Cruise Control Issues - Page 2 - Chevy Colorado & GMC Canyon
 2Likes
post #21 of 30 (permalink) Old 10-06-2016, 12:34 AM
Sometimes when a person steps on the brake and then just slides their foot off, the peddle snaps up so quickly it hits the switch and moves it. When this happens, the switch may be right on the brink of going on. If it is acting up, put your foot under the peddle and pull up while you try the cruise again. If that helps, grab the switch and adjust it toward the peddle slightly. The switch is made to auto adjust after installation by pulling up the peddle until it hits the end of travel. There are no nuts to adjust.
woodburner is offline
post #22 of 30 (permalink) Old 11-28-2016, 01:26 PM Thread Starter
Truck goes back into the dealer tomorrow as this issue is still ongoing. The break lights fire all by themselves. I have confirmed this both while moving and sitting idle. When sitting idle there is a noise which sounds like a relay or switch under the center console just ahead of the armrest. I can feel it engage and did-engage. You can clearly here it when idle. When I press the brake pedal the switch fires and the brake lights come on normally. the switch by the pedal and does not seem to be the issue as I can put my foot under the pedal to hold it up and the random firing of the switch still happens.
The brakes thankfully do not engage when this happens but the computer thinks they are as the lights come on and thus disengages my cruise or does not let me turn it on at all if the brake lights are already on.
I have even seen the brake light come on when parked and shut off and eve when the truck was up on the hoist getting work done.
Hopefully with this added info the dealer can finally fix this issue tomorrow.
Esoxchaser likes this.
bassthumper21 is offline
post #23 of 30 (permalink) Old 11-28-2016, 01:29 PM
Bad switch or pinched wire under the IP? I hope they take the time this time.
post #24 of 30 (permalink) Old 11-29-2016, 10:01 PM Thread Starter
So on the fourth visit and with the replacement of the brake switch and a calibration my brake light issue seems to be resolved. I still need to test out the cruise control on the highway but I didn't have any erratic brake lights coming on after I picked it up. Hopefully this is the end of it!
post #25 of 30 (permalink) Old 11-29-2016, 10:07 PM
Sounds good!
post #26 of 30 (permalink) Old 11-29-2016, 11:46 PM
Got my fingers crossed for ya
Toughsox is online now
post #27 of 30 (permalink) Old 01-10-2017, 03:21 PM Thread Starter
Issue still not completely fixed. The new brake switch helped a lot but the issue remains. Truck goes back in on Monday to the dealer. Also have an open support case with GM Customer service as well! My guess is it is better cause the brake switch is brand new, as it ages it will get s worse like the old one.
post #28 of 30 (permalink) Old 01-11-2017, 11:00 AM
Originally Posted by bassthumper21 View Post
I have a 2016 Canyon extended cab 4x4 I encountered problems with my cruise control today. I have just reached the 5000Km on the truck.I went on a road trip this weekend about 600Km each way. On the way down cruise worked as expected. It was a great drive down, however on the way back I fought the whole way to try and keep cruise control engaged. I would get it set and it would be fine for a bit and then it would stop. The icon would still be lit on the dash but no longer green as if I hadn't set it or I touched the brake. It did this the whole way back, shutting itself off after no specific period. I even pulled off the highway to see if shutting the truck down and starting it again would have a reset effect but I had issue the whole way home. There were no other warnings lights or issues with the truck.
Has anyone encountered any issues with their cruise control?
I wonder if it is a transmission temperature issue?
MolonLabe is offline
post #29 of 30 (permalink) Old 01-11-2017, 01:36 PM
Like I said before, is the switch being moved?
post #30 of 30 (permalink) Old 01-16-2017, 10:59 PM Thread Starter
Dealer had the truck all day today.*They have ordered a brake switch for the second time now. Waiting for the part to arrive, should hopefully be here*Wednesday or Thursday depending on travel time.
