Bose "Premium Audio" Specifications (including door panel removal beginning Post #31)
Specs on the 7 speaker Bose system.
Here's what I have so far; (Credit mostly goes to: kemit, jeffdawgfan, and yakcam41):
TRUCK: 2015 GMC Canyon, with Bose speakers, amp, and Navigation
RPO Codes (these are option codes used by GM to identify your system):
IO6 and UQA. IO6 describes our "infotainment system" with Nav, and UQA is our speaker system (premium audio branded with amplifier)
DASH: 3" speakers on each side, not true tweeters at all, but two-ways mid/highs instead. Must pull away a-pillar molding and then remove upper dash trim piece (use force to unclip), then use 7mm socket for bolts. Be careful of wire to little red sensor in center dash. Also, don't forget to reconnect said little red sensor wire (thanks jeffdawgfan).
FRONT DOOR: factory non-standard 6"x9" (low freq only, from amp). Use speaker adapter Metra 82-3004 to fit standard sized 6x9's. Or you can use Metra 82-3005 to convert down to 6.5 rounds. Also, to replace, do not completely remove the door panel! Just remove the screws, fronts have 5, rear has 4, then just one screw on the speaker plus a friction clip (thanks goes to kemit, below). Leave the panel hanging from the top, because of difficulty during reassembly (and why perform unnecessary work?).
REAR DOOR: factory non-standard 6" round, can fit up to 6.75" round. Speaker adapter for the rear is Schoshe SAGMHR-634. To replace, do not completely remove the door panel! Just remove the screws, fronts have 5, rear has 4, then just one screw on the speaker plus a friction clip (thanks goes to kemit, below). Leave the panel hanging from the top, because of difficulty during reassembly (and why perform unnecessary work?).
FACTORY AMP PLACEMENT, SIZE: 7 ch amp, behind glove box, to the right of cabin air filter. Non-bose has no external amp, but does have a "4-channel box" behind radio display.
FRONT/REAR DOOR SPEAKER HARNESS: Metra 72-5600. Although it says 98-up Ford, it fits (verified by Kemit; also, see his info below, with pics, on the easy way to get to the speakers).
FRONT DOOR SPEAKER ADAPTER FOR STANDARD 6X9's: Metra 82-3004
FRONT DOOR CONVERT TO BETWEEN 6" AND 6.75" ROUNDS: Metra 82-3005
REAR DOOR BETWEEN 6.5" AND 6.75" ROUNDS: Schoshe SAGMHR-634
GENERAL INFORMATION:
- Audio out from behind the stereo travels over the MOST (Media Oriented Systems Transport) communication bus. It is NOT analog, unfortunately
- Audio out is the rightmost, small gray harness behind stereo
- Audio in to amp is topmost brown harness on amp (passenger floor board)
- Audio out from amp is both the 16-pin green harness (nearly all speakers), and bottommost 8-pin black harness (just the front doors)
- See pics below for more info
