Wheeler's Off-Road, Inc. - Suspension - Page 7 - Chevy Colorado & GMC Canyon
 120Likes
post #121 of 178 (permalink) Old 04-07-2016, 06:20 PM Thread Starter
Wheeler's Off-Road, Inc's Avatar
Originally Posted by deadly99 View Post
Hey Dan, I submitted a request on your website and didn't get a response?
Hmmm.... Can you re-send it to dan@wheelersoffroad.com
support@wheelersoffroad.com
Wheeler's Off-Road, Inc is offline
post #122 of 178 (permalink) Old 04-07-2016, 06:55 PM Thread Starter
Whether you are still rocking the factory suspension, or have just upgraded to some trick Coilovers from King, Fox or Icon, be sure to grab a can of MavCoat to protect your investment from Rust and Corrosion!
Mavcoat® Steel Shield Corrosion Prevention Spray
post #123 of 178 (permalink) Old 04-27-2016, 02:05 PM Thread Starter
Currently in stock ready to ship at this time:
KING 25001-337 Colorado 15+ 2.5" Remote Reservoir Front Coilover Pair
KING 25001-338 Colorado 15+ 2.5" Piggyback Reservoir Rear Shock Pair
-Dan
lqdchkn likes this.
post #124 of 178 (permalink) Old 04-28-2016, 10:31 PM
KINGs came today.
Thanks for the help Dan
lqdchkn is offline
post #125 of 178 (permalink) Old 04-29-2016, 06:39 AM
The valving and spring rates on the Kings are suitable for the extra weight of the diesel?
post #126 of 178 (permalink) Old 04-29-2016, 11:45 AM Thread Starter
Correct. No changes for the diesel model per King.
post #127 of 178 (permalink) Old 05-25-2016, 12:39 PM Thread Starter
 4130 chromoly tubular upper control arms are 100% bolt on and hand crafted in the U.S.A.
 UCA’s are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle’s steering when 2.5″-3″ lift kits are installed.
 CNC machined tapered spindle adapters convert the factory ball joint to a 1″ uniball for added component strength & maximum wheel travel.
 TOTAL CHAOS includes 1″ I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball’s also features a military grade PTFE woven fabric liner that helps prevent noise.
 Custom profile upper and lower hi-misalignment spacers maximize droop wheel travel and are machined from heat treated 17-4 stainless steel.
 Upper control arms combined with extended length coil over shocks will allow for up to 1.5″ of additional wheel travel.
 Urethane bushings reduce bushing deflection compared to stock rubber bushings.
 Control arm pivots include zerk fittings to grease the urethane bushings & inner sleeves without disassembly.
 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
 Complete grade 8 hardware kit is included.
lqdchkn likes this.
post #128 of 178 (permalink) Old 06-14-2016, 06:20 PM Thread Starter
post #129 of 178 (permalink) Old 07-06-2016, 04:55 PM Thread Starter
Icon Stage 1 and Stage 2 Kits are in stock and ready to ship at this time!!
post #130 of 178 (permalink) Old 07-28-2016, 01:50 PM Thread Starter
We are planning a 2017 Calendar, and we want to Feature Your Rig!!
Please send Two High Quality Images to dan@wheelersoffroad.com for a chance to have your vehicle featured. (#WheelersCalendar)
*There will be lots of entries, so I apologize ahead of time if your rig does not make it in the calendar.
post #131 of 178 (permalink) Old 07-28-2016, 10:50 PM
Do not currently have good HIRES pics. :(
Is there a deadline for submission?
lqdchkn is offline
post #132 of 178 (permalink) Old 07-29-2016, 11:22 AM Thread Starter
No deadline yet. We are just getting started on it.
lqdchkn likes this.
post #133 of 178 (permalink) Old 07-29-2016, 11:54 AM Thread Starter
Any interested in a set of Total Chaos UCAs? $715.73 w/Free Shipping. In stock at this time!
DAN
lqdchkn likes this.
post #134 of 178 (permalink) Old 07-29-2016, 01:38 PM
Dan, I'll have a 2017 Canyon here as soon as I can and plan to install a lift and 31-32" tires practically the next day.
I want a highly functional lift because I travel some rough (~ 2' ruts and bumps for 100s of yards) job sites many times per day, often combined with massive amounts of mud.
Which lift set up can I purchase that has awesome functionality (i.e. improved travel range) but that also gives me the look I want with a 4.5"-5.5" suspension lift?
Please advise.
Suns_PSD is offline
post #135 of 178 (permalink) Old 07-29-2016, 03:45 PM Thread Starter
@Suns_PSD For 4-6" Lift you have to go to a Drop-Bracket Style of lift. They generally re-use the stock front Shock and Coil assembly, and then use a longer somewhat better rear shock. The nice thing about the Drop-Bracket lifts is that they do keep the suspension angles pretty close to stock which is good for ride and suspension performance. The down-side is that they raise the vehicle center of gravity and usually run blocks to lift the rear. Both of which are considered less than ideal for real serious off road use (probably not a concern for your use so much).
We do sell the Rough Country Lifts, as well as lots of shock and coilover options from Icon, King, and Fox.
Dan
post #136 of 178 (permalink) Old 07-29-2016, 05:04 PM
How much lift can you get with the UCA's that improve travel?
I wonder if that combined with a small body lift (which I've always been against) would give me the net result I am looking for?
Thanks!
Suns_PSD is offline
post #137 of 178 (permalink) Old 07-29-2016, 07:53 PM
drewabbs's Avatar
If you only knew the power of of he darkside Suns_PSD...
drewabbs is offline
post #138 of 178 (permalink) Old 08-10-2016, 01:34 PM Thread Starter
post #139 of 178 (permalink) Old 09-08-2016, 11:47 AM Thread Starter
lqdchkn likes this.
post #140 of 178 (permalink) Old 09-08-2016, 05:36 PM
What is the better shock, the Fox 2.5s or the King's? And why?
And what about the money for each?
Suns_PSD is offline
