Rattle - Chevy Colorado & GMC Canyon
 4Likes
post #1 of 26 (permalink) Old 12-25-2016, 09:14 AM Thread Starter
Rattle
Have a rattle coming from passenger side behind glove box during certain times, have had dealer check it out and can't find. I'm thinking computer board, has anyone else had this issue?
cgory is offline
post #2 of 26 (permalink) Old 12-25-2016, 09:51 AM
Lots of people has/had this Vibration problem with the computer vibrating. Stick some thin rubber foam behind it.
Skip H.
2016 Colorado
Skip is offline
post #3 of 26 (permalink) Old 12-25-2016, 10:32 AM
I had this as well.. ended up being a bracket that held some cooling pipes in place that was located to close to the firewall...all they did was bend it back away from it... there is a bulletin out for this PIT5505
cmurray224 is offline
post #4 of 26 (permalink) Old 12-25-2016, 11:18 AM
Mine was the computer in the bracket. I zip tied them tightly together
2016 CCSB Duramax - 226hp/458tq
Tuned by Innovative Diesel
onebaddz is online now
post #5 of 26 (permalink) Old 12-25-2016, 11:48 AM
dmaxjr's Avatar
ECM was my rattle as well. Take ECM out of bracket,put foam between ECM and bracket and re install. The diesel engine shakes at low rpm and the wiring harness to the ECM from Engine vibrates and causes ECM to vibrate in the holder creating a buzz/rattle. I could have swore it was coming from inside behind glove box. ECM is right on the other side of firewall from glove box in engine compartment.
dmaxjr is offline
post #6 of 26 (permalink) Old 12-25-2016, 11:59 AM
I have a rattle somewhere on the ac/heat control panel. At least that is what I think!
AV8OR is offline
post #7 of 26 (permalink) Old 12-25-2016, 12:07 PM
dmaxjr's Avatar
If the rattle/buzz comes and goes with engine rpm , but NOT with bumps in rough roads then look into the ECM shake.
If it only happens during bumps or rough surface driving then not usually the ECM, but some plastic vibration, wich is usually worse when cold weather.
dmaxjr is offline
post #8 of 26 (permalink) Old 12-25-2016, 04:58 PM
Thanks! I will check it out.
AV8OR is offline
post #9 of 26 (permalink) Old 12-27-2016, 11:55 AM
I think mine is from after I hit bumps it starts but keeps going some times. Drives me crazy. It is quite then hit some rough patches in hyw then a vibration rattling plastic noise starts and sometimes don't stop. Then may be gone after a while then start back up. I think ill ask my mechanic here at work to see if he can at least put rubber foam behind ECM to at least take it out of equation. The if it still does it guess ill see about the cooling pipes next. Someone mentioned glove box screws but I down know where they are and what they mean on that one.
crappie man is offline
post #10 of 26 (permalink) Old 12-29-2016, 11:12 PM
GM Customer Service's Avatar
Hi cgory and others,
We understand how this rattling can be frustrating and would be happy to contact the dealer on your behalf to get this addressed. Please feel free to send us a private message if you'd like to discuss further. Be sure to include your full contact info, VIN, mileage and preferred dealer. We're here if further assistance is needed.
Best,
Bret B.
GM Customer Care
post #11 of 26 (permalink) Old 12-30-2016, 12:24 AM
KMW
KMW's Avatar
Best,
Bret B.
GM Customer Care
Why is it that you pop up right away on small things like rattles and radio issues, but are nowhere to be found on the seriously problematic issues, like the shifting problems? By coming on here you are the face and representative of GM. Not just to an individual customer, but to all other customers and public with access to the internet. You're really reinforcing the growing perception/opinion that GM couldn't care less about their customers with this very real problem that has been PROVEN to be completely fixable. Multiple aftermarket tuners have been able to completely fix this issue. Why won't you?
100MPG likes this.
KMW is offline
post #12 of 26 (permalink) Old 01-01-2017, 08:31 PM
Hi guys - I had a terrible metal on metal rattle in the passenger side dash of my 16 CC diesel. Took the glove box out, searched around - the two main screws that hold in the passenger airbag were able to be turned with my fingers. Took 6 or 7 full turns of the bolt to get them to snug down. Metal on metal rattle gone now, but holy cow - not reassuring that the airbag wasn't tightened down. Now I have a plastic on plastic rattle. I've narrowed it down to the little device with the string that keeps the glove box from dropping like a rock. It looks like a total pain to get that little thing out, so I haven't been able to remove it and test, but a tap on the black plastic bar around that thing causes the same noise when the truck hits a bump. Sounds like a spring rattling in a plastic tube.
LBBabyDMax is offline
post #13 of 26 (permalink) Old 01-01-2017, 08:57 PM
404 Not Found's Avatar
Seems to me that the whole point is to get complaints off a public forum and have them sent to private messaging where they will not be seen.
k7tnt and 100MPG like this.
Engine built 1/12/16
Placed order 2/20/16
Dealer ordered 2/25/16
Built and shipped 4/12/16
Delivered to dealer 4/22/16
Drove it home 4/27/16
404 Not Found is offline
post #14 of 26 (permalink) Old 01-01-2017, 09:17 PM
I had a similar coming from the glove box area when ever I hit a rough patch of road. After trying to figure out where it was coming from for a couple of days, I finally found the source. It was actually the screws that run across the top of the glove box compartment. They are visible once you open the glove box. Two of them were completely loose and about to fall out. They screw into metal clips, so it was a metal on metal rattle. Easy fix. Something worth while to check out.
'16 CC Z71
Ugafiredawg is online now
post #15 of 26 (permalink) Old 01-01-2017, 11:22 PM
I think I heard this today. 600 miles on my truck. Will be listening more closely going forward. Have to turn off audio and HVAC and run low speed and I think that is the triggering scenario. Going to subscribe here to keep up with this.
Planned Mods:
Homelink
RandyNC is online now
post #16 of 26 (permalink) Old 01-02-2017, 07:39 AM
My rattles are fixed now but one was the trim around the speaker in the middle of the dash and the other was the trim around the rear view mirror.
The mirror trim just need to be pushed on to be popped into place.
bglf83 is offline
post #17 of 26 (permalink) Old 01-02-2017, 07:23 PM
LoJac963's Avatar
I'm working on tracking down my rattles. I'm fairly certain I have the dreaded door rattles but I thought I'd check all these as well.
Those 4 screws on the top of my glove box were completely loose as well. I'll have to drive around to see if that removed one of my rattles.
2016 GMC Canyon SLT Cyber Grey, 2" RC level kit, LED's throughout, Iron Cross steps, Line-X, Stubby Jr, GMC All Weather floor mats, Bull Rings x9, DRL harness, OPT7 LED lows and fogs
LoJac963 is offline
post #18 of 26 (permalink) Old 01-02-2017, 07:45 PM
Good deal! Hope it resolved at least some of the rattles. I ended up using some loktite on them to prevent it from happening again. Those little suckers can make a lot of noise when loose!
'16 CC Z71
post #19 of 26 (permalink) Old 04-17-2017, 09:29 AM
To bring this back to life: I had some rattles too. 5 hours later
FOLLOW PIT 5505 GIVEN BY CUSTOMER. FOUND THAT THE NOISE IS COMING FROM THE AIR CLEANRE OUTLET HOSE. CHECKED AND FOUNDS THAT GM IS AWARE OF THIS CONCERN AND WORKING ON A REPAIR FOR THIS
NO REPIARS MADE AT THIS TIME
PapsBlue is offline
post #20 of 26 (permalink) Old 04-17-2017, 01:13 PM
Mine is the passengers side door, they looked at and said, "No abnormal sounds". 😳The other drivers side door doesn't do it, lol. I'll be tackling this one one day.
16_MidnightRider is offline
