removing lowbeam bulb without the bumper? - Chevy Colorado & GMC Canyon
 4Likes
  • 1 Post By Kurt Hasseler
  • 2 Post By GraniteBlue05
  • 1 Post By kaiser67
post #1 of 19 (permalink) Old 03-19-2017, 12:07 AM Thread Starter
Kurt Hasseler's Avatar
hey guys,
is it possible to remove the headlight bulb without removing the front end? ive changed out all my other bulbs and its pretty simple, but ive noticed the lowbeams seem to have a retention ring around them.
also, side question..i picked up a set of OPT7 LED bulbs for the low beams. they are just the bulb and not the bulb, fan, motherboard combo that usually comes with LEDs. will installing just the bulb in the headlight housing work or do i need the all that other nonsense? only dipped my toe in the world of LEDs so pardon my ignorance.
-Kurt
Big Owl likes this.
Kurt Hasseler is offline
post #2 of 19 (permalink) Old 03-19-2017, 02:19 AM
Yes. Left side is completely accessible. Right side requires removing the cold air panels. Removing the horn makes your life a lot easier.
jso902 is offline
post #3 of 19 (permalink) Old 03-19-2017, 11:25 AM
kaiser67's Avatar
You can easily change the passenger side out by just removing the small plastic shield above it with a T-25 bit. It's a little tight but manageable
Driver side is self explanatory, no problem there.
2016 Red Rock LT CC SB v6 4x4
My build thread
Front bumper removal How-To
Rear Shock/lift Blocks How-To
kaiser67 is offline
post #4 of 19 (permalink) Old 03-19-2017, 12:28 PM Thread Starter
what tool do i need to remove the metal lock rig holding the bulb in place, and what is the trick to that?
post #5 of 19 (permalink) Old 03-19-2017, 01:50 PM
Torx screw. You can get it at Harbour freight or ace hardware.
Oops. Just realized the above post already stated what I said.
jso902 is offline
post #6 of 19 (permalink) Old 03-19-2017, 03:31 PM
Blue06Colorado's Avatar
You just rotate the bulb to get it out, counter clockwise.
-2016 Colorado Z71 CC Diesel long box-
-Hardwired Valentine1-Blacksys CH-100B Dash Cam-Bed Extender-
-4TL-R HID projector retrofit w/Morimoto 50w Ballast and Osram CBI 5500k Bulbs-RC 30" LED Lightbar and Grill Mount-
Blue06Colorado is offline
post #7 of 19 (permalink) Old 03-19-2017, 03:45 PM
GraniteBlue05's Avatar
-Kurt
I'm confused. . how did you buy the OPT7 LEDs without "all the other nonsense"?
Which, BTW, is very necessary to relieve the *HeaT* that is produced for LED operation. If you remove all the heat sink, fans, etc. . . your LEDs will burn out in a hurry .. if they will work at all.
Toughsox and Pavel Arsenov like this.
2017 2WD Colorado LT V6 Luxury & Conv Pkgs, Blk/Ashen Gray Leather
GraniteBlue05 is offline
post #8 of 19 (permalink) Old 03-19-2017, 04:53 PM
You need everything, not just the bulbs. There is no lock ring, turn the bulbs and pull them out
2016 CCSB Duramax - 226hp/458tq
Exhaust
DSP4 tuned by Innovative Diesel
Lowered 3.5/4
Infinity speakers all around, Alpine 10s in Subthump enclosure
onebaddz is offline
post #9 of 19 (permalink) Old 03-19-2017, 11:54 PM Thread Starter
i have H7 bulbs to go into the anzo lights i installed on my car. so if i need the LED bezel "accessories" , am i wrong for just installing led bulbs in my fogs and high beams without the other equipment?
post #10 of 19 (permalink) Old 03-20-2017, 11:21 AM
The H7 bulbs have a metal retaining clip. Unlatch the clip and they should come out easily, maybe even fall out. Im not sure what you mean by "bezel accessories" but its not a problem installing led bulbs in the anzo housings. they should be a direct replacement. The leds may come with a fan or heatsink and those are required.
post #11 of 19 (permalink) Old 03-20-2017, 04:34 PM
kaiser67's Avatar
Yeah H7s you just push down on the tab on the retaining clip and it springs out.
My build thread
kaiser67 is offline
post #12 of 19 (permalink) Old 03-20-2017, 05:16 PM Thread Starter
ok, I should have been more clear. sorry. all makes sense.
yes, I picked up some H7 LEDs but it just came with the bulbs and not the heat sinks/fan/motherboard. so I guess these will not work. ill have to find some H7s that are "complete"
post #13 of 19 (permalink) Old 03-20-2017, 05:17 PM
Any more info on the actual led bulbs you got? Link maybe?
Sent from my SAMSUNG-SM-G930A using Tapatalk
post #14 of 19 (permalink) Old 03-20-2017, 05:55 PM Thread Starter
these
post #15 of 19 (permalink) Old 03-20-2017, 06:10 PM
I would bet that those are direct replacement. They do not appear to need an external driver or cooling. The plug inside the headlight should plug into them just as it does the halogen bulb.
With that said, you may find them inadequate for low beams.
post #16 of 19 (permalink) Old 03-21-2017, 10:43 AM
Lazerado's Avatar
I'm a little confused as to what you are doing with H7 bulbs? The 2nd gen twins take 9005s/h11 bulbs for the highs/lows and 5202 for the fog lights.
BDS 5.5" Lift with Fox Shocks
RBP 94R 18x9 with custom Laser Blue inserts
305/65R18 Goodyear Wrangler Duratracs
Lazerado is offline
post #17 of 19 (permalink) Old 03-21-2017, 10:44 AM
He has the anzo aftermarket headlights, which uses H7 bulbs for low beam.
post #18 of 19 (permalink) Old 03-21-2017, 10:48 AM
Lazerado's Avatar
ahhh... totally missed that part
Lazerado is offline
post #19 of 19 (permalink) Old 03-21-2017, 10:54 AM
kaiser67's Avatar
Yeah those do appear to be a direct replacement plug and play but with that I doubt they would be anywhere close to powerful enough for a low beam. Probably why they are listed as "Fog lights" as well.
JScottM likes this.
My build thread
kaiser67 is offline
