Swapped OPT7 to Cyclops LED headlight bulbs - Page 4 - Chevy Colorado & GMC Canyon
 66Likes
post #61 of 200 (permalink) Old 03-15-2017, 11:42 AM
Originally Posted by lusid View Post
There is plenty of room in the housing to close the cover even with all the cords and metal box thingy.
Any need for capacitors to correct DRL flickering?
post #62 of 200 (permalink) Old 03-15-2017, 12:23 PM Thread Starter
I am not using capacitors with the Cyclops
RatRacer likes this.
2016 CCSB Duramax
onebaddz is online now
post #63 of 200 (permalink) Old 03-15-2017, 12:53 PM
My dumb ass should go back and read the first page where I asked/was answered the same question.
post #64 of 200 (permalink) Old 03-15-2017, 01:33 PM
Anybody ordering, use code ADV to get 5% off.
Should help on the shipping anywho....
Shawn Cargill likes this.
post #65 of 200 (permalink) Old 03-15-2017, 04:16 PM
Installed mine today, Hope it goes better then the HIDs
TonesGTO is offline
post #66 of 200 (permalink) Old 03-20-2017, 10:28 AM
Have to admit I'm disappointed in the light on these. anything past 15-20 feet and the light decreases dramatically.
TonesGTO is offline
post #67 of 200 (permalink) Old 03-20-2017, 10:41 AM
fondupot's Avatar
Seems different than everyone elses account of these lights in the thread.
fondupot is online now
post #68 of 200 (permalink) Old 03-20-2017, 10:57 AM
Still 100x better than halogen.
lusid is offline
post #69 of 200 (permalink) Old 03-20-2017, 11:28 AM
Send a message via AIM to haulingnothing
You might want to take a look at how your lights are aimed. I had the opposite problem of too much light because I was pretty much blinding everyone, and by adjusting the aim of the lights downward it actually makes them appear dimmer even though its just that they don't shine as far ahead.
FWIW, I have reflector headlight housings so this may not apply to those with projector housings.
muck likes this.
2016 Colorado - 2WD Extended Cab LT V6 - Laser Blue - Shoreline Edition
Plasti-Dipped badges - Air dam delete - DRL switch mod - OPT7 LED low beams - Moroso catch can - Pedal Commander
haulingnothing is offline
post #70 of 200 (permalink) Old 03-20-2017, 12:15 PM
macr88's Avatar
I think LED replacement lights still need some tweaking before they actually project the way they're supposed to.
My fog lights project a tremendous amount of light to the sides but lack that same amount of brightness for distance.
I know fog lights are different but the reviews of LED's in headlights from those who are looking for distance say the same thing.
I think if the LED was placed differently, maybe more top/bottom vs sides you'd get more distance out of them. There's no doubt that LED's will be fantastic once they get them right.
-mac
macr88 is offline
post #71 of 200 (permalink) Old 03-20-2017, 12:23 PM Thread Starter
Surely it's in how they are aimed. In my picture I would estimate that I'm about 240ft from that fence.
2016 CCSB Duramax
post #72 of 200 (permalink) Old 03-20-2017, 04:32 PM
kaiser67's Avatar
More and more LED replacement bulbs are able to adjust the position of the bulb now. By rotating where the diodes are can drastically change the pattern and output.
I just got in my Lumens G7s kit, going to put them in tonight to see how they do in the reflectors.
2016 Red Rock LT CC SB v6 4x4
My build thread
Front bumper removal How-To
Rear Shock/lift Blocks How-To
kaiser67 is offline
post #73 of 200 (permalink) Old 03-20-2017, 11:17 PM
Mine look nothing like that. Is there a way to adjust the position of the bulb?
TonesGTO is offline
post #74 of 200 (permalink) Old 03-21-2017, 12:13 AM
CliffZ71's Avatar
Send a message via AIM to CliffZ71 Send a message via MSN to CliffZ71
Neither did mine, that's why I went with the projector retro kit instead
2016 Summit White Colorado CC Z71 window tint, bug deflector, magnaflow muffler, zone 1.25 level,air dam delete, weather tech no drill mud flaps, Husky floor liners, A.R.E topper, Baja Designs Squadron R Sport amber LED fogs, Morimoto 4TL-R Bi-Xenon projectors, 35W D2S 5500 bulbs
CliffZ71 is offline
post #75 of 200 (permalink) Old 03-21-2017, 07:22 AM
You won't get a clean cutoff like that without projector housings. If you want to play around with the aim (up/down), there is an adjustment screw above each headlight. They are facing upwards, accessed through holes in the top of the radiator support.
post #76 of 200 (permalink) Old 03-21-2017, 09:02 AM
I have a Canyon so I do have projectors.
TonesGTO is offline
post #77 of 200 (permalink) Old 03-21-2017, 09:09 AM Thread Starter
I don't think so. You won't get the projector style cutoff, but aiming should help either way. My motorcycle headlight picture out of my garage above is a reflector housing. I don't know if it's just the style of the reflector housing, but even on my motorcycle it has a sort of cutoff effect that's just not quite as clean as my actual projector.
2016 CCSB Duramax
post #78 of 200 (permalink) Old 03-22-2017, 10:19 AM
Well I throw in the towel. Sending them back today.
2017 Canyon Denali Duramax 4x4
2005 Pontiac GTO
2014 Harley-Davidson Street Glide
TonesGTO is offline
post #79 of 200 (permalink) Old 03-22-2017, 10:45 AM
But he has a Canyon....which has projector housings.
Damn True is offline
post #80 of 200 (permalink) Old 03-22-2017, 11:05 AM
kaiser67's Avatar
How did you fit everything inside the dust cover? Is there a lot more room in the projectors than the reflector housings?
There's no way I can fit the relay/igniter/canbus boxes or whatever inside and I don't really want to run without dust caps
My build thread
kaiser67 is offline
