Regen Intervals and noticeabilty - Chevy Colorado & GMC Canyon
 99Likes
post #1 of 246 (permalink) Old 01-15-2016, 10:09 PM Thread Starter
dmaxjr's Avatar
So you lucky owners of the 2.8L may have had or will soon be having an Active DPF soot incineration. Other than the MPG drop on instant meter in DIC do you notice any other tell tale signs of regen. All my Dmax 6.6L trucks would go thru an active regen unnoticed other than a high idle and slightly more growl from exhaust tone. What intervals are these 2.8l engines doing an active regen ? Thanks in advance .
dmaxjr is offline
post #2 of 246 (permalink) Old 01-16-2016, 11:12 AM
Send a message via AIM to Ktaylor Send a message via Skype™ to Ktaylor
Funny you mention this because my truck is in its first regen as we speak.
My observations-
I have had 2 separate messages on the DIC. They are constantly on and I can not clear them. The current one says Action Requires on top and the message says Cleaning Exhaust Filter Must Continue Driving.
I believe I have around 1,200 miles on the truck already, but I can't tell for sure because I can't change the view on the screen.
The truck keeps dinging at me like the keys are in the ignition and the door is open, but it's not. I am sure that's part of the regen notification.
I am not sitting in front of a store that I need to go into but I am not going to shut the truck off during the regen.
Regen started at 10:40 and it is now 11:10. 30 minutes and who knows how much longer.
Not good.....
Ktaylor is offline
post #3 of 246 (permalink) Old 01-16-2016, 11:17 AM
I just stepped out of the truck and out of habit shut it off. **** it! Hope I didn't screw anything up.
Ktaylor is offline
post #4 of 246 (permalink) Old 01-16-2016, 11:36 AM
Moderator
They have to have planned for this. Please keep us posted :)
lqdchkn is offline
post #5 of 246 (permalink) Old 01-16-2016, 11:40 AM
dmcdufford's Avatar
Send a message via AIM to dmcdufford Send a message via MSN to dmcdufford
I might have expected this if you do a lot of short trips but I would expect it to be very very rare. Something does not seem right?
Keep us posted.
dmcdufford is offline
post #6 of 246 (permalink) Old 01-16-2016, 11:43 AM
I started the truck back immediately after I shut it off the first time, so it has been in teen for 53 minutes now.
I just spoke with a Duramax expert and he said shutting it down during regen is ok. It just picks back up when you start it again.
Ktaylor is offline
post #7 of 246 (permalink) Old 01-16-2016, 11:52 AM
dmcdufford's Avatar
I thought I remember reading somewhere that there were two types of regens. One was the routine one when could shut the truck off and it would pick up when you restarted. The other was the situation where there were too many short trips and it could not do a normal regen and you had to keep driving it, or running it.
I would have expected the second one to be fairly rare.
We need the duramax manuals that are inbound.
lqdchkn and one2doo like this.
post #8 of 246 (permalink) Old 01-16-2016, 12:06 PM
Moderator
The 2013 duramax manual mentions only the scary things we know about regen....don't turn the engine off, don't idle for extended time during regen, blah, blah, blah but it never mentions anything about the cycle finishing if the engine is turned off.
lqdchkn is offline
post #9 of 246 (permalink) Old 01-16-2016, 12:07 PM
Ive only got 250~ miles... no regen of any kind yet, probably 50/50 city/hwy driving so far.
'16 Colorado CCLB Z71 Duramax Rainforest Green, Zone 2.75" lift/level on 255/75-17 Duratracs
Eric Roberts is offline
post #10 of 246 (permalink) Old 01-16-2016, 12:25 PM
on my 700 miles trip back from the dealer, i notice a stretch were the mileage dropped to 17 to 18mpg. No other indication. I couldn't figure out what had caused the drop, after bit the mileage went back to the high 20's like normal
Dayton likes this.
2016 Colorado 2.8 Duramax,
  • LT, Jet Black Leather, White,
  • CC, LB, 4x4, Sprayed on,
  • Bose, Navigation,
  • 2" Auto Spring Level,
  • Iron Cross HD Step
shft22 is offline
post #11 of 246 (permalink) Old 01-16-2016, 12:30 PM
dmcdufford's Avatar
This is the 2015 Duramax manual for the full size. The regen is talked about a couple of places with the information on page 9-12 being what I was talking about.
http://www.chevrolet.com/content/dam...el3rdPrint.pdf
post #12 of 246 (permalink) Old 01-16-2016, 12:37 PM Thread Starter
dmaxjr's Avatar
There is no problem with shutting down during a regen. It will pick up again and resume when parameters are met again(heat/ exhaust temp)
dmaxjr is offline
post #13 of 246 (permalink) Old 01-16-2016, 12:38 PM
BumbleZ's Avatar
My observations-
Not good.....
The tech link article in the FAQ seems to be saying you need to keep it over 30 mph continuously for around 30 minutes for the regen to work....
low-tec likes this.
Fold-A-Cover G4 Elite
Factory GMC front Mud Flaps
BigBoi Headlight Switch Mod
In the garage: 2002 Z06
BumbleZ is offline
post #14 of 246 (permalink) Old 01-16-2016, 12:43 PM
dmcdufford's Avatar
Read page 9-12 in the manual linked above. The way I read it there are a couple of types of regens. When a "normal regen" occurs there is no message and you will likely not know it is occurring. If you get the message the opening post showed, it means the system could not do a normal regan and you do need to keep running it. The third type I read somewhere is when the second does not complete and the truck will go into limp mode and the dealer has to run a special regen (or something like that).
What I am curious about is what do he do or not do that caused the message and special regen.
Esoxchaser likes this.
post #15 of 246 (permalink) Old 01-16-2016, 12:52 PM
Lots of short trips or low speed driving. I'm thinking he needs to go for a sustained highway drive.
low-tec and Daw like this.
post #16 of 246 (permalink) Old 01-16-2016, 01:03 PM
No problem at all. If it still needs more "regen", it will complete it when you start driving again.
My 6.6 LMM, I never worry about shutting off the truck during regen, nor do another 6.6 owners.
The only time starting and stopping during regen is a problem, is if you are early in the regen cycle, and do multiple short trips. On a 6.6L, at some point in time, it's going to come up with messages about the need to keep driving. DPF regen is discussed in the Duramax supplemental manual, which no one has yet.
Idling will most likely not get the EGTs high enough to complete a regen.... at least on a 6.6 it won't.
When the "need to keep driving" (not sure what the exact message is) comes up, it's time to get on the freeway if possible, and drive!
If you keep doing short trips, and the regen never completes, it will put a 6.6L in limp mode.
myusername is offline
post #17 of 246 (permalink) Old 01-16-2016, 05:13 PM
My observations-
Not good.....
That DIC message is not supposed to ever come on in normal use and doesn't necessarily mean you are currently in a regen. It means the soot mass estimation is too high and it won't go away until a regen is completed. And if the soot is above a certain level it will eventually set a MIL and force you to take it in to the dealer for a service regen. Hopefully that's not the case.
Duramax_7 is offline
post #18 of 246 (permalink) Old 01-16-2016, 05:21 PM
BumbleZ's Avatar
Here's what the GM Tech Link article for the 2.8 Duramax says
The normal regeneration process removes captured particulates through incineration within the EPF. Regeneration occurs when the ECM calculates that the particulate level in the filter has reached a calibrated threshold using a number of different factors, including engine run time, distance traveled, fuel used since the last regeneration, and the exhaust differential pressure.
In general, the vehicle needs to operate continuously at speeds above 30 mph (48 km/h) for approximately 20-30 minutes for a full and effective regeneration to complete. During regeneration, the exhaust gases reach temperatures above 1,022°F (550°C). If exhaust gas temperatures fall below a normal calibrated threshold, regeneration will be terminated and a corresponding DTC should set. If a regeneration event is interrupted for any reason, it will continue, including the next key cycle, when the conditions are met for regeneration enablement. Normal regeneration is transparent to the customer. The self-cleaning occurs approximately once per tank of fuel.
A scan tool is required for service regeneration. Commanding a service regeneration is accomplished using the scan tool output control function. The vehicle will need to be parked outside the facility and away from nearby objects, due to the elevated exhaust gas temperature at the tail pipe during regeneration. The service regeneration can be terminated by applying the brake pedal, commanding service regeneration OFF using the scan tool, or disconnecting the scan tool from the vehicle.
There are two regeneration Driver Information Center messages. “Cleaning Exhaust Filter Continue Driving”will appear on the DIC when an exhaust particulate filter cleaning is required. To clean the filter, drive the vehicle above 30 mph (50 km/h) until the warning message goes OFF. This will take about 30 minutes. When the “Cleaning Exhaust Filter Must Continue Driving” message is displayed, it is important to keep driving to clean the exhaust filter. This will take about 30 minutes.
BumbleZ is offline
post #19 of 246 (permalink) Old 01-16-2016, 06:24 PM
battousai2000's Avatar
My observations-
Not good.....
Reading your post, it seems like you were indeed in the middle of a regen cycle and you needed to keep driving at highway speeds for 20-30 mins but you were idling for a while in a parking lot before you shut it down. This is probably why you went over 30 mins without the message going away.
low-tec likes this.
2016 Canyon, Duramax, All-Terrain, Cyber Grey, Crew Cab, Short Bed, 4x4, Sprayed on Bedliner, RC off road steps, Autospring 2.5 lift.
battousai2000 is offline
post #20 of 246 (permalink) Old 01-16-2016, 07:37 PM
I had a 2011 6.6 LML for almost 2 years and never saw a message that said to keep driving. I thought that was prior to the LML. So I'm kind of disappointed to see any mention of this with the 2.8. Do mostly city driving and it may not always be possible to do a sustained 30 stretch. Can you drop down a gear to get the engine revs up but still be driving less than 30?
XM813 is offline
