Whats up with this? - Chevy Colorado & GMC Canyon
 3Likes
  • 2 Post By jpelectrical
  • 1 Post By savagebob
post #1 of 9 (permalink) Old 09-27-2015, 08:41 PM Thread Starter
StoopidOme's Avatar
Whats up with this?
TRIFECTA: SUPERCHARGED Chevrolet Colorado / GMC Canyon (in progress; Dec 15th 2014) - Articles - News - TRIFECTA - Home - WOT-Tuning.com
Article says in progress dec '14. Any new news on it? Or is it a forgotten project?
StoopidOme is offline
post #2 of 9 (permalink) Old 09-27-2015, 08:53 PM
HotHead's Avatar
I noticed it too and was wondering.
2016 Colorado CC SB Z71 4WD Black with Towing Package.
HotHead is offline
post #3 of 9 (permalink) Old 11-15-2015, 09:35 PM
why cant we take the TT setup off the CTS-Vsport and slap it on the Twins?
jpelectrical is offline
post #4 of 9 (permalink) Old 11-15-2015, 09:40 PM
Chief2016's Avatar
You probably could, but you would not have the same engine/performance. Different compression, head design, cam timing, etc. In fact, would probably be a good way to "blow" your engine.
Chief2016 is offline
post #5 of 9 (permalink) Old 11-21-2015, 02:31 PM
Not on a low boost application. Nice 8lbs of boost would be really nice. Plus you tune the performance into the truck. You will only blow the motor getting too aggressive with the tune. All the performance companies out there throw superchargers and turbos on high compression engines all the time and still make massive gain on pump gas.
post #6 of 9 (permalink) Old 11-22-2015, 12:29 PM
Chief2016's Avatar
This is true, but you sacrifice long term reliability. My point being all factory turbo or supercharged performance engines are engineered for the extra power/performance. Lower compression (generally), stronger crank, rods and pistons, different bearings, etc. Yes, we can put "bolt on" turbos, superchargers, etc. and keep the boost low. It is a significant performance gain, but don't expect to get the same "life" out of your engine. If you only plan on keeping your truck a couple to 3 years, go for it! And wave when you blow by me.
post #7 of 9 (permalink) Old 11-22-2015, 01:17 PM
savagebob's Avatar
You can, and then tell us how it works when you get it sorted. It would be cheaper to get the whole engine with computers and fuel system and then all the parts will be happy together.
savagebob is offline
post #8 of 9 (permalink) Old 11-22-2015, 10:03 PM
If i can get a hold of a totaled CTS-v sport i plan to do just that!!! It's time to bring the Typhoon and Cyclone back to life!!!
RatRacer and savagebob like this.
post #9 of 9 (permalink) Old 11-23-2015, 07:42 PM
savagebob's Avatar
And you could name it Katrina.
MRZ06 likes this.
