Sirius Radio Connection - Chevy Colorado & GMC Canyon
post #1 of 5 (permalink) Old 03-16-2017, 10:25 PM Thread Starter
Old guy with a modern electronics question. About ten years ago, I owned a portable XM unit. I had mounts on my boat, motorcycle, work truck and personal truck. I had one portable unit I oved around. In those days, you unplugged the antenna, plugged the XM radio in and then reconnected the antenna lead to play the XM radio.
I don't want to pay for multiple radio connections, so I plan on installing a portable unit in my Canyon and one in my new boat. I see the new portable Sirius/XM units now come with a 3.5mm cable. Is the connection and operation as simple as plugging in the Sirius 3.5mm cable into the port on the center console, mounting the satellite antenna and plugging into power?
Thanks in advance.
Don & Mary
2016 GMC Canyon SLT Crew Cab 4WD
(Motor Home Toad)
2" Leveling Kit
Amp Running Boards
BakFlip Toneau
OPT7 LED High beams
Morimoto LED Low Beams
Diode Dynamics LED Fog
HomeLink
Electric tailgate release
Pedal Commander
Air Lift Air Bags
DonS is offline
post #2 of 5 (permalink) Old 03-16-2017, 10:39 PM
I just use my Sirius unit plugged into the cigarette port with the antenna on the dashboard. Tune in to 87.9 or 88.1 (depends on whatever you usually tune to) and your good to go.
Not sure about using the 3.5 mm since my unit has to be 5+ years old.
Hope Im answering what your question is.
Toughsox is offline
post #3 of 5 (permalink) Old 03-17-2017, 12:27 AM Thread Starter
Yes, my older unit worked that way, but required you to tap into the radio antenna (FM modulator). I'm trying to find out if the newer units eliminate the FM modulator and just use the 3.5mm jack.
Don & Mary
(Motor Home Toad)
2" Leveling Kit
Amp Running Boards
BakFlip Toneau
OPT7 LED High beams
HomeLink
Pedal Commander
Air Lift Air Bags
DonS is offline
post #4 of 5 (permalink) Old 03-18-2017, 05:12 PM
Thanks in advance.
Yes, the new units are that simple. I have one in my '16 Colorado. I used the 3.5mm jack to send the audio to the radio (select the media option on the radio). I used the 12v port on the opposite side of the console from the 3.5mm jack.
2016 Colorado
mjonesjr84 is offline
post #5 of 5 (permalink) Old 03-18-2017, 05:39 PM
Probably easier to activate it for the truck, then add on the small fee to use the app on your phone for the boat?
DrewNJ is offline
