Sun glasses holder rattle? - Chevy Colorado & GMC Canyon
 2Likes
  • 1 Post By kaiser67
  • 1 Post By evonschu
post #1 of 8 (permalink) Old 04-20-2017, 11:40 AM Thread Starter
Anyone experiencing an issue with their sun glasses holder rattling? I'm not sure if it is because the foam piece in the corner is kinda cock-eye'd or if there is something loose where it is mounted.
kb_28 is offline
post #2 of 8 (permalink) Old 04-20-2017, 12:17 PM
kaiser67's Avatar
Some people had rattles from the roof liner and solved it by pushing up around the dome light or console. Maybe try applying pressure around the console/sunglass holder to see if anything needs to pop back into place.
JBT likes this.
2016 Red Rock LT CC SB v6 4x4
My build thread
Front bumper removal How-To
Rear Shock/lift Blocks How-To
kaiser67 is offline
post #3 of 8 (permalink) Old 04-20-2017, 12:53 PM
wildwest450's Avatar
no.
wildwest450 is offline
post #4 of 8 (permalink) Old 04-20-2017, 01:07 PM Thread Starter
Sounds good. I will give that a try. Thanks.
kb_28 is offline
post #5 of 8 (permalink) Old 04-20-2017, 01:19 PM
The rattle is from your glasses touching the roof of the compartment.
I put some self stick rubber strips across the top of the compartment and it cured the rattle.
I used some weatherstripping that was about 3/16 inch thick and about a half in wide.
Three strips was enough and it is soft, so it doesn't put pressure on the glasses.
B.Ruhtra is offline
post #6 of 8 (permalink) Old 04-21-2017, 12:14 PM Thread Starter
I'll give that a try. I don't have sunglasses in the compartment though.
kb_28 is offline
post #7 of 8 (permalink) Old 04-21-2017, 04:02 PM
Over head rattle
I have the same problem I have nothing in the compartment. It's almost as if there is a wire or something hitting the compartment above. If anyone knows how to drop the overhead panel down please post. Mine is 2015 Canyon SLE.
white cat is offline
post #8 of 8 (permalink) Old 04-21-2017, 06:37 PM
evonschu's Avatar
I wrapp my sunglasses in a small microfiber towel that I'd normally use to remove minor smudges. Works great in stopping this too.
CaryBosse likes this.
evonschu is offline
