Dash Overlay - Chevy Colorado & GMC Canyon
 9Likes
  • 6 Post By moabite
  • 1 Post By moabite
  • 1 Post By sivartk
  • 1 Post By MV10
post #1 of 18 (permalink) Old 12-10-2016, 08:30 PM Thread Starter
Dash Overlay
One thing that I never liked about my '16 Canyon SLT was the huge silver bezel in the middle of the dash. I thought about painting or wrapping it as some have done...or purchasing a darker one. But since I've installed dash overlays in my last half dozen or so vehicles, I thought I'd go that route again. And the OEM "wood" trim in the Canyon was the worst fake wood I've ever seen. I went with dark burlwood this time around. You can also get several different shades and types of wood or numerous carbon fiber or solid colors. I did carbon fiber in one of my Jeeps. Liked it too.
Toughsox, JBT, matt2858 and 3 others like this.
moabite is offline
post #2 of 18 (permalink) Old 12-10-2016, 08:50 PM
mmg
mmg's Avatar
Looks good, you did A+ also on the install
mmg is offline
post #3 of 18 (permalink) Old 12-11-2016, 05:38 AM
backwoodsraider's Avatar
That just vinyl sticker stuff?
backwoodsraider is offline
post #4 of 18 (permalink) Old 12-11-2016, 08:49 AM
FAL guy's Avatar
I like it, can you tell us the brand and where you got them?
2016 GMC Canyon Crew SLT, 4x4, Cocoa/Dune, Copper Red
Ionic Gladiator Runningboards
BAK Bakflip Fibermax Tonneau cover
Bedrug Bedliner
FAL guy is online now
post #5 of 18 (permalink) Old 12-11-2016, 10:10 AM
PAR
PAR's Avatar
Is that one of these? I like it.
https://www.carid.com/2015-chevy-col...190411306.html
2015 Colorado CC/SB LT 2WD 3.6L V6
Cyber Gray/Jet Black
Convenience Pkg
18" Wheels
Tow Pkg/Locking Diff.
PAR is offline
post #6 of 18 (permalink) Old 12-11-2016, 11:28 AM Thread Starter
Yes...it is the $294 B&I small molded kit purchased through CARiD. Molded pieces included the dash bezel, shifter surround, and door panels. A few other flat pieces were included in the small kit but I haven't installed all of those and probably won't. I mainly wanted to cover the bright silver radio bezel...and the ugly piece around the shifter. As I mentioned, I've installed kits in Ford trucks, Toyota trucks, and a couple of Jeeps. The material is incredibly tough, easy to clean (I use Pledge), and simply does not come off if you do the prep work correctly. In fact, make sure you test fit and position each piece perfectly before you press it down...because you will never get it off again.
One (actually 2) of the pieces I did not install was for the steering wheel. There are 2 flat pieces to go on the silver part of the Canyon wheel. Those pieces really should be molded rather than flat. I just noticed that in the kit for the Colorado, the steering wheel overlay is, in fact, a molded piece.
The bezel piece was not exactly easy. I actually test fit it about a dozen times before finally getting the courage to remove the backing from the tape. I also removed the bezel and painted just the inner and outer edges black before applying the overlay. Most of that was not necessary. It turns out the only silver left showing would have been a narrow strip around the upper part of the radio opening .
PAR likes this.
moabite is offline
post #7 of 18 (permalink) Old 12-11-2016, 12:43 PM
sivartk's Avatar
Okay, I don't know if it was a change for the '17 Canyon SLT's, but I noticed that your dash lights up red and mine lights up blue around the buttons. Interesting.
2017 GMC Canyon SLT V6 2WD Crew Cab Short Box
sivartk is offline
post #8 of 18 (permalink) Old 12-11-2016, 01:14 PM
Krystof's Avatar
I'm pretty sure you have a brand confused Canyon. All Canyons should have red highlight lighting. Motor Trend had a brand confused Colorado as their yearly tester, too. Big whoops on GM quality control.
From the MT article:
"Our Silver Ice Metallic Chevrolet Colorado Duramax arrived with just 58 miles on the clock, and I was psyched to fire it up for the first timeóespecially because within a few days of its arrival, I was going to load it up and point it north for a much-needed vacation. You can probably imagine my surprise when the first time I fired it up, a GMC logo greeted me on the little driver instrument control display on the dashboard. Hmm. Upon closer inspection, the switches on the center stack that turn traction control on and off, among other things, were loose and only worked if you pushed them just so. My truck mustíve rolled down its Wentzville, Missouri, assembly line on an off day. Regardless, those are issues to be addressed at a later date because Iíve got big plans for the Colorado."
"Stormtrooper"
Krystof is offline
post #9 of 18 (permalink) Old 12-11-2016, 01:43 PM
pltctycanyon's Avatar
i'll keep the aluminum bezel in my black interior. it matches.
pltctycanyon is offline
post #10 of 18 (permalink) Old 12-11-2016, 02:46 PM
sivartk's Avatar
Yeah, I guess I'll have to do some digging to find out if a change was made for 2017. I think I actually like the blue better. It doesn't have brand confusion, but maybe color confusion
sivartk is offline
post #11 of 18 (permalink) Old 12-11-2016, 02:49 PM
PAR
PAR's Avatar
They have a good looking carbon fiber option. That's the route I would go if I were to do mine.
Convenience Pkg
18" Wheels
PAR is offline
post #12 of 18 (permalink) Old 12-20-2016, 06:57 AM
Send a message via AIM to Outdoor_funguy Send a message via MSN to Outdoor_funguy
I got mine covered with Vinyl Wrap from Gatorwraps . They have a lot of wraps, 3M Vinyl Wraps or Avery Denison Vinyl Wraps. You might also want to visit Gatorprints
Outdoor_funguy is offline
post #13 of 18 (permalink) Old 05-10-2017, 11:56 AM
LoJac963's Avatar
All 17's went to blue dash lighting. One reason I was glad to buy a 16!
Dash pieces look really good but after looking at the product I'm still confused. Are they actually molded pieces or just stickers?
2016 GMC Canyon SLT Cyber Grey, 4" MaxTrac lift with 2" RC level kit, LED's throughout, Iron Cross steps, Line-X, Stubby Jr, GMC All Weather floor mats, Bull Rings x9, DRL harness, OPT7 LED lows and fogs
LoJac963 is offline
post #14 of 18 (permalink) Old 05-10-2017, 03:43 PM
GraniteBlue05's Avatar
It looks nice in that Canyon. Don't like the picture of the light gray dash and dark wood on the CarID web page. And. . . . $300 for stickers is a bit much for me.
GraniteBlue05 is offline
post #15 of 18 (permalink) Old 05-12-2017, 09:48 PM
sivartk's Avatar
Dash pieces? The silver is molded aluminum pieces on the dash and steering wheel. Not sure what looks like "stickers"
Esoxchaser likes this.
sivartk is offline
post #16 of 18 (permalink) Old 05-12-2017, 11:26 PM
Disregard that.
The overlays I've seen were molded to fit the over the PLASTIC dash pieces on the dash and steering wheel.
They usually fit very well but I've seen some guys who can do wonders with 3M wrap.
Not me......
CheezyRiderAZ
CheezyRiderAZ is offline
post #17 of 18 (permalink) Old 05-26-2017, 08:44 AM
I hate the glare off glossy interior trim panels -- my Suburban LTZ's el-cheapo plastic wood was awful, and I still get poked in the eye by my Colorado from time to time. Unfortunately it looks like the only flat-finish option would be to splurge for custom paint, which is available through the B&I website. I didn't request a quote, but I imagine it's quite expensive.
B&I Product Search
I was wondering about the differences between the B&I kits since the CARID descriptions are identical. The B&I website labels the Combo kits as "Premium 3D" whereas non-Combos are just "Premium". Apparently the kits include both Colorado and Canyon pieces. For a 2017 crew cab:
jabberszl1 likes this.
MV10 is online now
post #18 of 18 (permalink) Old 05-26-2017, 11:14 AM Thread Starter
The Premium Molded or Premium 3D kits include molded pieces...whereas the others only include flexible flat pieces that bend around contours.
moabite is offline
