Swapped OPT7 to Cyclops LED headlight bulbs - Page 3 - Chevy Colorado & GMC Canyon
 57Likes
post #41 of 166 (permalink) Old 03-01-2017, 09:01 AM Thread Starter
Originally Posted by Damn True View Post
Just poked around a bit under the hood to see what might be involved in this. Drivers side is easy, the headlamp housing access ports are wide open. Passenger side...not so much. There's this odd, black rubber panel that wraps from the core support around onto the passenger side inner fender. Doesn't look like it just pops out easily.
Originally Posted by Shawn Cargill View Post
From what I have read, I head its easier to go through the wheel well on that side. Just loosen the plastic on the wheel well you don't even have to take it all the way off.
The black panel under the hood pulls back very easily. Pull out a retainer or two, pull the hose retainer out of the panel, and just flex it out of the way.
2016 CCSB Duramax - 226hp/458tq
Tuned by Innovative Diesel
onebaddz is online now
post #42 of 166 (permalink) Old 03-01-2017, 01:44 PM
Cool. Thanks! I was just looking at it last night in the dark with a small flashlight. I didn't want to muck around with it at all till I got some more information....which you just provided.
Appreciate it.
....I've only upgraded lighting once on a vehicle. An IPF kit for my old XJ (thus far the easiest and best documented vehicle upgrade I've ever done...if they had something for my Canyon, I'd buy it just out of loyalty, but they don't) to upgrade the sealed beam headlamps to H4.
So forgive the simplicity of this but...... between the H11 and 9005...which is the low/high beam?
Damn True is online now
post #43 of 166 (permalink) Old 03-01-2017, 03:18 PM
Appreciate it.
H11 low and 9005 high I believe.
papasmurf1958 likes this.
Shawn Cargill is offline
post #44 of 166 (permalink) Old 03-01-2017, 04:15 PM
Correct
post #45 of 166 (permalink) Old 03-01-2017, 05:30 PM
kaiser67's Avatar
FYI 9005 will just about always be for a high beam and are very popular for that on a lot of different cars. They do not have a 'cap' on the bulb which allows the light to spread 360 and straight out. A 9006 is essentially the same bulb but with a cap that used to popular for low beam. The H11 is similar, capped bulb.
2016 Red Rock LT CC SB v6 4x4
My build thread
Front bumper removal How-To
Rear Shock/lift Blocks How-To
kaiser67 is offline
post #46 of 166 (permalink) Old 03-01-2017, 05:45 PM
monkeyracer's Avatar
Go to TRS, and see how much for their 2 Stroke LED pairs vs Cyclops individuals...
For those that are too lazy to do that:
Cyclops:
H11 LED's = $64.95 x 2 = $129.90
9005 LED's = $64.95 x 2 = $129.90
Total = $259.80
Morimoto 2 Stroke from TRS:
2 Stroke LED's with H11 Adapter and Anti-Flicker Links = $115 + $5 + $15 = $135
2 Stroke LED's with 9005 Adapter = $115 + $5 = $120
Total = $255
The morimoto's are actually a few bucks cheaper.
Great review though. I plan to use HIDs for the Lows and LEDs for highs.
RatRacer likes this.
monkeyracer is online now
post #47 of 166 (permalink) Old 03-01-2017, 05:48 PM Thread Starter
Agreed. 9006 low and 9005 high is the most common setup I've ever seen until around 2007 when I started seeing more H11 low and 9005 high vehicles. The H11 lows are IMO superior to all of the older 9006 low setups.
I haven't taken a picture yet, but the Cyclops 9005 LEDs in my high beams are downright outrageous. If you forget to turn off your high beams when someone passes you the other direction you might just x-ray them it's so bright. I've never seen anything like it.
kaiser67 likes this.
post #48 of 166 (permalink) Old 03-01-2017, 11:27 PM
Well apparently IPF doesn't make a vehicle specific kit for the Canyon....but apparently it's not as involved a swap as the XJ kit I previously described and doesn't require it.
They have a 9005 analog: ///IPF? 351HLB LED HEAD LAMP CONVERSION KIT
and an H11: ///IPF? LED HEAD LAMP CONVERSION KIT
Any input from those of you with experience with these things would be appreciated. Like I said, I have purchased from them in the past and been really pleased...but if the Cyclops is a superior technology I'll go that route.
post #49 of 166 (permalink) Old 03-01-2017, 11:31 PM
KMW
KMW's Avatar
The poor Chinese to English translation on the Web site scares me a little! Gives the impression of a low end Chinese knock off company. But that's just based on past personal experiences.
KMW is offline
post #50 of 166 (permalink) Old 03-02-2017, 12:20 AM
IPF is a Japanese company. Apparently founded in 1946 and a supplier to a number of JDM mfr's and the global aftermarket.
post #51 of 166 (permalink) Old 03-02-2017, 09:07 AM
I've got the 2stroke lows...
They are pretty good, they have pretty noticeable hot spots tbh. My highs are from my WRX and look great. Now on to the fogs!
16_MidnightRider is offline
post #52 of 166 (permalink) Old 03-02-2017, 09:54 AM Thread Starter
IPF looks like it's double the cost of the Cyclops, which is insane. I haven't tried them, but there is no way they are double the light or quality. Cyclops is the only one I've found that has proven to be worth a premium over basic Amazon $60 bulbs. IPF might be just as good as Cyclops, but I can't see any reason why any LED bulb would be worth the $195 IPF wants.
post #53 of 166 (permalink) Old 03-02-2017, 10:46 AM
kaiser67's Avatar
I just ordered a set of Lumens G7s that came up to about $58 per bulb. 5 yr warranty doesn't sound bad.
I'll see how they do, albeit will be in a reflector lens instead of projector.
My build thread
kaiser67 is offline
post #54 of 166 (permalink) Old 03-02-2017, 11:34 AM
I wonder if there might be a difference predicated on the fact that IPF is also a supplier to JDM? OE quality housings and such? No idea though if the Cyclops product is of that level or if the delta between the two justify the delta in pricing.
post #55 of 166 (permalink) Old 03-06-2017, 08:19 AM
My install / demo video of the Cyclops LED bulbs :)
Passenger side added 30 mins due to all the stupid paneling but wasn't too bad. I might do fogs over highbeam next since I have the light bar installed.
Vinolush, Alymik1 and bpm2425 like this.
lusid is offline
post #56 of 166 (permalink) Old 03-06-2017, 10:14 PM
fondupot's Avatar
This is going to be my first Mod I think.
fondupot is online now
post #57 of 166 (permalink) Old 03-07-2017, 09:44 AM
I went with morimoto not cyclops, but I'd recommend the MOD regardless of brand, it's worth it. Much more output than stock and looks really good while doing it.
Sent from my SM-G935V using Tapatalk
Jgigs is offline
post #58 of 166 (permalink) Old 03-11-2017, 06:29 AM
Question
DISCLAIMER. Your results and or opinions may vary...
Few questions about this terrific improvement.
> For fogs, Which Cyclops kit do I need if I would like to have either day white (5000k-5500k)or cool white (6000k-7000k) tone ?
I have halogen housing housings...
> Can I add a Cyclops kit for low?
> What about the one for high?
> if so .. which ones do I need?
Which one will produce scattered light output high or low?
Thanks!
WeztZ71 is offline
post #59 of 166 (permalink) Old 03-15-2017, 11:03 AM
DISCLAIMER.
Ok...well I'm definitely going to upgrade my lights...this may be a silly question, but what did you do with that little box that's inline between the bulb and the plug? Does it just hang in the headlamp housing?
post #60 of 166 (permalink) Old 03-15-2017, 11:07 AM
There is plenty of room in the housing to close the cover even with all the cords and metal box thingy.
lusid is offline
