How to run wires through the firewall, 2015 Colorado - Chevy Colorado & GMC Canyon
 20Likes
post #1 of 24 (permalink) Old 09-06-2015, 09:32 PM Thread Starter
ADMIN
Blue15ColoradoLT's Avatar
This is just a simple "how to", just to show people where to run wires from the engine bay through the fire wall.
1) In the engine bay, on the firewall, between the engine and the brake fluid reservoir is the grommet where you want to cut into:
2) Using your knife, just slice straight through, all the way into the cabin area, and then just run the wire(s) through your slit:
3) The wire(s) will come into the cabin through the fire wall between the gas and brake pedal:
4) You can then run the wire wherever you need to for whatever accessories you are wiring up.
2015 Laser Blue Colorado LT
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED license plate lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Canyon swapped tail lights
Red painted calipers
Supermod ported throttle body
Silver metallic rally stripes
Super Skidz skid plate
Volant CAI
***NOTE***
SITE RULES
Blue15ColoradoLT is offline
post #2 of 24 (permalink) Old 09-06-2015, 09:59 PM
Thanks, I still haven't had time to poke under the hood.
Shot in the dark, the inside fuse box has some empty slots according to the manual... Would you know if any of them are hot, preferably ignition switch ?
Would make it that much easier so some light weight power demands, I still have to get to my footwell lights.
Xcanuk is offline
post #3 of 24 (permalink) Old 09-06-2015, 10:03 PM
Thats pretty much the same spot used in my 2005 Colorado. Nice to see they still haven't taken that spot away.
Wouldn't hurt to mention.....dab some RTV silicone after your all done to keep moisture out of the cab.
And, finally got the ok from my dealer that my truck got ordered....the waiting begins.
Toughsox is offline
post #4 of 24 (permalink) Old 09-06-2015, 10:05 PM Thread Starter
ADMIN
I actually used a slot in the fuse block for the power on my light bar. I can get a picture later tonight when I head out for the night.
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Volant CAI
***NOTE***
SITE RULES
post #5 of 24 (permalink) Old 09-06-2015, 10:14 PM
PAR
PAR's Avatar
Good info! Thanks! I used the grommet for the hood latch cable to run the power wire for my amp. It's not ideal, as I had to pull the grommet out and leave the power wire susceptible to shearing on the firewall.... I'll keep this spot in mind for next time, or if I choose to reroute.
2015 Colorado CC/SB LT 2WD 3.6L V6
Cyber Gray/Jet Black
Convenience Pkg
18" Wheels
Tow Pkg/Locking Diff.
PAR is offline
post #6 of 24 (permalink) Old 09-06-2015, 11:19 PM
Very Helpful! Thanks!
NEW TRUCK
OLD TRUCK
5inch CST lift
goleee33 is online now
post #7 of 24 (permalink) Old 09-06-2015, 11:20 PM
jot1teg's Avatar
A better place as long as you do not have a standard transmission is to use the spot where the clutch pedal would mount. I was able to drill a small hole for a power wire to my Kicker HS8 powered sub - used a small rubber grommet and then some sealant to make sure no leaks and no chaffing. There is plenty of room for larger wires if necessary. Again, this is only for automatics. By the way, I put the foam cutout piece back after I took these pics.
PAR, Mar424, DasGoob and 2 others like this.
2015 GMC Canyon Ext Cab All Terrain 3.6L V6 Auto
jot1teg is offline
post #8 of 24 (permalink) Old 10-27-2015, 07:11 PM
Morbius's Avatar
Best place to run wire from battery to interior
Will need to run two separate power wires (10ga.) from battery to rear seating area in 2015 Colorado Crew Cab Z71. Is there a good spot on driver's side? I have given a quick look inside cab and engine compartment, but haven't seen any obvious ports....
2015 Colorado Z71 4WD CC LB
Brownstone Metallic
Bose/Wheel Flares/Tow Package
K&N CAI
Westin Grill Guard/OPT7 CREE Lightbar/Autospring 2" level/American Tonneau tri-fold
Morbius is offline
post #9 of 24 (permalink) Old 10-27-2015, 07:53 PM
If anybody knows of the threads that address running the wires through the firewall please share.
DasGoob likes this.
post #10 of 24 (permalink) Old 10-27-2015, 09:03 PM
Morbius's Avatar
got it, thanks...
http://coloradofans.com/forums/201-2...-colorado.html
Brownstone Metallic
K&N CAI
Morbius is offline
post #11 of 24 (permalink) Old 10-27-2015, 10:02 PM
Originally Posted by Morbius View Post
hahahaha awesome!
post #12 of 24 (permalink) Old 12-29-2015, 05:08 PM
Thanks for the info, just ran my 4 gauge power wire. Since my amps will be in back I used a bolt under the seat for ground wire.
2016 GMC 2WD Short Bed SLT in Cyber Gray.
Towing package, Bose, Nav, and Driver alert
squiggyfreud is offline
post #13 of 24 (permalink) Old 12-29-2015, 05:23 PM
jot1teg, nice find. That's the spot I am going to use now that I see where you are talking about. Perfect to drill and place my 4AWG firewall bushing, cable. Thanks!
linenoise is offline
post #14 of 24 (permalink) Old 12-29-2015, 08:26 PM
post #15 of 24 (permalink) Old 01-20-2016, 03:38 PM
Not bad. I used The Same location and Gromit as the hood release cable For my small accessory power wires. I've been looking forward to installing an amp and sub And was hoping I could get my amp wire through there as well but I'll try your spot.
2016 Canyon SLE 3.6 Black / Philips Daylight4 LED day time running lights / Morimoto 35w 6500 K HIDs / Philips vision LED back up lights / weathertech floor liners and mudflaps / Guns N' Roses vanity plate / 20% tint / LED only parking lights / LED running board lights
evan16canyon is offline
post #16 of 24 (permalink) Old 05-17-2016, 04:17 PM
Mar424's Avatar
How are you guys connecting the positive wires to the battery?
I ran my 4 gauge amp wire through the firewall, but when I thought all I had left to do was unscrew the positive terminal nut, put the wire on then tighten the nut.... I realized the nut doesn't seem to come completely off, just loosens...
2015 Canyon Crew Cab | 3.6L V6 | BNR Tune | Pioneer 5800 | Eibach Leveling Shocks 1.4"|
Mar424 is offline
post #17 of 24 (permalink) Old 05-17-2016, 04:53 PM Thread Starter
ADMIN
The accessory fuse positions in front of the fuse block
File Type: jpg 1610760_10153674483089804_7999700679324468010_n.jpg (137.6 KB, 199 views)
Mar424 likes this.
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Volant CAI
***NOTE***
SITE RULES
post #18 of 24 (permalink) Old 05-24-2016, 09:17 PM
Bruce Edley's Avatar
Where did you end up putting the ground??
Bruce
2016 Chevrolet Colorado Z71 4x4 Deisel CCSB
1967 Chevrolet Caprice Hard Top 4 Door 350V8
Mods: Edelbrock Intake, Carb, Aircleaner, Hooker Headers, Magnaflow Super 40s
1980 Yamaha XS850 Midnight Special
Bruce Edley is offline
post #19 of 24 (permalink) Old 05-24-2016, 09:45 PM Thread Starter
ADMIN
The grounding screw
File Type: jpg 13240723_10154164459549804_1518433250991431877_n.jpg (118.1 KB, 146 views)
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Volant CAI
***NOTE***
SITE RULES
post #20 of 24 (permalink) Old 05-24-2016, 10:43 PM
I found that right after the post. Thanks!!
Bruce
