Backup Lights Installed - Chevy Colorado & GMC Canyon
 6Likes
post #1 of 29 (permalink) Old 09-05-2015, 08:51 PM Thread Starter
savagebob's Avatar
Experimenting with a backup lighting solution for secondary roads, trail riding, and anything else my 2wd will endure.
Rigid has a new series SR-M small aux light that is available in a diffused, flood, and spot version. The diffused is listed as a back up light, so that is what I purchased.
Amazon.com: Rigid Industries 98001 SR-M Flush Mount Diffused Back-Up Light Kit: Automotive Amazon.com: Rigid Industries 98001 SR-M Flush Mount Diffused Back-Up Light Kit: Automotive
This is a complete kit with relay, harness, switch, stainless hardware, etc. and is really the best quality LED lighting on the market in my opinion. I do this kind of work for a municipal public safety dept and I have used just about all of the major lighting suppliers products. These lights are also available with other mounting brackets and configurations. The flush mounts do require that you create a cutout in the location you wish to mount them.
In the other extreme, I attempted to find a cheap, Chinese LED that would be useful, but likely not a long term performer. This is what I decided on.
http://www.amazon.com/Signstek-Headlight-Waterproof-Dustproof-Shockproof/dp/B00GLLW3AM/ref=pd_sim_263_5?ie=UTF8&refRID=173HBZDYR9CGGVS0KBRY&dpSrc=sims&dpST=_AC_UL160_SR160%2C160_ http://www.amazon.com/Signstek-Headlight-Waterproof-Dustproof-Shockproof/dp/B00GLLW3AM/ref=pd_sim_263_5?ie=UTF8&refRID=173HBZDYR9CGGVS0KBRY&dpSrc=sims&dpST=_AC_UL160_SR160%2C160_
They are only 20 dollars for the pair so I did not expect much. Some of the nuts and bolts were not quite usable (really bad threads) so I could only mount 1 of the lights today until I go shop for some hardware. In a power up test in the shop they appeared to throw a decent light intensity and pattern. I chose to mount these in the bumper step pocket where I could just swivel them from a straight back aim to a 60 degree (to the side) point. Should make up for any shortcomings in pattern created by the placement of the Rigid lights in the bumper.
I will mount the left step pocket light when I find suitable hardware to replace the substandard stuff that was in the package. It will be a few weeks before I run power to the lights so I can't tell you how they perform on the vehicle. I may also add some silicone RTV to the cheap lights around the cable entry point just in case... I do like the versatility of this location because it allows you as much side coverage as you need. The bracket mount version of the same Rigid SR-M light might be a better fit in this location since the Signstek lights are a little long in that location. Functional, but some may not care for the look.
As you can see in the pics I slipped with the die grinder and scarred the paint on the right side. I did have it all covered with tape, but it broke through. That is ok, since I like the idea of having the bumper repainted for corrosion resistance anyway after all the cutting and raw edges exposed. You could just brush touch up the edges of the hole if you are careful with the cut.
If you decide to buy the 20 dollar lights, be sure to get the flood beam (or a diffused beam if available) The spot beam will not work well as a back up light.
TexazReece and Keveldinho like this.
savagebob is offline
post #2 of 29 (permalink) Old 09-05-2015, 09:03 PM
wildwest450's Avatar
You must put a lotta miles on in reverse, looks good.
wildwest450 is offline
post #3 of 29 (permalink) Old 09-05-2015, 09:29 PM Thread Starter
savagebob's Avatar
Have about 20,000 lumens in the front (30" lightbar and headlights) so I don't want the rear to get short changed. Wish these were like 1970's cars where you could subtract mileage from the clock in reverse.
(I swear I ran into a vehicle that did that way back....)
matt2858 likes this.
post #4 of 29 (permalink) Old 09-05-2015, 09:43 PM
team helotes's Avatar
I wanted the flush Rigids but I did not think the black would look good on my chrome bumper. I drilled and tapped 2 hole in the receiver and mounted them there. These are the cheap eBay ones. When they crap out I will replace with Rigids. I just pulled the power for mine off of the trailer backup wire.
I also replaced my factory backup bulbs with red/white Feniex Cannons. They are set steady burn white for 1 more for back ups, steady burn red for extra brakes and r/w flashing for warning.
team helotes is offline
post #5 of 29 (permalink) Old 09-05-2015, 09:48 PM
A+ for effort, looks good. Personally. . A little overkill, I always got away with one good set that lit up the rear sides so I can see where my rear tires were heading. Wonder what type of image the rear camera will pick up.
Xcanuk is offline
post #6 of 29 (permalink) Old 09-05-2015, 09:50 PM Thread Starter
savagebob's Avatar
Originally Posted by team helotes View Post
I wanted the flush Rigids but I did not think the black would look good on my chrome bumper. I drilled and tapped 2 hole in the receiver and mounted them there. These are the cheap eBay ones. When they crap out I will replace with Rigids. I just pulled the power for mine off OD the trailer backup wire.
Nice job. I just wanted to get the lights up a little higher. Do the Cannons mount through a 1" hole cut into the side of the factory light housings, or are they a direct bulb replacement? I might have to get some Canyon tail lights since the Colorado ones have a teenie tiny back up light window.
post #7 of 29 (permalink) Old 09-05-2015, 09:57 PM
They are a 1" hole. I just drilled out the factory hole to 1" and installed them, no going back to factory bulbs now. They are super bright. I went with the 120s they shine all the light straight out the back and do not use the factory reflector.
post #8 of 29 (permalink) Old 09-05-2015, 10:03 PM
If you are getting the bumper repainted take apart the Rigid and get the bezel painted to match. I did it on the ones in the front bumper of my Siverado and it looked better, but my bumper was blue.
post #9 of 29 (permalink) Old 09-06-2015, 12:12 AM Thread Starter
savagebob's Avatar
I was thinking of doing that. I might even try grinding off the Rigid logo and smoothing out the cast bezel. I just ordered 1 pair of Cannon 120 in red/white for the back with the tail brake backup feature. And another pair of Cannon 360 for fog lights in white/amber with same feature for those times when I need to stop in traffic to assist a dead vehicle. Have a work Silverado 2500 HD but still have been called out after hours and used my truck.
I am also going to wire all 4 reverse lights through a flasher to add to the rear warning lights. Guess I need to go price some Canyon tail light housings.
I am going to start using Feniex products more often for our builds. We have been using Whelen exclusively, but I am not satisfied with a few of their products. I like the Feniex 4200 control system for major projects. They are a very innovative company.
post #10 of 29 (permalink) Old 09-06-2015, 11:01 AM
Looks great!
NEW TRUCK
OLD TRUCK
5inch CST lift
goleee33 is offline
post #11 of 29 (permalink) Old 09-08-2015, 01:16 PM
Canyon 2005 Owner's Avatar
A question regarding replacing the "original" backup bulbs. I feel that the light amount, when in reversed, is very low. I'm sure it's my 67 year old eyes but I do have trouble seeing the driveway when backing up. The rear view camera (the stock camera on my WT on the small 4" screen) is not very clear either. I know that the 2005 Canyon I had seemed to be a lot easier to see just using the two outside mirrors backing into the small area that I park my Colorado. I see that many people have replaced lights with LED but that also means some wiring changes and I'm lost when it comes to "stuff" like that. Are you aware of any backup bulbs that are brighter and I could just remove the old ones and replace with the brighter ones. Thanks for your help
Now the proud owner of a 2015 Colorado WT--- so in other words, I don't know how to edit my Screen name
Canyon 2005 Owner is offline
post #12 of 29 (permalink) Old 09-08-2015, 01:36 PM
Look at this thread.
http://coloradofans.com/forums/130-d...all-video.html
post #13 of 29 (permalink) Old 09-08-2015, 02:14 PM
I have the MYLINK large screen, and I find my Canyon backup lights work great with the camera. The interesting thing I have see is going from outside, backing into the garage, the camera seems to hesitate a second before adjusting to the light differential. In daylight, it has to adjust in one direction, at night, my garage door opener puts out a fair amount of light, so it is actually trying to adjust to an increase in light from the door opener and the reflection off the white walls of my garage.
post #14 of 29 (permalink) Old 09-08-2015, 02:23 PM
ADMIN
Blue15ColoradoLT's Avatar
LEDs are straight replacements. Since you do not need resistors, just find some quality 921 LED bulbs and you're good to go.
2015 Laser Blue Colorado LT
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED license plate lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Canyon swapped tail lights
Red painted calipers
Supermod ported throttle body
Silver metallic rally stripes
Super Skidz skid plate
Volant CAI
***NOTE***
SITE RULES
Blue15ColoradoLT is offline
post #15 of 29 (permalink) Old 09-08-2015, 02:37 PM
Being old school, I still use my mirrors thru tinted windows, and changed mine out to high output LED's. It is easy, as you don't need any resistors or capacitor stuff to make work. But I will tell you that taking out the lenses the first time, it truly sounds like you broke them when those clips release.
post #16 of 29 (permalink) Old 09-08-2015, 02:41 PM
Thanks all
Good to know that it isn't the big deal that I was thinking it was - rewiring and such.
(1 side question - the video said to check for polarity...with a gauge?)
post #17 of 29 (permalink) Old 09-08-2015, 02:44 PM
ADMIN
Thanks all
when it comes to plug and play LED bulbs, plug the LED bulb in, and if it doesn't work, take it out, flip it 180 degrees and plug in again. No gauge needed.
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Volant CAI
***NOTE***
SITE RULES
post #18 of 29 (permalink) Old 09-08-2015, 02:58 PM
ahhhh guessing no markings ( + / - ) to hint which way....
Going to be a bit tough to put in reverse (manual shifter on my truck) and see if they come on when you are the only one around lol
(will have to wait till dark to give it a try)
late edit... Wait.... Could I keep the engine off and just put it in reverse and see it lights up?
post #19 of 29 (permalink) Old 09-08-2015, 03:24 PM
ADMIN
yes you can.
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Volant CAI
***NOTE***
SITE RULES
post #20 of 29 (permalink) Old 09-08-2015, 04:27 PM
chevygal68's Avatar
I'm going to install tailgate LEDs. 5 way that includes back up. Gonna have to order because they only keep the 60" in stock for FS PU.. I will post pix in my garage when install them.
Luvin' my 2016 Colorado.
HiHo HiHo its off to work I go.
Muffler Tip, Tinted Windows
Window Deflectors, 3M Defender
IronCross nerf bars, Rough Country level/lift, MT MTZ P3, Bakflip tonneau
chevygal68 is offline
