Low Idle Speed/Check Engine Light - Chevy Colorado & GMC Canyon
post #1 of 7 (permalink) Old 12-03-2008, 02:00 PM Thread Starter
Ok, what is the normal idle speed for the 2005, I5, 3.5 crew cab (Z85)??
It hovers between 300-500 rpms and stalled often. The check engine light had been on for quite some time and I took the thing in yesterday - they pulled a code and replaced the map sensor - $276.00. Drove off the lot last night and no change in idle speed, check engine light off.
This morning driving to work the engine light is back on again.
I called the dealer this morning - they want to check the code again. But if all they do is check codes this could go on forever!
Thanks for any advice!
Twiggymoo
twiggymoo is offline
post #2 of 7 (permalink) Old 12-03-2008, 02:05 PM
Re: Low Idle Speed/Check Engine Light
Most likely going to have to clean the throttle body, I had the same problems, and they were all fixed after I cleaned the TB.
There is an extensive write up on how-to, search that up.
Former UNDER 21 CLUB MEMBER #43
Z71ON on YouTube
2005 Colorado Z71 4X4
2007 Honda TRX400EX
2001 Honda CR250R
MarkEG is offline
post #3 of 7 (permalink) Old 12-03-2008, 02:18 PM Thread Starter
thanks MarkEg. I do have a question on the 3ft tube. The instructions say to snake it to the throttle body and use a funnel for the seafoam. Where is the entry point for the tube?
post #4 of 7 (permalink) Old 12-03-2008, 05:58 PM
clean machine's Avatar
^^ Pull out your air filter. Be careful with the seafoam.
06 WT 4 cyl. 5 speed AEM MBRP PCM4less
lowered 3/3.5
KDC-X693/kdc-c719/kac 7252/x1200m
Dynamat X doors/mmc6500 doors/2-momo 10's
clean machine is offline
post #5 of 7 (permalink) Old 12-03-2008, 06:33 PM
Just take the TB off and clean it good with Carb cleaner. Its only 2 plugs and 4 bolts. Very very simple.
Lifted Club Member #179
TOTW Winner Week #31 2008
Gun Toting American Club Member #55
CAI, Gutted Cat, Magnaflow, PCMforless Tune, New Head! (Thanks GM), Supermod PTB, Vette Servo
2" TB Crank, BJ flip w/1/4" Spacer, 2" Procomp AAL, Air Shocks, 1" BL
**SINSITY KUSTOMZ**
jrbyers96 is offline
post #6 of 7 (permalink) Old 12-03-2008, 06:36 PM
Ditto.
Its easier to clean it when you have it off too, you can get right in there.
Z71ON on YouTube
2007 Honda TRX400EX
2001 Honda CR250R
MarkEG is offline
post #7 of 7 (permalink) Old 12-12-2008, 09:54 AM
Send a message via MSN to southpaw756
Had the same thing happen with my 04 Z71 crew cab, had the fuel system i.e. throttle body and maf sensor cleaned and no more issues. Even seemed to have regained some power, maybe my imagination.
2004 Z71 Crew Cab
southpaw756 is offline
