Turbo Blanket - Chevy Colorado & GMC Canyon
 1Likes
  • 1 Post By Suns_PSD
post #1 of 14 (permalink) Old 04-21-2017, 09:28 AM Thread Starter
Post Turbo Blanket
Is anyone running one? If so where did it come from? I understand controlling underhood temp however during my research there seems to be some complaint about rot under the blanket? I assume since we are using factory manifolds and turbo housings (cast) we should have no issues. Looking for input from someone with more experience than myself.
Also what flange are we using turbo wise? I've read several threads where people mentioned different models of turbos from honeywell that are on our trucks but I'm not 100% what it is.
2016 Colorado CCLB Z71 Duramax
Current mods
GM offroad step bars
GM rear seat cover
GM Splash guards (front/rear)
Black Bowties (front/rear)
Thule Roof Rack/Roof Basket
ARE V series camper (headliner/12v outlets/LED Dome)
Future Mods (in order)
Headlight bulbs(stock blow booty)
Westin Grille Guard/10k winch
Full set of skid plates
High output alternator
Dual battery setup
DuramaxTrailboss is online now
post #2 of 14 (permalink) Old 04-21-2017, 10:13 AM
Generally heat shielding under the hood is best left alone unless you really needs it. GM has spent a lot of time working this out and generally unless you modified something that changed what they gave you it could more damage than good.
People often wrap headers and do more damage than good as it often holds the heat in and damages the unit.
In this case if it ain't broke don't fix it.
Now when you do mods that may change things then you may have to make a move to shield some items.
The key is to let the heat out and radiate away.
Also note if you do cover something and it is found to cause damage to the unit it could void any warranty on the item if it directly caused the issue to happen. Yes you can modify but GM is not going to pay for damage cause by your modification. Just something to consider.
Heat protection is good when you need it but if it is not a problem leave it alone.
hyperv6 is offline
post #3 of 14 (permalink) Old 04-21-2017, 10:44 AM
The idea behind a turbine blanket is not just heat control, but to also improve spool up and absolute boost.
lqdchkn likes this.
Suns_PSD is offline
post #4 of 14 (permalink) Old 04-21-2017, 12:04 PM
https://garrett.honeywell.com/produc...rado%20Duramax
post #5 of 14 (permalink) Old 04-21-2017, 01:05 PM
Originally Posted by ssgjurista View Post
Great find. I got curious and found that there are stock PT cruiser turbo upgrades made--- I wonder if one would drop in? MIC turbo builds a pretty good looking one with larger inducer/exducer.
16_MidnightRider is offline
post #6 of 14 (permalink) Old 04-21-2017, 08:33 PM
with my experience in my WRX for the past few winters, here in reno its been in single digits. Ive never had issues with my turbo spooling up because it was well below freezing. Of course elevation and air density effect the turbo also.
eyekyu is offline
post #7 of 14 (permalink) Old 04-22-2017, 08:40 AM Thread Starter
The more efficiently you can push heat/exhaust out of the turbo without losing energy to the engine bay, the better. At least from my understanding.
Current mods
GM rear seat cover
Dual battery setup
post #8 of 14 (permalink) Old 04-22-2017, 08:46 AM Thread Starter
There's no way we use the same turbo as the LML Duramax.....right?
Garrett 848212-5002S Stock Replacement Turbocharger
Current mods
GM rear seat cover
Dual battery setup
post #9 of 14 (permalink) Old 04-22-2017, 09:46 AM
With enough money anything works, but no. On a street/tow driver you ideally want the quick spool high early/mid tq. Too oversized creates lag. Remember we are dealing with a 2.8L.
post #10 of 14 (permalink) Old 04-22-2017, 05:32 PM Thread Starter
I don't mean with investing money. I mean the part number is 100% the exact same from the honeywell garrett website to that garrett replacement turbo.
Current mods
GM rear seat cover
Dual battery setup
post #11 of 14 (permalink) Old 04-22-2017, 07:11 PM
I read that as you were wanting, too lol. I would dang sure question that. You would think that our turbo would be hella small.
post #12 of 14 (permalink) Old 04-23-2017, 03:28 PM Thread Starter
Yea ours is small which is why I found that super odd. Both applications have the exact same garrett part number. I assume one has to be wrong.... idk
Current mods
GM rear seat cover
Dual battery setup
post #13 of 14 (permalink) Old 04-23-2017, 09:19 PM
why put a blanket on it when it is liquid cooled.
16 Crewcab Duramax Allterrain
Blazedude is offline
post #14 of 14 (permalink) Old 04-24-2017, 08:08 PM
Holding in the exhaust heat keeps the energy in the exhaust (as the exhaust gases cool, they loose velocity). It is common for turbo charged sports cars to "wrap" the headers, up-pipe, and hot side of the turbo to keep the energy in the exhaust instead of dissipating it out as heat and hence keeping exhaust velocity at its highest.
As previously mentioned, this results in slightly quicker turbo spool. Faster turbo spool means you get "on boost" quicker in the rpm range and minimize turbo lag. It also keeps engine bay temps lower.
I have never done this on the duramax but on my 2003 WRX (stage 2 tune with up-pipe, downpipe, full exhaust, intake ), wrapping the up-pipe, hot-side of the turbo, and the downpipe results in getting on boost about 200-300 rpm earlier. My wrapped parts have been wrapped since 2007 and are still solid but these are not stock pipes, they are made of Inconel which is much more durable and corrosion resistant than typical stock material.
My take on this is that it is probably not worth the hassle in this truck.
Hope that helps.
coloradoninja is offline
