2008 rear drum brake squeal is NORMAL...? - Chevy Colorado & GMC Canyon
Old 02-12-2009, 02:25 PM   #1 (permalink)
Default 2008 rear drum brake squeal is NORMAL...?
I searched for 'brake squeal' and the threads were fairly old, so I'm posting about a 2008 truck.
The dealer says it's normal...you gotta be kidding.
What's the fix for REAR brake squeal?
SLT...the only thing missing is "U".
2008 GMC CANYON SLT Z-71
BusMaster007 is offline   Reply With Quote
Old 02-12-2009, 03:10 PM   #2 (permalink)
Default Re: 2008 rear drum brake squeal is NORMAL...?
It'll go away after a bit.
rangerbob is offline   Reply With Quote
Old 02-12-2009, 03:30 PM   #3 (permalink)
I just had mine cleaned and adjusted (07 21k) and it fixed the squeal on mine. my ebrake seem tighter now.
David, I'll keep my money and guns, you keep your "change"
07 CC LT1 4x2 I5 Ruby Red: Team Red. TOTW Winner #30
08 Diamondback Peak Hardtail
Gun Toting American Club Member #50
stocklook is offline   Reply With Quote
Old 02-12-2009, 03:39 PM   #4 (permalink)
It has 15,000 miles on it.
How much longer is 'a bit'...? :D
Old 02-12-2009, 03:46 PM   #5 (permalink)
Yes dust builds up in them and they get noise.
I just pull the drums clean them off and it is all good again.
Newbi
Blaster is offline   Reply With Quote
Old 02-12-2009, 04:03 PM   #6 (permalink)
I'm baffled as to why I would need to pull my brake drums off of the back of my 2008 truck when I NEVER had to do that with a 1964 Pontiac that had drums on all 4 corners and never squealed like this truck does.
You can see my point, I'm sure.
Is the brake material different or is there some reason the dust isn't evacuated from the inside and therefore causes the noise.
Really. It IS annoying and sometimes gets strange looks when a brand new truck sounds like the wheels are coming off when coming to a stop.
Old 02-12-2009, 04:47 PM   #7 (permalink)
The friction materials have changed some over the years and so has the iron alloys used to cast the brake drums. The gap between the drum and backing plate doesn't allow for alot of air or water flow to keep the dust cleaned out. So the dust accumulates. In years past this dust was corrosive to the backing plate, brake springs, etc. So I got in the habit of pulling the drums off at every tire rotation and cleaning eveything up.
2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic MAXX Shackles: http://www.355nation.net/forum/suspe...here-here.html MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: http://www.355nation.net/forum/suspe...ering-kit.html
MAXX Stak Lift Kit for 2WD: http://www.355nation.net/forum/suspe...t-numbers.html PerforMAXX Body Lift: http://www.355nation.net/forum/suspe...y-spacers.html
ssgjurista is offline   Reply With Quote
Old 02-12-2009, 06:01 PM   #8 (permalink)
Cool.
It's due for the Discount Tire free rotation inspection anyway.
I'll ask them to do that when they service the truck.
Excellent.
Thanks.
Old 02-12-2009, 07:26 PM   #9 (permalink)
mine is a 08 with 3600 miles on it and the rear brakes squeek for the first few blocks then go away. i am thinking about taking it in to have it checked...
08 GMC Canyon, 3.7 liter I-5, Z71 EC, G80, Sunroof, Fire Red, Loaded. 1.5" shackle/TB lift with 09 17" Z71 Chrome rims.
jay15892 is offline   Reply With Quote
Old 02-12-2009, 08:01 PM   #10 (permalink)
Mine is an 08 with 6500 miles on it, does what jays does. After 2 or 3 times stopping it goes away. If it is dust, then I understand. I live in West Virginia so the coal trucks keep it dusty here.
2008 Colorado
Reg Cab W/T
2.9 5-Speed
BR29 is offline   Reply With Quote
You may not post new threads
You may not post replies
