Factory accessory kicker sub w/Bose? - Chevy Colorado & GMC Canyon
post #1 of 13 (permalink) Old 05-17-2017, 07:21 AM Thread Starter
Smile Factory accessory kicker sub w/Bose?
Anyone have this setup?
Where is it mounted? How does it look? Pics? How does is sound?
Thanks,
Tim
Tim Larsen is offline
post #2 of 13 (permalink) Old 05-17-2017, 02:11 PM
Tim,
I purchased and installed this a few weeks ago in my truck.
Mind you I am very picky so depending on what you are hoping to achieve you may or may not be happy with the performance.
To install it you partially dissemble the rear seat in a crew cab and the enclosure which houses the sub and amp is shaped appropriately to fit under. You will lose the majority of the storage area but you can still fit a couple straps and such next to it.
I don't have any pictures currently.
As for sound... I'm not very impressed.
Being you are looking for improvements you are likely not happy with the current performance of the Bose system. The Bose system in some other GMs is much better. (Like the Tahoe)
That said, this thing will be tapping into the high level output to the front right door speaker via the harness under the driver side kick panel.
The output is heavily processed already and has terrible low frequency fall off and too much mid.
There is no frequency cutoff control or sensitivity on the sub so you are limited to the pathetic three band EQ in the HU.
I feel like there may not be any sort of cutoff at all built into the kicker, or it is set too high as it sounds like there are a lot of 100hz+ sound coming from the sub, which sounds quite muddy and some music sounds like garbage. I have the "mid" turned almost all the way down at the HU and the bass turned down quite a bit to try and combat this but it doesn't help. I am considering the purchase of a passive in line 80Hz filter and that may help, but as I consider adding filters and aftermarket processors to try and fix the shit sound I'm moving way from my ideal perfect easy solution.
My primary interest in this upgrade was that it would be the easiest option, and while that is true, I feel that I ended up with muddy heavily processed mid heavy bass.
The garbage in garbage out rule applies here so its silly to expect a miracle from a system that already has issues.
In the end, it is "louder" and will produce more bass (and more mids like it or not.)
I don't know if I would buy it again.
barfdogg is offline
post #3 of 13 (permalink) Old 05-17-2017, 03:47 PM
Thunderbear's Avatar
While I am irked, like dogg, that the bass control is limited to the tri-band EQ (not having a separate line out control is just shitty design), otherwise I really like the sub.
The vehicle specific design and the plug and play aspect of the sub was a big draw for me, as well as being a GM licensed aftermarket part not messing with warranty.
The sound fills out the 'missing subwoofer' you hear, and fairly well for an 8" sub, but the enclosure and power isn't super hard hitting like you'll get with a crafted box, and well thought out amp and sub. But for me it filled the gap just right, and the install was super easy. Definitely a good icebreaker for me on a new vehicle with trim removal and such.
Cost wise, if that's a factor, if you're buying a quality sub/amp/wiring/box, you'd hit that price point or close to it pretty easily.
vi et armis invictus maneo..
Thunderbear is offline
post #4 of 13 (permalink) Old 05-17-2017, 07:32 PM
ZR2 EMT's Avatar
Thanks,
Tim
I was hoping to install one in my ZR2, however the thought of muddy bass isn't very encouraging. As a matter of fact, I had planned on ordering it in the next day or so in order to have it available when the truck lands at the dealership. I might hold off and save my $600 until I hear the stock Bose system.
"The road goes on forever and the party never ends." - REK
"If we get a little crazy, blame it on the alcohol." - PG
"It's not the size of the dog in the fight, it's the size of the fight in the dog." - MT
"All bleeding stops eventually." - ZR2 EMT
"Stay safe! Everyone goes home." - UNK
2017 Red Hot ZR2 V6 CC SWB - TPW 5/15 - Event Code 4800 (Bayed)
ZR2 EMT is offline
post #5 of 13 (permalink) Old 05-17-2017, 07:46 PM
fsnyder24's Avatar
This is the kit from GM Parts Direct.
They have two kits
1 labeled " compatible with ALL radios"
1 labeled " NOT compatible with BOSE"
http://www.gmpartsdirect.com/index.p...atsubgrp=audio
I like mine.
For those who forget their past, are condemned to repeat it.
fsnyder24 is offline
post #6 of 13 (permalink) Old 05-22-2017, 02:00 PM
ZR2 EMT's Avatar
Bump/
So has anyone else tried the OEM Kicker system that's compatible with the Bose speakers?
ZR2 EMT is offline
post #7 of 13 (permalink) Old 05-22-2017, 02:22 PM
Originally Posted by ZR2 EMT View Post
Bump/
+1 to this request... Also, love the REK quote in your signature
2017 GMC Canyon Denali Minimax
-Ordered 10/25/16
-TPW 01/02/17 (received 12/13/16)
-Built 01/09/17
-Delivered to Dealer 01/18/17
-Picked Up 01/20/17
2015 GMC Denali HD Duramax
durtymax denali is offline
post #8 of 13 (permalink) Old 05-22-2017, 02:40 PM
Bump/
Yeah ive had it installed with the bose system since day one.
LakLakLakLak-Z71 is offline
post #9 of 13 (permalink) Old 05-22-2017, 06:38 PM
ZR2 EMT's Avatar
Thanks!
In your opinion, did adding the sub improve the sound quality enough to justify the additional $600.00 cost? Did you do the install yourself?
I'm trying to figure out whether or not to order the unit in time to install it before I even take delivery of the truck. I'd like to hear your feedback on it. Thanks!
ZR2 EMT is offline
post #10 of 13 (permalink) Old 05-23-2017, 01:38 PM
I work in a custom auto shop. Im use to hearing big sound systems. That being said i always felt the BOSE did a very good job as is but i felt it was missing the low end punch. I opted for the kicker oem sub because the price was very reasonable through my kicker dealer and the install was non invasive and very easy. Not to mention it falls under the 3/36 warranty.
In my opinion its as close to perfect as can be. It gave me the small punch i was looking for. I feel the sub should be installed outright if they opt for the bose. My only complaint is overall volume. I sometimes like to listen to my music louder than most. Other than that its perfect. A small added punch that compliments the sound of the oem system that can be heard a full volume with out distortion.
This is my first new purchase ( the truck) and i didnt want to go away from the oem sound system as much as i could. I think this will hold me over at least until the warranty is up and i wont feel bad about ripping everything out and doing it over.
post #11 of 13 (permalink) Old 05-23-2017, 03:31 PM
Bump/
I have it. It was installed by my local audio shop along with replacing the front door and dash speakers and disconnecting the center speaker. If I had it to do over I would probably skip the Kicker VSS. The replacement of the door speakers with JL Audio 6.5" subs will give you more than enough bass while new 3.5" coax in the dash will fill in the mid and highs. Then you still have the storage space under the rear seat.
Cayenne06 is offline
post #12 of 13 (permalink) Old 05-23-2017, 11:01 PM
ZR2 EMT's Avatar
Thumbs up
Thank you both for the feedback. It gives me a lot more to think about with regard to upgrading the stock system.
ZR2 EMT is offline
post #13 of 13 (permalink) Old 05-23-2017, 11:59 PM
KMW
KMW's Avatar
I'm torn on this one! I'm about 90% swayed towards getting this with my ZR2.
Sent from my SM-G930V using Tapatalk
KMW is offline
