Hard to find replacement Air Filter locally. - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 11-14-2016, 11:15 AM Thread Starter
Did oil change and service at home, almost 40K so I decided to replace air filter.
I went to 3 different parts stores Saturday and not a single one had air filter for 2015 V6 in stock, all order only. I missed the closing of the local Chevy Dealer parts counter by an hour and I HATE going to that place any ways. It's frustrating dealing with those morons and the all around terrible customer service at that dealership (not where I bought it).
Has anyone else had problem finding them? I guess I will order online.
jimmac91 is offline
post #2 of 10 (permalink) Old 11-14-2016, 12:15 PM
RCogan86's Avatar
I inquired about one just for curiosity sake couple of weeks ago, same result. Big 3 had to order it, oddly they could get a K&N faster. Also, a 4th didn't have a listing for filter, but could get a K&N intake.
Not really sure why GM had to make another filter design, between the camaro, silverado, and older colorado/canyons you would think there was more then enough options to suffice. My opinion tho
RCogan86 is offline
post #3 of 10 (permalink) Old 11-14-2016, 12:42 PM
I had trouble with O'Reilly and Autozone a while back, but at time, dealer had air filters on sale: Even dealer had to order, but he had it the next day.
I remember when you could go to Walmart or K-Mart and they had most of the air filters on the shelf. Now days, the variety is too great. You would think that an engineer would find a way to use a standard part for something like this rather than re-design the blasted thing.
I had a 1978 Ford LTD II with a V8 302. Ford made a few of those engines back then. You know, Mustangs, T-Birds, regular LTDs, etc. Same frame on the LTD II as the T-Bird of that time frame. Turns out the air filter was specific to the LTD II and worse, the only vehicle that took that size tire was an LTD II. Nothing like calling a tire retailer and asking for a size tire and they saying, oh, you drive an LTD II.
Volume of our trucks is reaching a point where I would expect a few places will start stocking our air filters.
post #4 of 10 (permalink) Old 05-12-2017, 12:25 PM
imref's Avatar
i picked up an air filter from the dealer and changed it myself. what a PITA! My last few cars have all had clips that hold the housing in place. This truck has four screws. Once they are out, it's very difficult to move the housing to get to the filter.
Are folks taking off the housing by disconnecting the intake hose?
2016 Colorado LT 4WD, Long-Box, Laser Blue/Jet Ash. Convenience & Luxury packages, Factory Spray-in Bed Liner, Safety Package, Trailering Package, Mud Flaps, Quad-fold G4 hard tonneau cover, 3" OEM steps, All-season OEM floor mats
Ordered 5/22/15
TPW: 7/13/15
Received: 8/8/15
imref is offline
post #5 of 10 (permalink) Old 05-12-2017, 01:47 PM
I do. Disconnect intake hose, disconnect MAF wire and take the cap off. It did not seem difficult when I did mine.
agsy is offline
post #6 of 10 (permalink) Old 05-12-2017, 02:09 PM
404 Not Found's Avatar
The screws are tight also. I found that using a socket ratchet and extention with screwdriver bit was a lot easier than just a screwdriver. Yes, having screws is total BS. Just another way for the dealer to charge $300.00 to look at your filter.
Engine built 1/12/16
Placed order 2/20/16
Dealer ordered 2/25/16
Built and shipped 4/12/16
Delivered to dealer 4/22/16
Drove it home 4/27/16
404 Not Found is offline
post #7 of 10 (permalink) Old 05-12-2017, 02:27 PM
imref's Avatar
thanks, I tried to change it without disconnecting the MAF and the intake hose, much more difficult that way. :)
Ordered 5/22/15
TPW: 7/13/15
Received: 8/8/15
imref is offline
post #8 of 10 (permalink) Old 05-12-2017, 02:27 PM
I just use a large Phillips #3 Screwdriver, not a big issue. I also loosen the hose clamp from the filter to the engine and pull the hose loose from the air filter housing. Nut driver would work best on this, but I just used a slotted screwdriver, one of my larger ones, probably 5/16" blade? It is tight, but I can then remove the filter without needing to undo the sensor connector. My memory is that the wiring to the sensor also had a clamp that had to be removed as well, without removing that, unhooking the connector didn't buy you anything.
I had Autozone order me a filter two weeks ago. They offered to ship it direct to my address, so I had it shipped to my office. No extra costs over the $17 cost of the filter. Ordered on a Saturday, arrived on Wednesday, although it was promised for Tuesday.
I just can't justify buying 6 at a time on Amazon or Rock Auto and having to find a place to store them.
post #9 of 10 (permalink) Old 05-12-2017, 02:27 PM
Send a message via AIM to CPTTango30 Send a message via MSN to CPTTango30
I just bought a K&N filter. Problem solved.
CPTTango30 is offline
post #10 of 10 (permalink) Old 05-15-2017, 11:12 PM
imref's Avatar
agreed, especially since mine probably didn't even need changing at 18k, 20 months.
Ordered 5/22/15
TPW: 7/13/15
Received: 8/8/15
imref is offline
