Tire relocation and 2nd battery setup - Page 2 - Chevy Colorado & GMC Canyon
 11Likes
post #21 of 30 (permalink) Old 12-26-2016, 08:36 AM
The battery used I believe is a D34M from optima. It's a deep Cycle battery that can also be used as a starting battery if required. The comment above about the 0.7 volt drop is true, because of that I was debating on using this as a battery isolator, it can also be used to boost the main battery if it for some reason died and won't start the truck.
http://www.powerstream.com/battery-isolator.htm
If anyone goes with a diode style battery isolator make sure to get the 4 post ones. The 3 post ones won't work with our charging systems and the alternator won't put out any power. The 4th post is connected to a switched power from the ignition switch which enables it to work properly.
colt200 is offline
post #22 of 30 (permalink) Old 01-12-2017, 01:11 PM Thread Starter
maxwell_hau5_caffy's Avatar
So a small update to this. I've also been considering a softtopper to install, but kind of put off the idea since i didnt really understand how it was installed (kinda ignorant but oh well), i just assumed that I couldnt put a bed rack over the soft topper. But I came across this and realized the soft topper is just held on by a rail that is fastened to the bed rails and no drilling into the bed of the truck. So I think I'm going to make a bed rack my first metal working project and fab one up to my required spec.
Will probably do something similar to the album i posted below, add more support across the top and maybe extend a little bit over the roof to put the spare tire up there.
Baja Christmas - Album on Imgur
EDIT: I made a sketch. Red is welded together, blue will be removable so i can still load my motorcycle and stuff in the back without the rack interfering.
http://imgur.com/a/iqrgA
2016 Black Colorado Z71 4x4
- Current Mods: Air Dam Delete; WeatherTech floor liners; LED Bed-Lighting Mod;30" double row Xprite light bar;
Build Thread: http://coloradofans.com/forums/265-2...ml#post4084673
maxwell_hau5_caffy is offline
post #23 of 30 (permalink) Old 01-12-2017, 02:20 PM
So you're building the rack to go around the soft topper? I would probably get the soft topper before building the rack to make sure everything clears. I have a soft topper and have been thinking of a rack to go over as well.
NEW TRUCK
KN 63 Series intake - LineX - 30" GGLighting LED Bar - Front/Rear Adujustable King Shocks - Bajakits Boxed UCA - Method Double Standard Wheels - Falken AT3W 285/70/17 - Deaver Mini Pack inserts
OLD TRUCK
5inch CST lift
goleee33 is offline
post #24 of 30 (permalink) Old 01-12-2017, 02:56 PM Thread Starter
Yup, thats the plan. I dont really need to relocate the spare just yet. After I do my lift and tire upgrade, is when i'll need to relocate. Still need to get a z71 trim wheel to match the rest of them too so for me i'm still taking baby steps. lol
post #25 of 30 (permalink) Old 01-12-2017, 03:07 PM
I built a rack to go around my softopper for a recent trip to Alaska. It's pretty rough as I threw it together the week before I left(also my wedding week so I was pretty busy). Worked great though. I made it into 3 pieces for ease of install, disassembly, and storage. The whole thing is held on with the softopper clamps. It stayed rock solid from NYC, to Alaska and back with a heavy roof tent up top, fuel and water cans on either side.
lqdchkn, mexica and Tjdeerslayer37 like this.
Scurvynick is offline
post #26 of 30 (permalink) Old 01-12-2017, 03:26 PM
As far as tire relocation. I put mine in the bed. It takes up a lot is space but it's one of the only ways to relocate without lots of fab work.
NEW TRUCK
OLD TRUCK
5inch CST lift
goleee33 is offline
post #27 of 30 (permalink) Old 01-12-2017, 03:47 PM
Based on your comment, sounds like this trip was your honeymoon.
All I can say is congrats on a heck of a wife, may you have a long and happy marriage.
CaryBosse is online now
post #28 of 30 (permalink) Old 01-12-2017, 04:08 PM Thread Starter
Awesome! Congrats also.
Got any detailed pictures of the build? the trip?
@goleee33
That isnt an option for me. I would lose the ability to haul my motorcycle when i go up for track days and ultimately destroy my bed usage.
post #29 of 30 (permalink) Old 01-13-2017, 01:21 AM
Well "killer"....I was right, your work/ideas looks like crap! No wonder you couldn't take any suggestions, you don't have the skills to make something nice.
Don & Mary
2016 GMC Canyon SLT Crew Cab 4WD
(Motor Home Toad)
2" Leveling Kit
Amp Running Boards
BakFlip Toneau
OPT7 LED High beams
Morimoto LED Low Beams
Diode Dynamics LED Fog
HomeLink
Electric tailgate release
Pedal Commander
Air Lift Air Bags
DonS is offline
post #30 of 30 (permalink) Old 01-15-2017, 11:26 AM Thread Starter
Damn, you're still salty I didn't like your suggestion?
