Bypassing Passlock without using Remote Starter??? - Page 2 - Chevy Colorado & GMC Canyon
Old 01-19-2009, 02:08 PM   #11 (permalink)
huurb's Avatar
Default Re: Bypassing Passlock without using Remote Starter???
Originally Posted by coyote
Huurb:
No we need to bypass our stock passlock, no chip in key, for the remote start to work. Otherwise the starter won't crank, our ignition is all electronic and controlled through the PCM/BCM.
jlinknc:
I have no idea if it would work without looking at the diagram.
Coyote
I know I don't have a chip in my key, but the place that installed my remote start said that some coly's do have the chip. So that's where I got my info from. I have heard some people on this forum talk about having chips in their keys, so what do you believe
huurb is offline   Reply With Quote
Old 01-19-2009, 02:12 PM   #12 (permalink)
Send a message via ICQ to coyote Send a message via AIM to coyote Send a message via Yahoo to coyote
I don't know if the newer ones have the chip, but my 08 doesn't. The key looks the same as the 2005 key.
RIP Spike 9-25-2007
coyote is offline   Reply With Quote
Old 01-19-2009, 02:58 PM   #13 (permalink)
Mine does NOT have the chip in the key.. Just a normal looking key but I want to still use my normal looking key to start the truck and do not want to use a remote starter. I thought with all the Passlock problems that have bombarded the Colorado's since 2004 that someone might have used a Passlock Bypass Module to bypass the Passlock entirely WITHOUT installing a remote starter. Looks to me if you can bypass it for the remote starter to work then you should be able to bypass it for the key to work. I'm no electrical engineer so that is why I am asking for help here. Again, let me make it clear that I'm not interested in a Bypass Modules installed to use a remote starter...I'm looking for info on Passlock Bypass Modules installed WITHOUT using a remote starter.. Thanks Jimmy
jlinknc is offline   Reply With Quote
Old 01-19-2009, 03:09 PM   #14 (permalink)
You can have someone turn off the security features when you get your PCM tuned.
Originally Posted by supermodulation
Find someone with an HPtuner and turn off your "VATS", end of problem!
RIP Spike 9-25-2007
Old 01-19-2009, 06:22 PM   #15 (permalink)
PassLock has been a problem long before there were Colorados. All GM models with PassLock have had certain vehicles that have the problems.
06' Colorado Xtreme
Louisiana Meet: http://coloradofans.com/viewtopic.php?p=506023#506023
collyondubs is offline   Reply With Quote
Old 01-21-2009, 09:59 AM   #16 (permalink)
I've called 3 different HPtuners and they said they could NOT turn off the Passlock II system on a Colorado with their Open Port. Can you give me the name and number of the HPtuner you say that can do this so I can have one of these HPtuners call to see what their secret is?
Old 01-21-2009, 10:12 AM   #17 (permalink)
I had stocker2 tune my PCM, you could try PMing him.
RIP Spike 9-25-2007
Old 01-21-2009, 10:19 AM   #18 (permalink)
I just contacted Alvin@pcmforless.com a few minutes ago. I found his name and contact info on this site. He said he has never turned off the Passlock system on a Colorado but he thinks he can do it and is going to try it tomorrow afternoon on my truck. If that doesn't work then I will contact your tuner for further instructions. Thanks
Old 01-21-2009, 11:28 AM   #19 (permalink)
Administrator
I own an HPtuner Pro and I have done it! :D
supermodulation is offline   Reply With Quote
Old 01-21-2009, 01:42 PM   #20 (permalink)
Canyon08Z71's Avatar
I believe you!!
I also have the HP Tuner Pro and have done it. :D
- Gerry
Advanced Vehicle Technologies
AVT Local & Remote Vehicle Tuning
AVT @ Facebook
Canyon08Z71 is offline   Reply With Quote
You may not post new threads
You may not post replies
