loads of room but for what? - Chevy Colorado & GMC Canyon
 12Likes
  • 1 Post By mhr900ss
  • 6 Post By CaryBosse
  • 1 Post By boombots
  • 1 Post By drewabbs
  • 3 Post By JScottM
post #1 of 16 (permalink) Old 04-27-2017, 08:11 PM Thread Starter
mhr900ss's Avatar
Hi folks: I just removed the unusable spare wheel and heat shield. With my lift I can sit on the ground and my head clears the bottom of the bed (I'm 6'1"). I zip-tied the wheel dongle so that the centering lug doesn't bang about underneath and now I have a massive void under the truck. I'm thinking of water and air tanks, maybe using the unused diesel DEF fill point for the water. It's way too much empty space not to use for something.
BumbleZ likes this.
mhr900ss is offline
post #2 of 16 (permalink) Old 04-27-2017, 09:40 PM
Thunderbear's Avatar
Second battery, secondary gas tank, spare air tank, lockable storage. Plenty of things you could put there. Are you going to carry a spare at all?
vi et armis invictus maneo..
Thunderbear is online now
post #3 of 16 (permalink) Old 04-27-2017, 09:46 PM
.boB's Avatar
I'd be thinking of another fuel tank. To me, that would be the most useful.
.boB
www.RacingTheExocet.com
.boB is offline
post #4 of 16 (permalink) Old 04-27-2017, 10:02 PM
bnemmie's Avatar
I second the second fuel tank and battery.
bnemmie is offline
post #5 of 16 (permalink) Old 04-27-2017, 11:22 PM
I see the potential for the creation of a Pinto gas tank explosion.
And just in case we need a good spark, let's add a battery.
24v, goleee33, bigdave51 and 3 others like this.
CaryBosse is online now
post #6 of 16 (permalink) Old 04-27-2017, 11:38 PM
On board air for sure.
Sent from my BLN-L24 using Tapatalk
drewabbs likes this.
boombots is offline
post #7 of 16 (permalink) Old 04-28-2017, 12:16 AM
.boB's Avatar
Not at all. If you look at that space, it's very well protected. If you're worried about it, you could add a fuel cell.
.boB
.boB is offline
post #8 of 16 (permalink) Old 04-28-2017, 10:52 AM
maxwell_hau5_caffy's Avatar
my thing with putting anything down there is that its exposed to whatever terrain you're driving thru. Whether thats pavement, dirt, mud, or a water crossing. Not a problem for me, but salted roads would cause issues if not properly protected too. I would say maybe a 2nd fuel tank or water storage if you're planning on going out for a few days at a time. Anything else, i'd be afraid that it would damage or cause issues because of its exposure.
2016 Black Colorado Z71 4x4
maxwell_hau5_caffy is offline
post #9 of 16 (permalink) Old 04-28-2017, 11:40 AM Thread Starter
mhr900ss's Avatar
Thunderbear: I just ordered a full-size spare and a Wilco Offroad Hitchgate Classic. What would be a great opportunity for a manufacturer of rotomoulded plastic products would be to make a storage container the same or similar dimensions to a spare wheel complete with a centre lift point compatible with wheel lift mechanism; fill it with stuff and lift it up into the body. I have already approached one manufacturer of water containers about this idea but they were not interested.
The approach I'm planning to take with my truck is to make it an overlander/bug-out vehicle but to do it with a modular approach; air and house batteries in-a-box so they can be removed when not needed and swapped between vehicles if required. Despite this, a built-in air tank and delivery system to the front and back doesn't weigh much and there really is a lot of room under our trucks.
mhr900ss is offline
post #10 of 16 (permalink) Old 04-28-2017, 12:14 PM
The plastic storage is probably not likely. The most likely way to fit something there, and I really like idea of reusing the winch mechanism, is to build a wooden box and fiberglass it. You end up with something stronger than plastic and still waterproof. And if it works out, it's something that can be duplicated by others if you share the build plans.
The box would need QD points for air and power. An Anderson 50 amp QD would probably work.
post #11 of 16 (permalink) Old 05-01-2017, 07:32 AM
If I didn't need the bed space that moving the spare would take up.... I would love on-board air. Would come in handy when taking the teryx to ride, the trailer tires, etc.
16_MidnightRider is offline
post #12 of 16 (permalink) Old 05-01-2017, 09:04 AM
drewabbs's Avatar
With that lift, It sounds like you need a new jack.
Onboard Air for sure, extra tow straps and tools on a winch system like @Thunderbear suggested.
Man it would be nice to put your sandbags down there in the winter.......
Xibit would suggest that you do not put a TV down there, dawg.
ChaosTheory likes this.
drewabbs is offline
post #13 of 16 (permalink) Old 05-01-2017, 12:18 PM
A spare tire would be perfect for that spot!
CaryBosse, drewabbs and JimChevy15 like this.
JScottM is offline
post #14 of 16 (permalink) Old 05-01-2017, 12:29 PM
Not sure I understand the rest of your comment, but sandbags or some other weight for winter would be a great way to go. Load the weight low and right over the rear wheels.
I doubt that the winch can handle lifting 200 pounds of sand though.
post #15 of 16 (permalink) Old 05-01-2017, 11:38 PM Thread Starter
mhr900ss's Avatar
JScottM: I bought this truck to take off pavement and the lift and bigger wheels were already installed so my old spare was useless as it wouldn't fit the front and was too small. I did measure the space underneath and I'm confident my new wheel will not fit. I'm hoping to pick it up at the end of this week or next and will play just to see. There's a little frame at the back of the spare wheel well that I'll probably have to remove also; I'll play and take pics. Even if it fits, I'd have to fab an alternative heat shield and my bigger concern is it would hang too low, even with my lift; my tires are 12" wide. Moot point as I have already ordered a Hitchgate but it's still good to know if an oversize wheel will fit underneath.
mhr900ss is offline
post #16 of 16 (permalink) Old 05-02-2017, 08:54 AM
ChaosTheory's Avatar
If you make a bunch of trips to Mexico, I'm sure someone down there could find a use for that "extra space".
2017 Duramax 4x4 Z71
04/20: Ordered at dealer
04/25: Accepted by GM (2000)
04/26: TPW 05/08 given (3000)
04/29: Vehicle ready to build (3300)
05/05: Order sent to production (3400)
05/13: 0946 AM, vehicle completed
05/17: Delivered to dealership (5000)
ChaosTheory is online now
