Sound Of Rushing Water in Dash - Page 2 - Chevy Colorado & GMC Canyon
 4Likes
post #21 of 35 (permalink) Old 06-22-2016, 11:00 AM
Originally Posted by bglf83 View Post
My AC sounds like that to for a while when it just comes in.
I had a couple of GMC loaners that did it too. I think it's normal.
Yes my 16 colorado makes that odd noise the first time i call for AC in the day. Haha, darth vador...
trckn is offline
post #22 of 35 (permalink) Old 06-23-2016, 07:05 AM
I took my truck back for the 3rd time for this sound. The mechanic came out to ask how it has been who is the one who always works on it. I asked him what exactly is the process in that tech bulletin. He said just what i have read online. Jack the truck like 1ft off the ground in the front only, let it run close to an hour with the overfill cap off. He said yes you will lose coolant since it will bubble out, not a lot but definitely some, so make sure you have some if you plan on doing this several times at home.
Yes said the tried it a different way which did not yield any better results. He said since the thermostat is electronic they drove around with their little computer plugged in and the thermostats only opens 60-70% of the way at normal operating temp since we are not towing etc.. They said they told the computer to open it at 100% so there was no restricted flow, but that really didn't help much either. He said it is just a bad design with the reservoir placement and the hoses going into the heater core which make it susceptible to air.
Lot of info but it is good that they have made some effort to fix. I just don't understand how some people have did this once in their garage and it is good and mine has been in several times!
trckn is offline
post #23 of 35 (permalink) Old 03-06-2017, 02:29 PM
DemetrioGQ's Avatar
Originally Posted by salty_dog View Post
My dealer easily fixed this issue. They stated that they evacuated system and refilled.
Hoping this is the case with me haha.
2016 Colorado WT Crew Cab 2.5L
DemetrioGQ is offline
post #24 of 35 (permalink) Old 03-14-2017, 08:15 PM
Had mine in today. They burped system we'll see if it works. For what it's worth they said engineering is working on a solution.
Buckeye1! is offline
post #25 of 35 (permalink) Old 03-14-2017, 10:22 PM
Ive been burping mine for months now. It's a lot less but I'm guessing you need to do this a bunch consistently until it's totally gone and not just "when I think about" like ive been doing, lol
lqdchkn is offline
post #26 of 35 (permalink) Old 03-15-2017, 02:40 AM
DemetrioGQ's Avatar
Let me know if the noise goes away...
post #27 of 35 (permalink) Old 03-17-2017, 08:45 PM
I have only driven once since getting back. Too early to tell.
post #28 of 35 (permalink) Old 03-18-2017, 09:09 AM
It's doesn't bother me much. Do you think there is so much air it could cause issues down the road? If not it doesn't bother me and I'll burp it myself someday just to see if it goes away...
Sent from my XT1064 using Tapatalk
boombots is online now
post #29 of 35 (permalink) Old 03-18-2017, 09:43 AM
Dealer claims it won't hurt anything. Had them look at it while doing first oil change.
Mine doesn't do it all the time.
post #30 of 35 (permalink) Old 03-18-2017, 06:30 PM
DemetrioGQ's Avatar
I got hit with this. No work can be done until GM figures out what makes this rushing water sound. Meh - no biggie I've accepted it. Just blast music louder lol. Tech says the truck is fine, will drive fine, and no issue as of now. They will keep me/us posted on when they have a fix for it
post #31 of 35 (permalink) Old 03-18-2017, 07:13 PM
My answer was similar.
post #32 of 35 (permalink) Old 03-20-2017, 10:40 AM
i have the same issue, took it in and got the same response as DemetrioGQ. They checked it and said GM is aware and that is all. Just a little annoyance of a sound, but they didnt do anything else. Mine happens quite often.
eljefe is offline
post #33 of 35 (permalink) Old 03-20-2017, 10:59 AM
My local dealer said the same to me.
Seems like the cabin wouldn't get warmed as quickly with the heater coil partially empty.
Not a performance issue, but certainly a comfort and convenience issue.
Sent from my LG-H631 using Tapatalk
'16 Base
x.guillory is offline
post #34 of 35 (permalink) Old 03-20-2017, 11:28 AM
it is interesting, i have used my heater over the last week and has been fine, so this is indeed a very odd issue. The truck quickly warms up and when i turn the heat on its right there, and feels fine as far as heat. Im wondering if a design flaw or some other engineering situation is at play. I guess time will tell.
eljefe is offline
post #35 of 35 (permalink) Old 03-20-2017, 06:02 PM
DemetrioGQ's Avatar
Definitely just a little annoying sound but I get over it fast.
Let's hope they figure it out soon!
x.guillory likes this.
