Wheels We Offer For 2nd Gen Trucks - Page 10 - Chevy Colorado & GMC Canyon
 51Likes
post #181 of 214 (permalink) Old 04-06-2017, 09:17 AM
CC1999's Avatar
Yes they appear to be removable.
2016 Colorado Dmax 4x4 White LT
Icon Stage V Suspension
1" rear lift blocks
Fuel Black Anza 18x8 Rims
Toyo Open County AT 285/60/18 tires
Duramax Tuner tune and Trans tune
Drop in bed liner and rubber Chevy mat
Black bow ties
Black OEM fender flairs
Custom built lighted headache rack and rails
Westin Brute crossover tool box
Other vehicles:
2015 Ram 2500 CTD 4x4 White Laramie
2011 Toyota Land Cruiser 4x4 White
CC1999 is offline
post #182 of 214 (permalink) Old 04-06-2017, 04:50 PM Thread Starter
ColoradoFans.com Site Sponsor
CUSTOMWHEELS4U's Avatar
Originally Posted by haulingnothing View Post
Nice. I know these aren't actual beadlocks, but I'm wondering if the beadlock ring is removable? I'd like to be able to take it off to paint it. OP, please feel free to chime in. Thanks
The ring itself is not. The bolts are removable though. We've had the flange powder coated. We take the bolts out and the powder coated tapes the wheel face off. Typically runs $50-60 per wheel.
CUSTOMWHEELS4U is offline
post #183 of 214 (permalink) Old 04-06-2017, 09:23 PM
CC1999's Avatar
I stand corrected .
Good to know,
I was thinking added plus for these, was if I ever scraped up a rim , that would be easy to fix by just replacing the ring.
I am guessing then that the Fuel Trophy is the same way, I have those on my Land Cruiser?
1" rear lift blocks
Black bow ties
Other vehicles:
CC1999 is offline
post #184 of 214 (permalink) Old 04-07-2017, 11:19 AM Thread Starter
Originally Posted by CC1999 View Post
I stand corrected .
Good to know,
Yeah they're part of the mold. There aren't any wheels I know of with removable rings that fit the twins.
post #185 of 214 (permalink) Old 04-07-2017, 11:22 AM Thread Starter
New 17x9 -12 wheel available for those of you needing 4.5" backspace for your lifted trucks. The wheel is matte black with removable gloss black inserts. Limited availability right now but there are a few sets in stock.
post #186 of 214 (permalink) Old 04-07-2017, 02:21 PM
Send a message via AIM to haulingnothing
Do you know of any with removable rings that could be custom drilled for the twins?
2016 Colorado - 2WD Extended Cab LT V6 - Laser Blue - Shoreline Edition
Plasti-Dipped badges - Air dam delete - DRL switch mod - OPT7 LED low beams - Moroso catch can - Pedal Commander
haulingnothing is offline
post #187 of 214 (permalink) Old 04-07-2017, 03:15 PM
I'm officially going to be an outlaw running chrome wheels! It's like they don't exist any longer!
Suns_PSD is offline
post #188 of 214 (permalink) Old 04-10-2017, 09:55 AM
What TPMS sensors are you guys running on your aftermarket wheels?
I wanna keep the original sensors in the factory wheels which I'll most likely use for winter only tires later.
RockAuto has OEM AC/Delco sensors for my '16 Canyon for about $37 ea.
TIA
Fasted58 is offline
post #189 of 214 (permalink) Old 04-10-2017, 10:29 AM
TIA
I bought a used OEM set on eBay for $40 for all 4 and they work just fine
rich7930 is online now
post #190 of 214 (permalink) Old 04-10-2017, 11:12 AM Thread Starter
The company OMF will build one that will bolt on to the Anza. I've seen them do it before.
https://www.omfperformance.com/
haulingnothing likes this.
post #191 of 214 (permalink) Old 04-15-2017, 01:04 AM
@CUSTOMWHEELS4U Do you happen to know, or stock lugs/locking sets that accommodate the Fuel Vectors for our bolt pattern?
Jay Bee is offline
post #192 of 214 (permalink) Old 04-17-2017, 11:13 AM Thread Starter
We do. They're the spline style lug that uses a key.
post #193 of 214 (permalink) Old 04-17-2017, 01:46 PM
CC1999's Avatar
Do you have any shorter black lugs then spline type?
My studies have the starter nubs cut off for running spacers which with my current setup I found that I no longer needed the spacers.
I think my wheels might take on a little deeper look to them if the lug nuts were not sticking out as far as the spline type do.
My lug nut are currently sticking out about as far as the center cap mane slightly past the center caps.
I am thinking possibly a shorter acorn style might do the trick.
1" rear lift blocks
Black bow ties
Other vehicles:
CC1999 is offline
post #194 of 214 (permalink) Old 04-17-2017, 02:51 PM Thread Starter
Yours are 1.9" tall. I don't stock them but I access to the same spline style lug but 1.38" tall. We usually don't stock them due to some of the fitment issues we had with other trucks. But if you trimmed the nubs off they'd probably work for you.
post #195 of 214 (permalink) Old 04-18-2017, 10:40 PM
CC1999's Avatar
Sounds good thanks.
Email sent.
1" rear lift blocks
Black bow ties
Other vehicles:
CC1999 is offline
post #196 of 214 (permalink) Old 04-28-2017, 09:47 PM
PM'd with an impossible task
slammedincouch is online now
post #197 of 214 (permalink) Old 05-05-2017, 02:07 AM
Any update on the GD7s in the gold/bronze?
G-Oil Guy is offline
post #198 of 214 (permalink) Old 05-05-2017, 11:32 AM Thread Starter
They've came in. A lot of them sold really quick. The only blanks left are 17x9 +15 for now.
post #199 of 214 (permalink) Old 05-05-2017, 12:50 PM
Thanks for the fast reply.
Did you happen to snag any "real life" pictures? I'm trying to get an idea of what these look like in a non professional photo setting before pulling the trigger
post #200 of 214 (permalink) Old 05-08-2017, 11:30 AM Thread Starter
I didn't since they ship direct from GRID after being drilled. I'll check with some of my customers and see what they can do for pics.
