Center Console USB Install - Page 2 - Chevy Colorado & GMC Canyon
 4Likes
post #21 of 26 (permalink) Old 04-19-2017, 11:45 AM
Anyone know if those part numbers would work with the 7inch mylink android auto my radio is the IOb....also how to get to and where is the hmi module. Thanks
Sent from my SM-N920V using Tapatalk
killerpaintman is offline
post #22 of 26 (permalink) Old 04-19-2017, 11:58 AM
Yes, this will work with the I04, I05, and I06 radios. Basically as long as you have the MyLink system it will work.
The HMI is located directly behind the HVAC controls.
mjonesjr84 is offline
post #23 of 26 (permalink) Old 04-19-2017, 12:08 PM
I actually have the IOB its the 7 inch mylink was a option on the worktruck...guess will work with that too? Also how do you access the hmi by climate controls do you have to remove tons of stuff? Any link to access hmi? Thanks
post #24 of 26 (permalink) Old 04-19-2017, 12:16 PM
Your best bet is to see if your HMI has the open USB slot.
To get to the HMI, the trim around the radio and HVAC pops off. Then there is 4x 8mm screws holding the screen and HVAC panel in the dash. Remove that and it is clipped into the bottom of the opening.
killerpaintman likes this.
post #25 of 26 (permalink) Old 04-19-2017, 10:40 PM
Thanks for the info im thinking the IOB radio might be kind of a oddball...thanks for the help!!
post #26 of 26 (permalink) Old 04-20-2017, 07:12 AM
I think in the Colorado it is an odd ball because it just started in '17. I know that at my company we have 2 2017 Silverado WT's that have the I0B radio. It sucks. The only option it has is the projection (Android Auto/Apple Car Play).
If I were you, I'd look into changing out to an I05/I06 radio from Digital Dash Solutions or MVI.
2016 Colorado
