SCC Super Z6 Snow Cables - Chevy Colorado & GMC Canyon
 2Likes
  • 2 Post By GregDAP
post #1 of 12 (permalink) Old 01-10-2017, 01:52 AM Thread Starter
Planning a trip up to Mammoth Mountain from SoCal in my 16 Canyon.
California has rules that requires that drivers must carry chains during winter weather on certain mountain roads or run the risk of being turned around at Chain Control checkpoints regardless of 4WD.
Reading Through a couple posts here and the internets, there really isn't much info on chains that would fit on the Twins.
The manual says not to use chains and to "Use another type of traction device" because of clearance issues.
They weren't kidding: There is maybe less than an inch on the Driver's Rear between the parking brake cable and tire sidewall.
There isn't an much of an issue on the Passenger Rear as the Parking brake cable is routed along the rear axle.
Hope to never have to used these, but they seemed easy enough to put on. SCC's Super Z Cables are designed for limited clearance and exceed class "S" Wheel well specs. Which I guess the Twins are not.
I Have a 2016 Canyon SLT. The Tire Size is 265/60-r18. The SCC Model I have is SZ441. The Reviews on Amazon are kind of mixed and other than buying a set of real snow tires I'm not sure of other options.
Manny is offline
post #2 of 12 (permalink) Old 01-10-2017, 02:06 AM Thread Starter
Meant to Post this to 2nd Gen Wheels and Tires. My apologies @08Canyon can I get a move?
Manny is offline
post #3 of 12 (permalink) Old 01-10-2017, 10:06 AM
macr88's Avatar
Can the inside portion be tightened up so the outside cable couplers are on the tire vs at the lip of your wheel?
I would also look to see if there's an emergency brake line cable bracket that can be bent to provide more clearance.
That cable shouldn't be that close to the tire, seems like something's not setup corrrctly.
-mac
macr88 is online now
post #4 of 12 (permalink) Old 01-10-2017, 11:06 AM
08Canyon is not a moderator anymore
Moved thread to the proper section
dshawster and macr88 like this.
GregDAP is offline
post #5 of 12 (permalink) Old 01-10-2017, 02:27 PM Thread Starter
The snow cables are self tightening and self centering, so this is the position they want to be in. I jacked up the back end and spun the wheel by hand everything is close and snow cable didn't want to move.
Don't have anyone elses parking brake cable to reference but it it appears the cable exits the wheel at the designed angle there isn't any slack in the system. I might tweak the bracket a little and secure with a zip tie but another obstacle in there is the leaf spring.
-mac
Manny is offline
post #6 of 12 (permalink) Old 01-10-2017, 06:42 PM
I too, am in Socal and planning a trip to Mammoth! Looking at the options for chains or cables even though I won't use them...
I picked up a set of what ended up being Trail Boss take-offs with 265/65/17 Duratracs which are snowflake / severe snow rated. At the point in which they actually make me put chains/cables on, they will more than likely have shut down the road already.
That being said... I still need to CARRY them or I'll get stuck...
This might be a complete faux pas, BUT... with a 4wd... what about putting the cables in the front and treating it almost like a FWD cable setup? Will it clear everything there? Bonus being that it will improve braking and turning as well =P
apexaddict6 is offline
post #7 of 12 (permalink) Old 01-10-2017, 07:20 PM
pltctycanyon's Avatar
i think you'll be needing flotation also
pltctycanyon is offline
post #8 of 12 (permalink) Old 01-11-2017, 03:17 PM Thread Starter
The manual says:
Code:
If you do find traction devices that will fit, install them on the rear tires....Install them on the tires of the rear axle. Do not use chains on the tires of the front axle.
So I dont know, might be a traction control thing?
Manny is offline
post #9 of 12 (permalink) Old 01-11-2017, 06:37 PM
aahh - traction control would make sense... dangit. I need to find something that will fit and that I can get in short order - mammoth is this weekend!
post #10 of 12 (permalink) Old 01-11-2017, 07:21 PM
just ordered a set of the same for my truck. The fitment guide on amazon had a different part number for it than the 4wheelparts guy did for the tire size that I have (265 65 17) - but he checked his guide twice before placing the order.
I don't anticipate ever needing it as I have the Duratracs with the snowflake on them - but CA requires me to carry them or I'll get stopped... sooooo... now they're ordered...
post #11 of 12 (permalink) Old 01-11-2017, 09:40 PM Thread Starter
I picked up mine from 4wheenparts they have a huge depot in Compton. Price is little higher at $123 but I have them. Going up on Thursday should be a interesting ride. Enjoy the fresh powder!
Manny is offline
post #12 of 12 (permalink) Old 01-22-2017, 10:17 AM
I purchased the Z-Cable Light Truck, SUV Tire Chains at Pep Boys. Reg $99.99 on sale for $84.99 OTD w/tax $92.43 Part Number ZT741 SKU 8237209
My truck is a 2016 WT tire size 265 70 R16 - As others have stated parking brake cable is close.
Installation is easy. Chains are split on the outside no need to drive on just slide under from rear. Lot of install videos on You Tube.
Notes, when you hook the rear chain link make sure it is flat and not twisted, clearance is close but does not interfere with brake cable.
MIKEMCFI is offline
