floor wet gmc canyon 2005 - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 12-25-2008, 03:16 PM Thread Starter
Hi I own a 2005 gmc canyon crew cab and when it rains the drivers floor gets wet, any help to fix this problem.Thanks Bill
jarvo is offline
post #2 of 10 (permalink) Old 12-25-2008, 05:38 PM
JBT
JBT's Avatar
Re: floor wet gmc canyon 2005
Do you have a sunroof?
_________________________
Chevy Molded Splash Guards
Chevy Chrome Side Steps
Bose & Nav System
Spray in bed liner
Tow Package
Built 8/18/15
A.R.E. Z Series Cap
Bed Rug
Red Hot
JBT is offline
post #3 of 10 (permalink) Old 12-25-2008, 05:41 PM
JBT
JBT's Avatar
Some peoples third brake light leaks but that usually makes the back seat floor wet.
Bose & Nav System
Spray in bed liner
Tow Package
Built 8/18/15
A.R.E. Z Series Cap
Bed Rug
Red Hot
JBT is offline
post #4 of 10 (permalink) Old 12-25-2008, 09:48 PM Thread Starter
no i donot have a sunroof
jarvo is offline
post #5 of 10 (permalink) Old 12-25-2008, 09:51 PM
Send a message via AIM to eb0b
check all your weatherstripping around the doors and then check your wipercowl for any visible leakage there
2005 Colorado Z71:
K&N intake, Flowmaster 40 Series Exhaust, T-Bar 1 1/2'' front.
2004 Saturn ION Red Line:
B&M Short Throw Shifter 14.5 @95 ETA
eb0b is offline
post #6 of 10 (permalink) Old 12-25-2008, 10:51 PM
There's a TSB on this...
http://www.naskie18.com/colorado/TSBs/F ... 0Floor.pdf
CapeRR is offline
post #7 of 10 (permalink) Old 12-26-2008, 01:16 AM
Check the third brake light first, rear window second and then the TSB. You can also pull up the carpet and see it it ran from the front or back.
RIP Spike 9-25-2007
coyote is offline
post #8 of 10 (permalink) Old 12-27-2008, 09:34 AM
z7105's Avatar
Send a message via AIM to z7105
Is GM required to fix the TSB...even if your warranty has already expired?
I have the same issues with my 2005 and its driving me nuts!
05 Colorado 2WD Z71 Crew Cab
5% Tint · Billet Grille · Grille Emblem · Bed Spray Liner · 6 in. Antenna
15x8 Chrome Rock Crawler Rims - 99 series · 31x10.5 BFG All-Terrains
z7105 is offline
post #9 of 10 (permalink) Old 12-27-2008, 10:34 AM
No they are not required to fix a TSB, only a recall. I had a similar issue with a Dodge Ram there was a TSB for the engine manifold pan gasket, but i would have had to pay the dealer to do it so I just went to my regular mechanic.
The TSB is only a service bulletin to point the tech in the right direction when troubleshooting. I don't agree that we should have to pay for a manufacturing defect/design flaw, but that's how it goes.
RIP Spike 9-25-2007
coyote is offline
post #10 of 10 (permalink) Old 12-27-2008, 10:52 AM
If your leak is coming from the cowl area, you can follow the directions in the TSB and fix it yourself. You would remove the wiper arms and plastic cowl cover to get access. Other than a few dollars for a tube of silicone, it's a cheap fix.
