Dimensions for SubThump Boxes? - Chevy Colorado & GMC Canyon
 3Likes
  • 1 Post By monkeyracer
  • 1 Post By Prince Leslie
post #1 of 14 (permalink) Old 03-15-2017, 07:28 AM Thread Starter
monkeyracer's Avatar
I am looking to see if anyone here with a Subthump box and a tape measure can help me out.
I want to build my own box with some added features, and it would be nice to use the exterior dimensions from the Subthump box as a starting point. They don't make a box like what I would want, and it's not worth buying a box for dimensions that I am not going to use.
Thanks in advance.
Prince Leslie likes this.
monkeyracer is offline
post #2 of 14 (permalink) Old 03-17-2017, 06:38 AM Thread Starter
Bump... anyone out there want to take a crack at this?
post #3 of 14 (permalink) Old 03-17-2017, 07:13 AM
I just made a single 8 box and plan to build some features into it such as storage. It's still a work in progress. More like a rough draft. I'll post pics when I'm done.
Sent from my XT1064 using Tapatalk
boombots is offline
post #4 of 14 (permalink) Old 03-17-2017, 09:03 AM
GraniteBlue05's Avatar
Well . you're the "engineer". -- . . .. .
GraniteBlue05 is offline
post #5 of 14 (permalink) Old 03-17-2017, 09:34 AM
I can get the dimensions for you, I just don't know when I will have a chance, I probably can this weekend.
2016 CCSB Duramax
onebaddz is offline
post #6 of 14 (permalink) Old 03-17-2017, 02:54 PM
Thanks in advance.
I don't get it. Why do you want dimensions from another box if you are building your own? Unless you are using 6" woofers or something it won't be too big. Back in my car audio days we built the box as large as possible to fit where you want it. You know? Has something changed? Or are you wanting to build it just like the Subthump one for some reason?
JScottM is offline
post #7 of 14 (permalink) Old 03-17-2017, 03:50 PM Thread Starter
To be honest, it is because I have a baby seat installed right now, and don't want to take the effort of pulling that out, removing the plastic cover and metal bar under the seat to measure out what might be the right size, then reinstall everything, build the box, uninstall everything, test fit, see I made a simple mistake, reinstall everything, rebuild the box, etc. you see where I am going with this...
I figured it would be easy enough for someone to grab a few quick dimensions from the box we already know fits.
What I want to build will be a single woofer with amp space, but also maintain some storage space that I can access without having to flip up the seats (again, because of the baby seats that will be installed).
Back in my car audio days, I drove cars with trunks or SUVs/hatchbacks with cargo areas, so you could build a simple square box by just taking 3 measurements (L x W x H). The most complicated part I needed in those cars was a hinged panel that covered a storage area and provided protection for the speakers from the other items that might be rolling around in the trunk. That panel was contour conforming to the trunk wall and hinges.
Obviously with these trucks, really the only place to throw a sub and amp is under the rear seat, and since both baby seats will prevent me from pretty much ever using that space, I might as well use it for a sub box.
JScottM likes this.
post #8 of 14 (permalink) Old 03-17-2017, 04:38 PM
I don't think basic dimensions will get you where you want to be due to specific shapes you are going to have to build. It's gonna require a truck to be present.
2016 CCSB Duramax
onebaddz is offline
post #9 of 14 (permalink) Old 03-18-2017, 08:07 AM Thread Starter
The box is a prismatic shape (ignoring the inset for the subs, my box will be a little different there anyway). I would only need 7 dimensions to build the shape of the box.
post #10 of 14 (permalink) Old 03-18-2017, 06:02 PM
Darrenaoe's Avatar
PM Sent
15 Z71 Cyber Grey
Bose Nav System Upgraded w/ Kicker Speakers
Groundshaker box w/ 2 10" Rockford RDS2D Powered by Rockford Prime 500w
Tinted Windows
Chevy Soft Bed Cover
HID Headlights & LED Fog Lights
Blue Illuminated Under Seat LED
Black Running Boards
HELO HE901 18" Rims w/ Geolander 265 65r18
K&N Air Filter
Swithback Led
Corsa DB
MGP Caliper Covers w/ Bowtie Logo
Weathertech mats
AS 2.5 Kit & RC body lift
30" LED Bar Bumper Mounted
Darrenaoe is offline
post #11 of 14 (permalink) Old 03-23-2017, 12:04 PM
Prince Leslie's Avatar
Originally Posted by Darrenaoe View Post
PM Sent
Could you send me these dimensions too?
2015 Green Rado
4" RC Lift
17x8.5 Grid MR309
285/70/17 Nitto TG
Prince Leslie is offline
post #12 of 14 (permalink) Old 03-23-2017, 12:30 PM
My build has some dimensions and measurements if you need. I'm going a bit different with my route, but really its all there. My log is attached to my sig if it helps.
LansonF is offline
post #13 of 14 (permalink) Old 03-23-2017, 02:26 PM
Damn.....That build thread is very thorough. Good job on that!
LansonF likes this.
post #14 of 14 (permalink) Old 03-23-2017, 03:19 PM
Thanks man. I've learned a lot (the hard way), Subthump makes a killer box though, extracts every inch of space (and that's good.) But if you need space for equipment like I do, making custom is the way to go. I DO wish I would have used a bit more depth and width, closer to the Subthump design. Maybe I'll redo mine (for a 3rd time!) later. I just want sound again for now.
LansonF is offline
