Dash rattle solved - Chevy Colorado & GMC Canyon
 8Likes
post #1 of 40 (permalink) Old 08-18-2016, 10:10 AM Thread Starter
Dash rattle solved
First post... been lurking here for a while.
2016 Canyon SLT diesel, one month old. No issues whatsoever except for this.
I developed a rattle in the passenger side dash, sounded like something small rattling around the right dash speaker. Turns out it was a metal bracket just under the top lip inside the glove box. It's held on by 4 or 5 torx screws and most were only finger tight at best. Glad I found it before I had the dealer pull the dash apart.
So, just a quick note if anyone developes anything like this and where to possibly look.
Cheers,
Skidpuppy
JBT, Dorsey, lqdchkn and 2 others like this.
Skidpuppy is offline
post #2 of 40 (permalink) Old 08-18-2016, 10:19 AM
Excellent, so I take it you dropped the glove box and tightened the screws and that helped resolve the rattle?
I have a rattle that comes and goes... So ANNOYING
lusid is offline
post #3 of 40 (permalink) Old 08-18-2016, 10:40 AM
I developed a rattle in the passenger side dash, sounded like something small ralleling around the right dash speaker. Turns out it was a metal bracket just under the top lip inside the glove box. It's held on by 4 or 5 torx screws and most were only finger tight at best. Glad I found it before I had the dealer pull the dash apart.
Cheers,
Skidpuppy
It happened to my truck too. 2015 Canyon SLT. I did not notice any vibrations, however when I poped the glove box out for something else I found one screw inside the glove box which drew my attention to the other three which were all loose.
akkoacanyon is offline
post #4 of 40 (permalink) Old 08-18-2016, 12:09 PM Thread Starter
Yep, just opened it and tightened the screws.
post #5 of 40 (permalink) Old 08-18-2016, 09:03 PM
pltctycanyon's Avatar
funny i found a glove box mounting screw in the bottom of the box. the other 3-4 screws were not totally tight and that one either fell out or was never installed
2016
pltctycanyon is offline
post #6 of 40 (permalink) Old 08-19-2016, 04:13 PM
Thank you, Thank you!
4 - T15 torx screws at the top of the glovebox when you open it. For me the leftmost one was super loose, the remaining three were better but still needed to be tightened. Hoping this was the harmonic rattle with the sound system at certain frequencies (and it didn't take a loud volume). Prior to this quick fix I thought the rattle was coming from either the front right dash or the passenger door, we'll see. I'd rather fix stuff like this myself than let someone else who may not care about details take my interior apart.
2016 Canyon SLT
Update: no more rattle
nspsend is offline
post #7 of 40 (permalink) Old 10-04-2016, 07:22 AM
superjet71's Avatar
I wonder if this is my issue, I noticed a rattle at times coming from the passenger area this morning.
superjet71 is offline
post #8 of 40 (permalink) Old 10-04-2016, 11:18 AM
GeeBus's Avatar
I've got a similar rattle. Going to check tonight
2016 GMC Canyon CC SB Black
K&N Blackhawk
MBRP Black Cat-Back
Zone 5.5" suspension + 1.5" body lift
Bushwacker Pocket Flares (currently not on)
18X9 Fast Rigg Wheels
35X12.5R18 Kenda MTR
Dipped Badges
Blacked out grille
Tinted Windows
LED Interior Lights
LED Fogs
HID Lows
Trifecta WOT
GeeBus is offline
post #9 of 40 (permalink) Old 10-04-2016, 11:55 AM
videobored's Avatar
Good job OP, you are doing God's work, son. Mine isn't rattling (yet), but I'll give'm a tighten this weekend just to head it off.
2016 Cyber Gray Z-71 v6/4wd/cc/sb (bose, spray-in bedliner, chrome tip)
Mods: plasti-dipped bowties, BAK Revolver X2 tonneau cover, Husky mud flaps and floor mats, Rexing V1 dashcam, NFab 6-step nerf bars
What's the difference between a dirty bus stop and a lobster with breast implants? One is a crusty bus station, the other is a busty crustacean.
videobored is offline
post #10 of 40 (permalink) Old 10-04-2016, 04:42 PM
404 Not Found's Avatar
Just checked mine. Two were snug. Two were barely seated. All are tight now. Thanks Skidpuppy. Makes me wonder how many really important bolts aren't tightened.
Andrew24 likes this.
Engine built 1/12/16
Placed order 2/20/16
Dealer ordered 2/25/16
Built and shipped 4/12/16
Delivered to dealer 4/22/16
Drove it home 4/27/16
404 Not Found is offline
post #11 of 40 (permalink) Old 10-04-2016, 07:40 PM
Andrew24's Avatar
2016 Canyon SLT
i found i only got it when the truck was under load above 90kmh, hopefully its fixed
2015 red hot ext cab z71
Andrew24 is online now
post #12 of 40 (permalink) Old 01-25-2017, 11:47 AM
Priminition's Avatar
I'll need some help with some identification of a screw. I currently have a large rattle behind my glove box. I opened the glove box and noticed that behind the glove box door there is supposed to be a screw of some sort connecting the dashboard to what looks like a metal bracket behind the glove box, except that it is currently missing. The metal bracket is connected to either a wiring cluster instrument (possible an ECM of sorts) OR it assists the ducting to the HVAC. I can't tell due to the cramped space behind the glove box, but it rattles over every bump in the road so you can imagine how annoying that is.
So if anyone can identify the missing screw, that would be helpful. Here is a couple of pictures of the missing screw. Its hard to tell what is needed with the cramped space. You will see that there is a shiny metal bracket with a triangle shaped metal backing is where the screw is missing.
2016 GMC Canyon SLE, 4x4 (All-Terrain)
Cyber Grey, Navigation, Bose System
Trailering Package, Spray-in bedliner
Fold-a-cover, Air Dam REMOVED
Priminition is offline
post #13 of 40 (permalink) Old 01-27-2017, 07:56 PM
Cheers,
Skidpuppy
Would it go away once you start driving? I have a noise coming from the passenger side of the truck as well, but once I start driving it goes away. In park or stopped at a light it'll come back. Sounds more like a ticking sound. Truck has around 900 miles currently.
skoot3r is offline
post #14 of 40 (permalink) Old 01-27-2017, 08:35 PM
Z71CYBER's Avatar
I have a metal rattle coming intermittently from the left side on my colorado, thought might be speaker cover grill but nope. Wonder what else could be moving around back there.
2015 Z71 V6 Cyber grey 2 Wheel Drive Crew Cab Long bed
Diablo Trinity T1000 Tuner | Trail Boss Wheels l Duratrac 265/65/17 l Eibach Fronts (2.0") / Rear Shocks l Swaybar End links l Peragon Bed Cover | K&N Drop in Filter | 30% Ceramic Tint | AVS Hood Deflector / Visors | Weathertec Front /Rear Mud Flaps | OEM Fender Flares l Carbonfiber Bow Tie Wrap| OEM BedLiner | OEM Tow Hitch | N Fab Sidesteps | OEM Z71 Mats
Z71CYBER is offline
post #15 of 40 (permalink) Old 01-28-2017, 02:25 PM
No kidding, I've found some dash screws loose too. Do those line workers at GM get liquor breaks or something? (or if not, should they?)
JScottM is online now
post #16 of 40 (permalink) Old 01-28-2017, 07:32 PM
I could imagine that every fastener is installed so it can be SEEN by the QC people but, how tight are they? How would anyone really know?
post #17 of 40 (permalink) Old 01-28-2017, 07:54 PM
i had loose glove compartment screws and one not even in the hole, just laying in the compartment box.
guess the installer couldn't keep up with the line that day.
post #18 of 40 (permalink) Old 01-28-2017, 08:46 PM
my window sticker said "some assembly required" in fine print. At least the battery was included right?
Vinolush likes this.
post #19 of 40 (permalink) Old 01-29-2017, 03:46 PM
Attachment 209489
Attachment 209497
So no luck from anyone as to the screw size? I really do not want to take it to the dealership so that they can have it for a week to fix one screw.
post #20 of 40 (permalink) Old 01-30-2017, 08:18 AM
Can't believe I'm seeing this thread a day after noticing a small vibration coming from the passenger's side. 2017 Canyon Denali. Going to check it today!
wborisenok is offline
