How To: DRL Delete (2nd Gen) - Page 3 - Chevy Colorado & GMC Canyon
 31Likes
post #41 of 56 (permalink) Old 08-12-2016, 05:56 PM Thread Starter
bigboi98's Avatar
Bump for any of the new members
Sent from my SM-G920V
badandy519 likes this.
bigboi98 is offline
post #42 of 56 (permalink) Old 11-21-2016, 09:50 AM
sabbotage's Avatar
Send a message via AIM to sabbotage Send a message via MSN to sabbotage
Is there a click between off and auto once the spring is removed so the switch stays locked in place like it is for the other modes? Just curious. :)
2016 GMC Canyon All-Terrain Duramax
sabbotage is offline
post #43 of 56 (permalink) Old 11-21-2016, 10:45 AM
I went threw this whole process only to find out our Canadian trucks have DRL on the low beams that come on as soon as I take the truck outta park. ?
CanyonTO is offline
post #44 of 56 (permalink) Old 11-21-2016, 11:40 AM
Not really no. But it stays in the off position fine.
In Canada aren't DRL required by law? In the US they aren't
P.S. FART
lqdchkn is offline
post #45 of 56 (permalink) Old 11-21-2016, 12:33 PM
sabbotage's Avatar
What about the auto position? Is the switch tight enough that it will stay in auto after hitting a few bumps or something? I was just hoping it wouldn't slide back to off on it's own
post #46 of 56 (permalink) Old 11-21-2016, 01:42 PM
P.S. FART
Duh stupid Newfie here.. yes they are required by law.. here we have some stupid drivers so they have to make certain things law
CanyonTO is offline
post #47 of 56 (permalink) Old 11-21-2016, 02:26 PM
Off has no detent (click, snap, lock whatever you want to call it) that I can really feel but the dial will stay there. The dial stops and stays in all positions fine. I'm not sure how much clearer we can make this.
Worst case, if you don't like it you can put the spring back in as long as you don't break something taking it out, or buy a new switch, or post up here to swap with someone that wants to do this but hasn't.
You have options man, some of them may be pricier to you but this isn't going to be the end of your truck
lqdchkn is offline
post #48 of 56 (permalink) Old 11-21-2016, 03:07 PM
sabbotage's Avatar
I wasn't trying to be difficult. I was just genuinely curious.
I think I may do this for the sake of possibly swapping to HIDs in the near future. I'd like to see the LEDs in my headlights of my canyon be the DRLs instead of the headlights. I may have to look into swapping that somehow.
post #49 of 56 (permalink) Old 11-21-2016, 04:15 PM
Lol my bad if that came off as "snarky" was just trying to be literal
lqdchkn is offline
post #50 of 56 (permalink) Old 11-22-2016, 06:49 AM
poconojoe's Avatar
I thought there was a setting to turn off the DRL.
poconojoe is offline
post #51 of 56 (permalink) Old 11-23-2016, 02:57 PM
Dang... I was really hoping there was a wiring thing you could do to more so reroute the DRL to the ambers :P
James Bell is offline
post #52 of 56 (permalink) Old 11-23-2016, 03:55 PM
sabbotage's Avatar
Apparently there is a harness someone can make according to this post: Can I make the LED signature lights function as the DRL system?
The person who mentioned that hasn't replied what options the harness gives you as far as reverting your DRLs to the parking lights or the LED markers.
James Bell likes this.
post #53 of 56 (permalink) Old 03-15-2017, 10:45 AM
sohccammer427's Avatar
Big thanks to the op for all his replies. Have a Z71 on order and had wondered if this was doable. I'd have no issues it the drl's were separate lamps, but running the actual projector headlights at a reduced voltage I may not light.
I may or may not do it but this sounds like the only way. On the VW it's a controller setting changeable via software.
Anyhow, as far as I know my Z71 will have fog lamps, so just to add to this thread, it appears there are two switches available as mentioned. And Rock Auto does carry them.
22940469 w/o fogs
22940468 with fogs
sohccammer427 is offline
post #54 of 56 (permalink) Old 03-15-2017, 11:28 AM
22940469 w/o fogs
22940468 with fogs
Fogs lights are standard on the Z71 package.
There is a third switch also, for trucks equipped with the sport bar and off road lights.
23458495 with fogs and off road lights
post #55 of 56 (permalink) Old 05-18-2017, 02:05 PM
This thread is awesome and the reason I had to register just so I can say thank you! The auto drl was only thing that bothered me but now Im drl free lol
Lt1bandit is offline
post #56 of 56 (permalink) Old Yesterday, 07:11 PM
redbolt04's Avatar
This is the best thing ever! I run a retrofit bi xeon hid setup in my truck and it's bit happy if I forget to turn off the drl every time I drive! This is the greatest! Thank you!
Sent from my AS985 using Tapatalk
redbolt04 is offline
