Random hot air blowing from vents? - Chevy Colorado & GMC Canyon
 3Likes
  • 1 Post By Mellowyellowz
  • 1 Post By Jay Bee
  • 1 Post By fondupot
post #1 of 9 (permalink) Old 05-07-2017, 10:28 AM Thread Starter
On my way home just now, I had hot air blowing through my vents for a good 5 minutes. I turned the AC on during that time, and the hot/cold air were mixing to make it not so hot, but not as cold as 70* should feel. Anyone know why this is? My settings were off when this happened.
2017 Summit White Colorado Z71
CC, 4X4, V6, SB
Eibach Pro
Zone Offroad 1.5" BL
Icon Swaybar Reloc.
Autosprings Diff. Drop
Swaybar Endlinks
Fuel Vectors 17" (custom painted matte gray)
Falken Wildpeak A/T3W 265/70/17 E-load
Blackoak 30" curved LED
RC mounting brackets
Rigid Industries Security Hardware Kit
Powdercoated Tow hooks
Illuminated Front Emblem // Black Rear Emblem
Tyger Armor Star Armor Side Step/Nerf Bars
Amerex B417 Fire Extinguisher
Jay Bee is offline
post #2 of 9 (permalink) Old 05-07-2017, 06:47 PM
reduce temp to 68-69
HotHead likes this.
Friends come and go, but enemies accumulate!
Mellowyellowz is offline
post #3 of 9 (permalink) Old 05-07-2017, 10:05 PM Thread Starter
I doubt that'll do anything cause the AC/Air wasnt even on at the time. The two temperatures were mixing. So some source of hot air, besides the AC, was blowing simultaneously creating a lukewarm air. All my gauges were reading normal, engine temp was normal.
CC, 4X4, V6, SB
Eibach Pro
Icon Swaybar Reloc.
Swaybar Endlinks
Jay Bee is offline
post #4 of 9 (permalink) Old 05-08-2017, 06:14 PM
It sounds like the hot/cold blend temperature sensor. Wasn't there a recall for this? I think even if "auto" mode is off, the system still tries to mix the air for the desired temperature. I think the only exception would be the "low" setting, you should try that maybe next time.
agsy is offline
post #5 of 9 (permalink) Old 05-08-2017, 06:39 PM
That was for 15 & 16's with the auto system, which resulted in a lack of heat.
The way the auto system works is a total enigma. Unless you are the engineer that designed it, any explanation is a stab at a possibility.
post #6 of 9 (permalink) Old 05-08-2017, 10:17 PM Thread Starter
Lol, so since it was like 50* outside, my car decided to blow hot air even with the ventilation/AC system off?
CC, 4X4, V6, SB
Eibach Pro
Icon Swaybar Reloc.
Swaybar Endlinks
Jay Bee is offline
post #7 of 9 (permalink) Old 05-08-2017, 11:12 PM
I believe the only way to truly turn the system "off", is to pull the fuse.
post #8 of 9 (permalink) Old 05-08-2017, 11:37 PM Thread Starter
I would like to give the DERP award to the engineers at chevy.
RatRacer likes this.
CC, 4X4, V6, SB
Eibach Pro
Icon Swaybar Reloc.
Swaybar Endlinks
Jay Bee is offline
post #9 of 9 (permalink) Old 05-10-2017, 11:45 AM
fondupot's Avatar
I find the AUTO hvac in my 2017 to be a little wonky too. small temp adjustments blast me with COLD or HOT air. Depending on if I go up or down.
fondupot is offline
