What Livernois can do for you! - Chevy Colorado & GMC Canyon
 1Likes
  • 1 Post By Livernois Motorsports
post #1 of 3 (permalink) Old 02-14-2017, 11:27 AM Thread Starter
Hey guys just wanted to pop in and let you know we are here for you and your vehicles!
Here is a little info about our tuners for you. Please let us know if you are looking for something else we are happy to help
● Fuel Mapping- The fuel map inside the ECU is able to adjust the air/fuel mix for maximum efficiency and performance in any condition.
● Boost Mapping (If Applicable)- Controlling the compressed air/fuel mixture that is entering the motor. This is done by “teaching” the car’s computer new parameters in which to work.
● Air/Fuel Management- Air/Fuel management is one of the most important factors in the combustion process. Maintaining a proper Air to Fuel ratio is crucial to getting the most out of your motor and also to prevent damage.
● Rev, Top Speed Limiters and Shifting Characteristics- By dialing in the optimal RPM range and pressures for your transmission to shift at we are extending the life of those components. We also take this opportunity to revise your top speed limiter. These modifications are made to make sure that you are able to have a long-lasting and fun life with your vehicle.
● Towing Capabilities- We amplify your vehicle’s natural ability to haul your cargo around. By accessing the parts of the computer that control performance we are able to create more power where it is needed in the low RPM ranges. You can even get greater efficiency VS stock!
● Timing- Timing is where we control when the combustion event occurs. By revising the moment this happens we are able to increase your vehicle’s performance and efficiency!
● Torque Management- Using our proprietary tuning software we alter when, where and how the computer tries to step in maintain control over your vehicle in a performance setting.
● Tire Size Alterations (Where Available)
● Axle Ratio Alterations (Where Available)
Whocares05050 likes this.
Livernois Motorsports is offline
post #2 of 3 (permalink) Old 02-28-2017, 11:48 AM Thread Starter
Call today with any questions about our product! We are happy to help.
post #3 of 3 (permalink) Old 03-16-2017, 11:38 AM Thread Starter
Get your truck tuned for the spring!
Dyno proven air/fuel adjustments Gains of over horsepower and torque on your otherwise stock vehicle Compatible with most performance packages for the 2015+ GM SUV's offered by Livernois Motorsports Transmission modifications with reduced torque management and modified shift points/firmness Greatly Enhanced throttle response Available for 87, 89, 91, and 93 octane fuel Revised Rev Limiter Revised Top Speed Limiter Read/Clear (DTC) Codes
Give us a call 313-561-5500
