Retrofit in OEM projectors - Page 2 - Chevy Colorado & GMC Canyon
 33Likes
post #21 of 108 (permalink) Old 01-27-2017, 12:41 PM Thread Starter
I forgot to note:
I am using can bus standalone adapters. They came with my Ram kit so I had to use them (They prevent bulb out warning and flicker) However If you already have a working HID kit without these then we probably do not need them.
nwscoobie is offline
post #22 of 108 (permalink) Old 01-27-2017, 01:08 PM
CliffZ71's Avatar
Send a message via AIM to CliffZ71 Send a message via MSN to CliffZ71
Originally Posted by nwscoobie View Post
They are the XB Bulbs 4500k, best part about d2s I can run the night breakers which I am thinking about ordering. But the xb bulbs perform very well
2 x Splitter: 9005 Male > 9005/9006 Female - Looks like you will need to order x2
Their website says this
(QUANTITY: ONE Splitter (Order 2x for a Pair) )
Since they bolt right in there is no need for alignment, I have a pair of new FXRs that I was going to put in my last truck but they are 3" I still would have when this same route. Considering how easy this was. I wish there was a side to side adjustment but that is GM's issue.
Definalty do it when you get a chance its so easy and the reward is worth it, You will have x4 high beams as well. I like the mix of halogen and HID for my highs.
You cant tell the difference between them, It looks like OEM. I thought about doing a red eye mod but I will wait until the weather warms up.
Cool, Thanks, so if i am getting the whole set up starting out fresh, i dont need the Amp to D2S adapters right?
2016 Summit White Colorado CC Z71 window tint, bug deflector, magnaflow muffler, zone 1.25 level,air dam delete, weather tech no drill mud flaps, Husky floor liners, A.R.E topper, Baja Designs Squadron R Sport amber LED fogs, Morimoto 4TL-R Bi-Xenon projectors, 35W D2S 5500 bulbs
CliffZ71 is offline
post #23 of 108 (permalink) Old 01-27-2017, 01:39 PM Thread Starter
That is correct you can buy ballasts with the D2S adapters which is the standard.
If you are buying a kit fresh this is what you want:
The Honda Accord Retro-Quick kit is everything you need. I didn't have a relay available when I installed, but mine works without, If I had the option to get one I would just for comfort
https://www.theretrofitsource.com/co...C47309%2C48188
evoxse likes this.
post #24 of 108 (permalink) Old 01-27-2017, 05:37 PM
CliffZ71's Avatar
Thanks man, what about the can bus standalone adapters, should i get and does Morimotto carry them
CliffZ71 is offline
post #25 of 108 (permalink) Old 01-27-2017, 05:42 PM
CliffZ71's Avatar
Am i reading that right, the whole kit is only $150 with the optional stuff included? Priced out seperately it comes out to $295!
CliffZ71 is offline
post #26 of 108 (permalink) Old 01-27-2017, 06:05 PM Thread Starter
I think you would be ok without the can bus adapters, considering lots of people are running the plug and play kit without any issues. Just the relay harness would be a good idea.
Well the price for all that is about 320.00 the projectors alone are 150.00 for the pair. Its fairly inexpensive if you compare to the labor involved in a more advanced retrofit. Some places will charge 700+ alone for labor. Since you can get away with 300ish it is a steal. If you like premium headlights they are not for everyone.
post #27 of 108 (permalink) Old 01-27-2017, 06:54 PM
Are the high beam splitters necessary, since both high and low beams already fire during high beam usage?(only fogs turn off)
post #28 of 108 (permalink) Old 01-27-2017, 09:13 PM
CliffZ71's Avatar
Ok, so then I'll add the harness with the relay(s) and I should be good, yes? I have the parts I need in my shopping cart on the Morimoto web site. I need to get the harness for the D2S bulbs correct? Thanks for all of your help with this. This is something I think I could do myself. By the way, nice looking truck!
CliffZ71 is offline
post #29 of 108 (permalink) Old 01-27-2017, 09:58 PM
CliffZ71's Avatar
I'll just get the kit, it has everything I need. Seems to be the best bet. Like you said, it pays to have a good set of lights that are done correctly, for $320 you really cant beat that. You haven't had any problems or issues upon delivery or during the time that you had them?
CliffZ71 is offline
post #30 of 108 (permalink) Old 01-27-2017, 10:03 PM
bulldawg449's Avatar
Argh! I'm doing it! I literally just ordered some new ballasts and bulbs, but it looks like I'll just be eating the cost of the bulbs for now. Next weekend will be a project weekend with a brush guard and fitting these pups in.
RatRacer likes this.
2015 Red Hot Colorado Z71 2WD Crew Cab
Purchased 8/4/2015
Mods: Morimoto 4TL-R Bi-Xenon Projector Conversion, Morimoto D2S 35W 6500K HID Lows,
Morimoto XB LED Fogs, Black LT Wheels, Anzo LED Tail Lamps, OEM Black Bowties, Air Dam Delete,
Westin Sportsman Grille Guard (Black)
bulldawg449 is offline
post #31 of 108 (permalink) Old 01-27-2017, 10:15 PM
Suckah!
(my carts full, pending splitter necessity info)
bulldawg449 likes this.
post #32 of 108 (permalink) Old 01-27-2017, 10:23 PM
Suckah!
Splitter shouldn't be necessary. Power should still pass through as normal since the truck's computer dictates that.
Purchased 8/4/2015
post #33 of 108 (permalink) Old 01-27-2017, 10:29 PM
Where's Black Friday when ya need it...
post #34 of 108 (permalink) Old 01-27-2017, 11:21 PM
CliffZ71's Avatar
Do you think it will be easy removing the stock projectors for this set-up? I haven't thought of doing this before but hey, what the heck right? Let us know how it goes with the removal process, good luck.
CliffZ71 is offline
post #35 of 108 (permalink) Old 01-27-2017, 11:25 PM
CliffZ71's Avatar
No kidding
RatRacer and Grey16Ziti like this.
CliffZ71 is offline
post #36 of 108 (permalink) Old 01-28-2017, 11:36 AM
Well, since @nwscoobie says that it will take a little effort to get the OEM projectors out, I imagine the biggest hurdle is working any brackets out while you're pulling the projector out. I've done a retrofit on my prior HHR and if it doesn't involve cracking open the housing then I'm all for it and I know the effort will be worth it. I figure once I get one out, the other will be much easier. Getting the bumper/housings out will probably be the biggest pain.
Purchased 8/4/2015
post #37 of 108 (permalink) Old 01-28-2017, 11:51 AM
CliffZ71's Avatar
Unhappy
To me the bumper doesn't look that bad to do, however, the fender flares I have will suck being held on with tape and all. Guess I'm on the lookout for a good 3M tape. The stock projectors coming out will probably take a bit of wrestling, but with a little luck, maybe not be so bad. I'm ordering my setup next week so I'll have it for when the weather starts to warm up. My biggest worry is the possibility of new parts being put in then something not working correctly
CliffZ71 is offline
post #38 of 108 (permalink) Old 01-28-2017, 12:06 PM
Hmmm do I want to be the one to try it on my canyon...should be the same projector right?
rich7930 is offline
post #39 of 108 (permalink) Old 01-28-2017, 03:35 PM Thread Starter
Suckah!
Splitter is only for the high beam selonid in the new projector it sends a signal to open the shield down to enable the high beam function. The splitter just makes it a plug and play so you dont have to splice into your high beam wires, for the extra 5 bucks its well worth it.
that 25% would look pretty good right now huh, also google TRS codes or ask them on facebook sometimes they will give out one.
I will post a picture
I will post a picture of the projector to show how to split it apart in the housing to remove very painlessly
Taking out the projectors will take about 3-5 minutes for the first one and 30 seconds for the second one. There are three screw holding the projector to the housing, remove those 3 and the projector will move freely. Also you will need to use the level adjustment for the headlight to get to the top screw easier you will see when you try and remove it.
There is a little plastic retainer on the projector that you can pop off in the headlight and the projector can come apart in the housing making it a breeze to remove. I learned this on the second headlight.
Yes they should be identical, a guy on another forum sent me a picture on a canyon headlight and it looked the same, I cant guarantee it 100% since I have a Colorado
post #40 of 108 (permalink) Old 01-28-2017, 03:47 PM Thread Starter
The circles are the 3 screw locations and the star is the tab you can easily pop off in the headlight, best I could do.
VFRLuke, RatRacer and bulldawg449 like this.
