Height difference from Right to Left? - Chevy Colorado & GMC Canyon
 9Likes
  • 2 Post By EyeFive
  • 2 Post By Karcinagin
  • 1 Post By New Z71
  • 1 Post By Bwilliams1848
  • 1 Post By SigArms
  • 1 Post By Garrettb189
  • 1 Post By Janster
post #1 of 10 (permalink) Old 03-20-2017, 04:27 PM Thread Starter
Just did the Rough Country Level and put on 18x9 18mm Offset with 265/65R18's.
couple of things are noticeable.
The rear axle appears to stick out on the right side about 1" further than the left.
There is also a difference of height from the left side to the right side. I did not measure before the lift so I'm not sure if the variation was there prior to adjusting the height.
With all four tires at 35PSI the center measurements are as follows;
LF 36 15/16 RF 37 9/16 +5/8"
LR 36 5/16 RR 37 1/16 +3/4"
Is this normal "within tolerances" or did the lift exaggerate this? Vehicle doesn't show any adverse handling characteristics.
FlynJRacer is offline
post #2 of 10 (permalink) Old 03-20-2017, 04:41 PM
EyeFive's Avatar
Im 3/8" lower on driver's front and back.
mexica and FlynJRacer like this.
EyeFive is offline
post #3 of 10 (permalink) Old 03-20-2017, 07:58 PM
Karcinagin's Avatar
My stock 2015 is 1in lower in the rear on the driver side then the passenger and I don't even have 25k on it yet. I plan on taking it into the dealer soon.
slimsailor00 and FlynJRacer like this.
2015 Colorado Z71 CC LB 4x4 Black
Nav, Bose, Tow
Is your truck lifted, have aftermarket wheels or tires?
Please fill out this survey to help build a database of what fits our trucks.
To view the results click here.
Karcinagin is offline
post #4 of 10 (permalink) Old 03-20-2017, 08:14 PM
My '16 is 5/8" lower on drivers side - front and back.
FlynJRacer likes this.
2016 Colorado Z71 4x4 CCSB Cyber Gray
Bak MX4
New Z71 is offline
post #5 of 10 (permalink) Old 03-20-2017, 08:35 PM
Mine is .5 inch lower on the driver side front and rear.
Bwilliams1848 is offline
post #6 of 10 (permalink) Old 03-20-2017, 11:06 PM
SigArms's Avatar
There's a dealer bulletin on this already. But no fix as of yet. I have it too.
I am trying to build a fix for it now as chevy seems not to care.
Rig: 16' Colly LT 4x4 2.8D, short bed, G80, Bose, etc
Built list: Bak revolver x2, premium Line-X, rigid b/up lights cut & mounted in bumper, kn insert air fltr, zroadz fog plate w/rigid spots & floods, d-max tuner, matte blk badges and custom diesel badges
To/do: N-Fab runners, bilstien 5100 RHA 2" lift with rear 1" gm lift blks, dry cold air intake, puddle leds, 275/65-18 TA ko2 on helo 904s w/ 0 offset, Anzo headlights and tails
Sponsors: Virginia Line-X (Ant), Alt Mana.
SigArms is offline
post #7 of 10 (permalink) Old 03-20-2017, 11:48 PM
Garrettb189's Avatar
Not sure if any of you have tried this yet but I loosened the rear leaf spring end bolts and then bounced the truck pretty hard (my dad and I bounced on the rear bumper), his idea, then tightened the bolts.
It worked to get rid of the lean on my truck, it seems that the rear springs were either tightened while the truck was not sitting level or that the bushings twisted during transport.
'16 EC LB 3.6L V-6
2" RC leveling kit & 1.25" RC body lift
Airdam delete
Raptorliner DIY bedliner
Method Grid Wheels -Special Thanks to JT@Bajakits with stainless beadlock bolts
Falken Wildpeak AT3 265/70/17
NFAB W2W nerf bars/steps
OEM fog light kit
OEM fender flares
As soon as $$ permits...Bajakits Upper A-arms and King coilovers and rear shocks.
Garrettb189 is offline
post #8 of 10 (permalink) Old 03-21-2017, 07:16 AM
EyeFive's Avatar
just the drivers? or both sides?
EyeFive is offline
post #9 of 10 (permalink) Old 03-21-2017, 07:20 AM
Janster's Avatar
It could be they're over torqued from factory....When they're over-torqued, they can't flex properly and certainly can't 'settle' when its first being driven.
Recommendation for anyone - is to find out what the proper torque is supposed to be (for all bolts - main eye, and shackles) and loosen and retorque. Or ask your dealer if they can check for proper toque on the rear suspension.
www.lieblweb.com
2016 GMC Canyon
2015 Infinity QX70s
Janster is offline
post #10 of 10 (permalink) Old 03-21-2017, 08:26 AM
+1 on loosening and retorquing the spring bolts. It appears there's some binding in the bushings. Mine was about an inch off side to side when I got it but had worked itself to about 5/8 inch difference at 5000 miles. Redoing the bolts fixed the problem. And yes, you do both sides. Just for the record, Chevy says less than 1/2 inch difference is within specs.
Crock is offline
