alignment specs - Chevy Colorado & GMC Canyon
 1Likes
  • 1 Post By allendc1
post #1 of 12 (permalink) Old 10-15-2014, 11:43 AM Thread Starter
alignment specs
Can someone get me the factory specs for alignment my machine only goes to 2014
allendc1 is offline
post #2 of 12 (permalink) Old 10-17-2014, 06:23 PM Thread Starter
never mind got it
allendc1 is offline
post #3 of 12 (permalink) Old 12-17-2014, 04:30 PM
Where did you get these specs from?
cravecrate is offline
post #4 of 12 (permalink) Old 12-17-2014, 04:35 PM
AirBender's Avatar
Originally Posted by allendc1 View Post
never mind got it
Thanks for posting. I'm going to print this out, nice to have on file.
"Ideals are peaceful...History is violent"
2015 Cardinal Red Canyon SLT- All Options + Line-X Spray-In Bed Liner - 3M Full Front/Half Hood Clear Bra - ReTrax Pro Retractable Tonneau Cover - 5" Chrome Assist Steps
AirBender is offline
post #5 of 12 (permalink) Old 02-19-2015, 10:04 AM
Any chance you could obtain and share the alignment specs for the 2wd crew cab long bed with v6? I went into dealer because I noticed that my steering wheel was a bit cocked to the left when driving straight. Alignment was fine (nu pulling) but the steering wheel was crooked. Before checking their Hunter alignment machine they started adjusting and when they were ready to re-align they realized they don't have the specs for the 2015 Colorados. They work order said they aligned it using the specs from the 2012 model. So now my wheel is straight when I let go of it but it pulls to the left.
Thanks!
Bad Apple is offline
post #6 of 12 (permalink) Old 03-19-2015, 01:26 AM Thread Starter
They can call their hunter rep and get the specs, and manually input them into the machine, if they can't let me know and I will get them for you.
allendc1 is offline
post #7 of 12 (permalink) Old 03-19-2015, 01:31 AM Thread Starter
Also if it's not pulling and the tires look even and smooth after some miles, having them set toe again will fix steering wheel angle depending on how OCD the alignment guy is. The 2012 has a lower caster on left versus right side which would cause a pull to left.
DasGoob likes this.
allendc1 is offline
post #8 of 12 (permalink) Old 05-30-2015, 02:43 AM
team helotes's Avatar
Did you by chance get the specs for a 2015 Canyon 2wd? I went by my buddies shop and their machine did not have them. We are planning on doing a 2 1/2" kit once my truck gets here.
team helotes is offline
post #9 of 12 (permalink) Old 05-30-2015, 04:28 AM
savagebob's Avatar
Or it could be that way to compensate for the crown in the highway so that it will track straight ahead.
savagebob is offline
post #10 of 12 (permalink) Old 03-12-2016, 03:25 PM
2015/2015 Wheel Alignment Specs
Hey guys I recently put a leveling kit on my 2016 Crew Cab Duramax Colorado. I took it to a local place to re-align the front wheels. They told me that they didn't not have the specs for 2015/2016. But they used the 2009-2012 spec. Tech told me that this was the same suspension as those models. They didn't charge me and gave me the adjustment printout. He stated that they only adjusted the toe because it was out. This kinda surprised me that no camber was done. I know it was just a leveling kit but I assume camber would be needed.
Does anyone have 2015/2016 spec range so I can compare?
epeniata is offline
post #11 of 12 (permalink) Old 03-12-2016, 03:40 PM
Take it some other place to have it aligned properly.
I really assume you got free work (translates to -it's not correct)
My THEORY is they didn't charge you for messing up the geometry on purpose.
End of story.
I merged you into the thread with specs posted in Post #2.
Humm....this thread indicates the settings are in fact the same. Maybe you're good.
Alignment
post #12 of 12 (permalink) Old 03-21-2016, 01:23 PM
DasGoob's Avatar
Send a message via Skype™ to DasGoob
Hunter Alignment Machine does not necessarily translate into perfect alignment. You must have a technician with training and understanding of what they are doing.
If your technician is not asking you many questions about your typical driving situation, then you should know that you may or may not get a good alignment for you. How much load do you normally carry? How many people normally with you? What is your commute like (road condition, lane choices, how much towing, etc.). All of these affect the alignment acutely or over a period of time. He can fine tune within the parameters given (especially since there is plus/minus 0.8 deg tolerance in the spec) to give you the best experience. Want something that hugs the road like it is on rails? He can do that (albeit sacrificing some tire life). Overall goal is to drive true and straight, with steering centered, during your normal driving conditions.
For example, one customer he had owned a Honda Odyssey. They most often drove this car with the full on family (5 of them, and all are quite....... heavy). Since this is normal condition, he loaded it up with sandbags to simulate the weight normally experienced in the correct locations, then gave it another shot. Amazing how a difference that made in the overall alignment of the four tires. Once this was done......tire wear was excellent, it drove very well, and customer was quite happy.
LONG STORY SHORT...... it is a bit of art form to do this correctly. Hunter makes great equipment, but if the technician is a bit thick, your end result will not mean perfection. Sad to say but some people just cannot follow instructions. (This is particularly sad as the newest Hunter Platforms literally walk you through step by step with photos and instructions, even what size tools to take to the task).
DasGoob
"Nothing is foolproof when you have a sufficiently talented fool"
'16 Colorado, Summit White, Z71 mud mats, LED everything in cab, LED cargo and B/U lights, LED bed lights, 12VDC outlets bed, Undercover Flex, Pop n Lock for Tailgate, LED front Turn signals, LED Tail lights, LED Rock Lights, 32" LED Light Bar in bumper, Weathertech mud flaps, Rocky Road Outfitters rock sliders, Patriotic Z71 decals, Elite Catch Can, Dash Cam
DasGoob is offline
