ProFab Performance Intake Tube LWN 2.8L Duramax Installation and Discussion - Chevy Colorado & GMC Canyon
 40Likes
post #1 of 48 (permalink) Old 04-24-2017, 03:28 PM Thread Starter
hacklerjason's Avatar
I am opening a thread to document my install and discuss the product
Install was very straight forward
Fit and finish is top quality
Definitely love the bead rolled ends of the hard pipe
I like the rough powder coat and the silicone boots are heavy duty
Included all hardware
File Type: pdf ProFab Performance Intake Tube (2016+ Colorado Duramax).pdf (507.8 KB, 184 views)
hacklerjason is offline
post #2 of 48 (permalink) Old 04-24-2017, 03:29 PM Thread Starter
Reserved
I plan to edit
post #3 of 48 (permalink) Old 04-24-2017, 08:11 PM
papasmurf1958's Avatar
I agree on the quality for sure. I could see what looked like 7 layers of reinforcement material in the silicone. Install was simple. I cut about 3/4" off turbo end of the lower boot and 1/2" off the air box side of the upper boot. This allowed for a nice fit up without touching anything, even the oil filter housing. I also installed the Profab hot side ic pipe. Another good quality item. Fit was spot on and the 2 3/8 pipe is routed under the air intake with only one 90 degree turn plus a slight bend. I chose this vs. the afe for that reason as the afe has three 90 degree turns and is much longer in total length. Went with the afe on the cold side. The piping was much longer and less rubber balloon, I meant boot.
My first road test was pulling my 16' enclosed trailer loaded to about 4500lbs. I definitely can tell the engine gets torque quicker than before. No dyno to prove it. Turbo whistle is present now. I'm liking the upgrades for sure.
k7tnt and hacklerjason like this.
papasmurf1958 is offline
post #4 of 48 (permalink) Old 04-25-2017, 01:45 AM Thread Starter
ProFab is running a group buy right now
post #5 of 48 (permalink) Old 04-25-2017, 01:59 AM
Add me to the list, wait, they don't ship to Cali, interesting.
2016 GMC Canyon SLT (Summit White)/ 2.8L Dmax/ 4x4/ CC/ LB/ Line-X/ Remote Start/ Debadged/ Icon Suspension Stage IV/ 17x8.5 Method Grid Titanium/ 285/70/17 Toyo Open Country AT/ OEM GMC All Weather Liners/ Bakflip MX4 Cover.......
JDubs is offline
post #6 of 48 (permalink) Old 04-26-2017, 11:00 PM
SigArms's Avatar
Screw it, add me to the list as well!
lqdchkn and hacklerjason like this.
Built list: Bak revolver x2, premium Line-X, rigid b/up lights cut & mounted in bumper, kn insert air fltr, zroadz fog plate w/rigid spots & floods, d-max tuner, matte blk badges and custom diesel badges, bilstien 5100 RHA 2" lift with rear 1" gm lift blks, 275/65-18 TA ko2, 2" wheel spacers (big rub @ full steer, w/o spacers), pedal cmdr
To/do: AFE intake, puddle leds, Anzo tails, Zone 1.5" body lft
SigArms is offline
post #7 of 48 (permalink) Old 04-26-2017, 11:01 PM Thread Starter
Check pms
mexica and SigArms like this.
post #8 of 48 (permalink) Old 04-26-2017, 11:06 PM
Moderator
hacklerjason and SigArms like this.
lqdchkn is offline
post #9 of 48 (permalink) Old 04-27-2017, 09:40 AM
Any pictures installed? Or of the boost tubes?
2016 Colorado Z71 Trail Boss Duramax Diesel
Summit White Crew Cab
go_n_low is offline
post #10 of 48 (permalink) Old 04-27-2017, 09:53 AM
Info on the group buy please!
go_n_low is offline
post #11 of 48 (permalink) Old 04-27-2017, 11:36 AM
Moderator
Its not a GB in the traditional sense, just PM @hacklerjason to get the link for the special purchase price and buy.
Just posted on FB that the expiration date is 5/9 so order soon
hacklerjason likes this.
lqdchkn is offline
post #12 of 48 (permalink) Old 04-27-2017, 12:49 PM
When ordering the the intake tube, should I add the PCV fitting? It asks on their website and I didn't see it discussed here.
go_n_low is offline
post #13 of 48 (permalink) Old 04-27-2017, 12:53 PM Thread Starter
If you aren't rerouting you PCV, you'll need the fitting
mexica likes this.
post #14 of 48 (permalink) Old 04-27-2017, 07:33 PM
Here is the intake and hot side tube.
mexica and hacklerjason like this.
post #15 of 48 (permalink) Old 04-27-2017, 07:34 PM Thread Starter
Was the intake tube long enough? I had a couple changes requested and I think everybody should have the newest pipe
post #16 of 48 (permalink) Old 04-27-2017, 07:43 PM
The tube fit nicely. Was plenty long enough. The hot side pipe did not come with the adapter to the ic fitting but the boot attached securely without any drama. I trimmed about 3/4" off the turbo end and about 1/2" off the air box end. I ordered mine early last week before the group buy. The silicone elbo on the air box side came separately from the supplier direct shipped. A little tweaking an it fit without touching anything. The breather tube fitting is nice and snug too. Overall a good quality kit.
post #17 of 48 (permalink) Old 04-27-2017, 07:47 PM Thread Starter
I ended up removing an inch from the turbo side, clocking it at about 10:00, 10:30 respective to the turbo inlet, to keep it off the oil filter housing. And also removed about an inch from the airbox side
papasmurf1958 likes this.
post #18 of 48 (permalink) Old 04-29-2017, 03:10 PM
Duc
Is this the $189 kit in their site?
Duc is offline
post #19 of 48 (permalink) Old 04-29-2017, 07:43 PM
You are correct. I think they have a coupon code on Facebook this week too.
post #20 of 48 (permalink) Old 04-30-2017, 12:23 PM
Duc
So many talented people on this site modifying and building things why hasn't some made this. Seems like it'd be a LOT cheaper to buy a couple boots and bend a piece of pipe then $189.
Duc is offline
