Flat Towing - Chevy Colorado & GMC Canyon
post #1 of 15 (permalink) Old 05-18-2008, 10:47 PM Thread Starter
Flat Towing
I just bought a donor S10 4 door Blazer to finish my Jimmy project. The trans was shot, so I decided to get a tow bar and drag it home behind my truck. I have a picture but it's on my phone. I was impressed with how the 2.8 performed, it held 60 in 5th gear most of the way. Anyone else ever flat tow with their truck?
Victory Red '06 Std. Cab/Z85/4x4/2.8/5 Speed/
3.73's/G80/Sport Masters Hinged Tonneau/2" T-Bar/.750" Diff. Drop/Skyjacker AAL/Mastercraft Courser AT2 31x10.50s
89,000 Miles-1/19/12
ds06rado is offline
post #2 of 15 (permalink) Old 05-19-2008, 11:25 AM
Re: Flat Towing
dumb question, whats flat towing??
dlegend18 is offline
post #3 of 15 (permalink) Old 05-19-2008, 11:29 AM
CALI-BOSS
DBNissan's Avatar
Re: Flat Towing
Flat towing is pulling a vehicle that has all four tires on the ground. The term is most commonly used in the RV world. When you see an RV pulling a car without a dolly or trailer, that's flat towing.
DBNissan is offline
post #4 of 15 (permalink) Old 05-19-2008, 11:35 AM
Re: Flat Towing
oh, ok. seen it before but never knew what it was called. Learn something new everytime. Thanks
post #5 of 15 (permalink) Old 05-19-2008, 12:55 PM
Re: Flat Towing
Great way to rack up miles on your runabout vehicle.
rangerbob is offline
post #6 of 15 (permalink) Old 05-19-2008, 01:27 PM
Re: Flat Towing
My Grandparents bought a Canyon 4wd to pull behind their RV and it doesn't rack up any miles at all when they flat tow it.
Indigo Blue '04 Canyon Z71 Ext Cab
Trac-Rac
Speedy28 is offline
post #7 of 15 (permalink) Old 05-19-2008, 09:43 PM
Re: Flat Towing
interesting didnt know it as called flat towing
05 Chevy Colorado
Z71 4x4 Ext cab
I5 3.73 Ratio
FIPK 57 K&N Intake
Flowmaster 40 muffler
Bridgestone A/T
PCMforless Tune
Tranny Cooler
red12 is offline
post #8 of 15 (permalink) Old 05-19-2008, 11:58 PM
Re: Flat Towing
If a 4 x 4 (auto trans), and if equipped with a neutral on the 2 x, 4 lo,4 hi controls, press the 2 x and the 4 hi buttons at the same time, until the neutral light blinks and comes on. With the tranny in Park, the rig is ready to tow. A fuse can be pulled under the hood, to eliminate any mileage build-up.
If you have a 2 wd, a manual trans, or a unit without the neutral light, u r on your own....who knows??????
I have a 99 blazer and an 08 colorado and both are set up to be towed behind the motorhome. The blazer has maybe 5000 miles of towing under its belt, w/o any problems.
I think with a 2 wd and manual transmission, one just has to put the trans in neutral and make sure the front wheels arent locked by steering or ignition switch.
Oregon Colorado is offline
post #9 of 15 (permalink) Old 05-20-2008, 02:11 AM
Send a message via Yahoo to dirtydawg
Re: Flat Towing
Originally Posted by Oregon Colorado
. . . press the 2 x and the 4 hi buttons at the same time, until the neutral light blinks and comes on. . .
That's, "press the 2x and the 4 LO buttons at the same time . . ." (See manual). If you try the 2x & 4 HI at the same time, all it will do is shift from one to the other, not Neutral.
2007 TOTW #33 - LIFTED CLUB #24 - CONSERVATIVE CLUB #43
Rancho 4" / Skyjacker Softride / PA 3" - ProComp Xterrain 305/70R16 - 16x8 Eagle 1378
Smittybilt XRC-8 Winch - Optima Red - Hella 4000 Compact Fogs - AEM / PCMForLess - E-fan - Hard Cover
dirtydawg is offline
post #10 of 15 (permalink) Old 05-20-2008, 09:41 PM
Re: Flat Towing
Very correct. I noticed the error of my ways while in the truck today. I was shooting from the hip and shot myself in the foot...lol
Anyway, its pretty damn obvious and self explanatory , if ya look at the markings at the/on the control button panel.
post #11 of 15 (permalink) Old 05-22-2008, 01:32 PM
Re: Flat Towing
And doesn't it say to have the transmission in neutral when doing so? The few times i had to use 4lo i had to have the tranny in neutral.
2005 Rado Z71 Ext Cab I5
Vent Visors | Redline Hood Lift Kit
2"shackles/TBar lift/Skyjacker Nitro 8k's
Diff Drop 3/4" | Pro-Comp AT's | 1" BL soon
Lifted Club Member #80
Gun Toting American Club Member #34
JeSuS is offline
post #12 of 15 (permalink) Old 05-22-2008, 06:29 PM
Re: Flat Towing
Kudos to GM for designing a vehicle to be flat towed - a lot of vehicles even if you have the tranny and/or t-case in neutral, the lube system internally does not work correctly and you can cause some serious damage. I was impressed when the salesman showed me that feature, even though I will most likely never use it.
2008 Pontiac G6 3.5 4 door
1996 Jeep Grand Cherokee 4.0 ... the "other vehicle"
Canyon.Off.Road is offline
post #13 of 15 (permalink) Old 05-22-2008, 06:48 PM
Re: Flat Towing
I agree with you Rangerbob. Even though you may be able to keep the miles from registering on the odometer, the suspension and tires are still racking up miles.
2008 GMC Canyon Ext Cab SLE
3.7L DOHC I5 Auto
Sonoma Red
trixr4kidz623 is offline
post #14 of 15 (permalink) Old 05-22-2008, 07:44 PM
Re: Flat Towing
Don't have it in front of me, but as I recall the manual said nothing about leaving the AT in N. Once the T-case is in N, no torque is transfered between the driveline and the tranny. That's why the manual says to apply the parking brake while putting the T-case in N. The truck will just roll away with you if you don't. If you're already hooked to a tow vehicle (as one would assume if you're setting up the truck for flat-towing) then it's no problem. But if it's not connected to anything, you'll be sitting in a mighty big roller skate! That could end in a and a and a and a
post #15 of 15 (permalink) Old 05-22-2008, 10:49 PM
Re: Flat Towing
For sure....not a good idea to roll into something else, I always drive up to my MH, hook up, and then do the neutral switch over. I believe it then says to put the vehicle in park (which seems kinda strange), but its a good idea to just follow the OM instructions. Must make sure that the steering isnt locked though....
