Passenger Rear tire locks - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 05-17-2009, 01:54 PM Thread Starter
Why does my passenger rear tire, lock when the brakes get wet? It happen to me last night after going to work. I drove through a flooded parking lot and after i tried reversing, i believe my emergency brake, locks my passenger rear wheel only when going reverse. if you drive forward it does not lock, but trying to go reverse, it lets you go for about a split second than it feels like if you slammed on your brakes to stop. Right now I'm stuck on my apt. cant get out because i cant go reverse, due to the rear passenger brake, and there is a huge brick wall in front of my parking....
d1_drifter is offline
post #2 of 4 (permalink) Old 05-17-2009, 06:13 PM
Re: Passenger Rear tire locks
you could always throw it in netraul and push it back....if ya needed to go somewhere in a hurry...
And A Few Mods...
Koda22 is offline
post #3 of 4 (permalink) Old 05-18-2009, 01:24 AM
fbody4life's Avatar
I beleive there is a part in the back brakes that adjusts the brake pads when you are in reverse. There maybe something wrong with this and thats why it only happens in reverse. Hopefully someone that knows more about the brakes can chime in on this comment and help you out.
04' Crew Cab 4WD Z71
Lifted member #264
4" Skyjacker lift, 2" Shackles, 16x8 Pro Comp 8128, Toyo open country M/T 285/75R16
K&N CAI, Gutted pre-cat, MBRP exhaust, PCM4less tune
Kenwood DNX5120, Subthump box, Solobaric 8L7, Kicker amp, Infinity Kappa door speakers
SSK Crossmember Caps, Auto shifter
SuperSkidz front skid plate
fbody4life is offline
post #4 of 4 (permalink) Old 05-18-2009, 02:55 AM Thread Starter
well the neutral and push does not work i wish it did, but what i did today ones the rain stopped and the sun came out, I put it on reverse and it rolled easily well sorta than putting it back on drive it sounded like it needed brakes on the rear...so than the brakes were back to normal, but i replaced the brakes on the rear and well let me tell you i was lucky enough there were not touching metal to metal yet, but the truck needed rear brakes bad, maybe thats why they would lock up. My truck has 72,000 miles now and i had never replaced them ... i know it was about time... but hopefully that will fix the problem no rain yet it was a miracle we had some rain in Laredo,tx. Im just waiting to test it out again to see if this fixed the problem. Thanks for the ideas on trying to solve my problem coloradofans...!
