Guide vane position and turbo noise questions - Chevy Colorado & GMC Canyon
 42Likes
post #1 of 84 (permalink) Old 01-11-2017, 09:52 AM Thread Starter
mrpositraction's Avatar
I am trying to find a suspected leak as I have some additional turbo noise that I didn't have before. But around the same time I installed a tune and haven't been able to return to stock yet (new to the Spade (autocal) and the directions provided doesn't include a way to return to stock. I've requested the stock file from the tuner as well as my purchased tunes (as I'll need those later to modify when I delete).
In my reading of this forum yesterday I read something about a "whislter" tune and wondered if that could have been possibly implemented into my tunes and is causing the sound. I would be fine with this as I am only concerned if there is a leak.
Here is some videos of what I am experiencing:
https://youtu.be/SlfrdZpvsKY
https://youtu.be/A46EVbusiTs
Here is a picture of the guide vane arm (I am assuming this is the arm and servo motor) position at idle: (I realize this is a crap picture with the shadow, but you can see the arm is "fully extended" if you will, meaning, looking from the front of the truck, it is in the furthest counter clock wise position it can go).
So here are my questions:
Does the guide vane position look like it is "open" creating the whistle that I am hearing in the videos?
I can here this on start ups too, it isn't just under load, so this leads me to think this is still a leak I am chasing.
I have pulled both the hot and cold side pipes post turbo and inspected them and didn't see any signs of leaks. I realize though that this sound could be from a very small leak.
Another thing I notice, on cold start up, I see signs of a very small leak were the "guide vane control arm" goes into the exhaust side, can anyone confirm if this is normal? Water drips out when it first starts up (condensation), also, you can see some small "exhaust marks, black" on the turbo housing.
2016 Colorado LT Diesel
Duramaxtune DSP-4 Tuning
mrpositraction is offline
post #2 of 84 (permalink) Old 01-11-2017, 10:44 AM
When I get mine back I'll check for the water marks. What kind of boost are u seeing? Would a datalog confirm if you are losing boost if you start to see a linear drop? I haven't played with the minimax yet.
I could see stuck vanes causing the sound and maybe not a leak. Have you checked the turbo for shaft play?
What can tell you... mine doesn't sound like that, my EcoBoost never sounded like that, my WRX didn't sound like that, etc. sounds more like a SC than a turbo.... which would make me want to check the shaft and bearings to make sure it was free turning. It sounds like you already checked all the clamps.
16_MidnightRider is offline
post #3 of 84 (permalink) Old 01-11-2017, 11:01 AM
I know nothing about the VNT function but I know @hacklerjason knows a bit.
Any ideas, bro? Definitely not something I've heard before
lqdchkn is offline
post #4 of 84 (permalink) Old 01-11-2017, 11:29 AM Thread Starter
I haven't check shaft play yet, if I am unable to find a leak I was going to return to stock and take it to the dealer and have them look at it. It started making this noise at 300 miles. I will be installing my AFE air box soon and will check then (assuming I can see the turbo fins and shaft at that time.
post #5 of 84 (permalink) Old 01-11-2017, 11:30 AM Thread Starter
Yeah, I was kind of hoping @hacklerjason would chime in, seemed very knowledgeable about what I am asking.
post #6 of 84 (permalink) Old 01-11-2017, 11:41 AM
hacklerjason's Avatar
Give me a little bit to get to work and I'll come back... Get me turbo desired vane position at idle please, while running...
hacklerjason is online now
post #7 of 84 (permalink) Old 01-11-2017, 11:45 AM Thread Starter
I'll work on getting that, I am very new to EFI Live and Autocal and learning so I am likely a little slower at getting this stuff. Have been a Ford guy and SCT user for years and have that stuff pretty well figured out.
post #8 of 84 (permalink) Old 01-11-2017, 11:52 AM
We just have to determine if it's making noise by design or flaw...
post #9 of 84 (permalink) Old 01-11-2017, 12:07 PM
I watched your videos... How much boost is indicated by your scan tool?
post #10 of 84 (permalink) Old 01-11-2017, 12:21 PM
I will say that don't sound normal.. can I see a pic of the intake
When did you first notice the noise and what was done just prior?
post #11 of 84 (permalink) Old 01-11-2017, 12:42 PM
Here is what mine sounds like... Nothing like yours and I have what I consider to be a large intake
https://youtu.be/13voHN2wDk4
Also... When you idle and then key off... Do you hear the arm cycling end to end for about 2 seconds then stop?
post #12 of 84 (permalink) Old 01-11-2017, 02:11 PM Thread Starter
Desired at idle is 100%
post #13 of 84 (permalink) Old 01-11-2017, 02:21 PM
Duramax_canyon's Avatar
That doesn't sound normal sounds kinda like a bearing noise I could be wrong.Mine is tuned and doesn't sound like that it could be the tuning you have thats weird.
hacklerjason likes this.
2016 black GMC Canyon 2.8 duramax long bed 4x4
Ready lift 2" leveling kit
18x9 black/machined moto metal 970's
275/65/18 nitto terra grappler g2
N-FAB steps
Gen5diy daytime running light disable harness
Morimoto 6500k HIDS 35w ballast canbus harness
Limo tinted
EFI live tuning by Aaron at all In truck performance
TCM tuning by Aaron at all in truck performance
Custom 3" exhaust
More to come soon....
Duramax_canyon is offline
post #14 of 84 (permalink) Old 01-11-2017, 02:26 PM
That's how mine sounds at idle minus the intake I was thinking about getting one for the mini max how do you like it and is yours oiled or is it the pro dry filter.
N-FAB steps
Limo tinted
Custom 3" exhaust
post #15 of 84 (permalink) Old 01-11-2017, 02:31 PM
It does sound like something in the CHRA... That's a whining sound and not a spooling sound... Could be bearing, wheel touching the housing because the bearing went... Just speculating right now, need more details
post #16 of 84 (permalink) Old 01-11-2017, 02:32 PM
It's the pro dry s... I never liked oiled filters... I've gone through too many mafs with older K&N 77 series intakes
I do like it! At WOT you can really hear the turbo
post #17 of 84 (permalink) Old 01-11-2017, 02:34 PM
And that is ok if you are going for a whistling tune... Can you make a datalog of a short drive
Record desired vane position, actual vane position, engine speed, throttle positon, and manifold absolute pressure please...
post #18 of 84 (permalink) Old 01-11-2017, 02:37 PM Thread Starter
Wasn't able to determine this, after getting the guide vane desired it would no longer data log. Looks like I need to update firmware on the device but waiting for my stock file from the tuner. I'll get my stuff updated and retry.
post #19 of 84 (permalink) Old 01-11-2017, 02:38 PM Thread Starter
I noticed it around 300 miles. Right after I installed the tune, probably within 40 miles, but I think that is coincidence to be honest. I have nothing else done to the truck.
post #20 of 84 (permalink) Old 01-11-2017, 02:39 PM
What about while you drive around? Is it pegged at 100% all day? I need that recording I requested in my post to help further
