
