Anyone Swap the key around? - Page 2 - Chevy Colorado & GMC Canyon
 60Likes
post #21 of 81 (permalink) Old 11-20-2016, 04:55 AM Thread Starter
Originally Posted by Nicolas_p View Post
That's not the same key. We'd need the 4 button key and that is also an after market key. Not OEM, we'll have way better luck at successfully getting a flip key if we go with an oem version. I would order one but the extra 15-20$ in shipping cost to get them Canada is a little crazy. I'm hoping someone down south will be able to help out and attempt it
I'm trying to do the best I can in ordering a key from the dealer if allowed. I need to bring my Minimax anyway for some maintenance. So while there I'll see what I can do about ordering a key!
310HSSV is offline
post #22 of 81 (permalink) Old 11-21-2016, 03:53 PM
jaeisber's Avatar
Interested in this...I had the separate key and FOB. I came from a proximity key before this, so even having to use the key to turn the truck on is slightly annoying. Getting down to a single FOB will help.
2016 GMC Canyon CC 4x4 AT SB Onyx Black
Westin Pro Traxx 4
Trifecta Advantage Performance Tune
American Tri-Fold Soft Tonneau
Morimoto XB LED Fog Lights
Custom LED Bedlights
Diode Dynamics Cargo/Reverse/License Plate Bulbs
Morimoto XB35 5500K HID Low Beams
jaeisber is offline
post #23 of 81 (permalink) Old 11-21-2016, 04:27 PM
Something about turning the key makes me feel like I'm one with the truck. That we are not separate. Shifting it into drive feels like the tires are my feet, the the engine and trans are my muscles. Too much? Lol. It may not be like that but I do prefer turning the key. I also prefer shifting instead of turning a knob. I really wish that they kept the column shifter but oh well. It needs to feel like a truck. I do agree about the fob and key being one piece. I'm subscribing to this thread.
Toughsox, Janster and aver3 like this.
IanDV is offline
post #24 of 81 (permalink) Old 11-21-2016, 05:20 PM
C9H13NO3's Avatar
Programming instructions ( steps how program a keyless entry remote) below
IMPORTANT: Before entering programming mode, have in possession all of the GM remote transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory if not reprogrammed during the same programming procedure. The other transmitters will not be functional until you program the transmitters again with new remote.
Keep this in mind when you bring your vehicle to the dealer or try this yourself. From what I read it is an easy process so doing it yourself may be the easier route depending on your dealer.
Air Dam delete
LED Lights/Signals
HID High/Low
RC 1" Level
aFe Momentum GT
MBRP Exhaust
Elite Catch Can
Trifecta Tune
C9H13NO3 is offline
post #25 of 81 (permalink) Old 11-23-2016, 03:01 PM
so what happened? lol I am interested in this as well.
robbpoe likes this.
James Bell is offline
post #26 of 81 (permalink) Old 11-26-2016, 09:53 PM
C9H13NO3's Avatar
I got tired of waiting and ordered the equinox key. Need to get my wheels balanced and will have them give it a try sometime this week. Apparently post 2010 requires some gm component plugged into the vehicle during programming so this can not be done at home...
Air Dam delete
LED Lights/Signals
HID High/Low
RC 1" Level
aFe Momentum GT
MBRP Exhaust
Elite Catch Can
Trifecta Tune
C9H13NO3 is offline
post #27 of 81 (permalink) Old 11-26-2016, 09:55 PM
Thank you being the guinea pig. I would have done it but customs charges on something that may work aren't very pleasant
Nicolas_p is online now
post #28 of 81 (permalink) Old 11-28-2016, 08:21 AM
plastrd's Avatar
Just a point of information if someone wants to research fobs, the FCC ID of my Canyon fob is M3N-32337100. Looking that up on an FCC ID database comes back with a registration for 314.9 MHz so any potential replacement fob will need to be that frequency. If you can get the FCC ID of the replacement before ordering you could check the frequency in advance.
2016 Canyon CC LB SLE AT, Cyber Gray
Eibach Pro Truck Sport RHA shocks leveled at 1.4", Access Vanish tonneau cover
plastrd is offline
post #29 of 81 (permalink) Old 11-30-2016, 12:09 AM Thread Starter
OKay, well. I have just received my Equinox 4button fob in the mail yesterday.. Problem is.. I bought the fob with a key that is apparently already cut.
SO! I have to add a step.. I need to order a BLANK key so i can have Chevy copy my key cut... So I can program the fob to work... Standby for results...
(I work overnights. Its hard for me to get to the dealer during operation hours) hang tight!
310HSSV is offline
post #30 of 81 (permalink) Old 12-04-2016, 12:01 PM
Laslow's Avatar
Found out a better and cheaper solution... Just attach the fob and the key together with a small bolt, spacer and nylon lock nut. The nylon washer will make the key move freely but still keeps the bolt from turning. The spacer, or larger nut, keeps the key from sticking outwards and lines up with the fob. Might not look pretty but damn it works great.
Laslow is offline
post #31 of 81 (permalink) Old 12-04-2016, 12:30 PM
ernster500's Avatar
That is AWESOME!
david.irwin.583 likes this.
ernster500 is offline
post #32 of 81 (permalink) Old 12-05-2016, 08:48 AM
Congratulations on winning the internet today! Is your system available in flat black?
Nicolas_p likes this.
Sylent_Snyper is offline
post #33 of 81 (permalink) Old 12-05-2016, 02:43 PM
david.irwin.583's Avatar
Amazing.. I want to do the same thing now! Tired of the key fob rattling everytime I hit a bump
david.irwin.583 is offline
post #34 of 81 (permalink) Old 12-05-2016, 05:38 PM
C9H13NO3's Avatar
My knee bumps the fob every time I transition to the brake. That and the fact the key sets off the alarm when you use it on the door makes this NEED to work, haha.
Air Dam delete
LED Lights/Signals
HID High/Low
RC 1" Level
aFe Momentum GT
MBRP Exhaust
Elite Catch Can
Trifecta Tune
C9H13NO3 is offline
post #35 of 81 (permalink) Old 12-05-2016, 08:57 PM
Vinolush's Avatar
Yankee Ingenuity!!
Vinolush is offline
post #36 of 81 (permalink) Old 12-10-2016, 02:51 AM Thread Starter
Haha This will be the alternative if my Equinox key fob doesn't work...
My appointment for my trucks first service is DEC 17th.. That's the day I'll be going to the parts counter and buying a blank key to copy my current key, and then hopefully finding out how to get it to program to the truck
Thank you for all for hanging around for results.
I'm just excited as you are!
310HSSV is offline
post #37 of 81 (permalink) Old 12-10-2016, 08:24 AM
Janster's Avatar
I'd been reading this thread pondering....... now you're gonna have a key that sticks out 3-4" (guess) out of the ignition (instead of just 1"). I mean....if you don't like the dangly bits, keep them separate and put the fob in your pocket.
You're idea is pretty slick! You can a least pivot the fob back and out of the way so it doesn't stick out as far.
Not something I would do (I don't mind the dangly bits) but just thought I'd mention that. GREAT JOB!!
www.lieblweb.com
2016 GMC Canyon
2015 Infinity QX70s
Janster is online now
post #38 of 81 (permalink) Old 12-10-2016, 10:23 AM
Laslow's Avatar
I agree my friend. That is why after the key is inserted into the ignition then you just pivot the fob 90 degrees so it hangs down. 3/4 of an inch is all takes from the edge of the key to the edge of the fob. I can afford that. Anyway, hope people find it useful.
Laslow is offline
post #39 of 81 (permalink) Old 12-11-2016, 06:35 PM
Morbid's Avatar
I have wondered about this since day one of getting my truck. My moms LS Equinox has the "switchblade" fob. Even the Cruze that Ive taken from the dealer twice while my truck was in for recalls has the "switchblade" fob. But yet, a more expensive truck and you get to here the jingle or knocking around of an old school style fob dangling from the ignition. I'll be watching this to see what happens. Meant to look into some options early on, but got caught up doing everything else appearance wise that I wanted to do. I have a local place that has done me good in the past and will beat internet pricing by 15% as long as its something they have in stock or they will match it if they have to order it.
2016 CCSB LT V6 --- Purchased Oct. 15 2015 --- LT Convenience Package --- Tow Package w/ Locking Rear Diff --- GM Black Bowties --- AVS Vent Visors --- Belltech Lowering Kit
Air Dam Mod --- Bakflip MX4 Hard Folding Cover --- Line-X Bed Liner --- 20x8.5 American Racing AR914's +15 offset --- 255/50 Nitto 421Q's
Lowering Thread: http://coloradofans.com/forums/193-2...t-lowered.html
Morbid is offline
post #40 of 81 (permalink) Old 12-13-2016, 05:42 PM
Being a true man of science...
https://youtu.be/ZyIXxs68es0
Let me know if I missed something lol I am not aware of a programming method where a machine is connected.
MugPro is offline
