The owners manual says that the 12V power adapters are always "ON" even with the key off and removed from the truck.... I have discovered that this is not so in my 2015 Colorado.... Works fine with the key on...But does not work with the keys removed... ?!?!
Is this something I could setup or will the dealership need to set them up in the BCM or wherever ????
Thanks for any input !!!:rtfm:
